For a tensor S_{i j} I am trying to write its convective derivative in the velocity field v_k that will involve term v_k * d (S_{i j} ) / d x_k . Will this term be written as inner (v, nabla_grad(S)) or somehow else? I looked at the difference between grad and nabla_grad for vector but not sure if it will be the same for tensor. Thank you!
To implement v_kS_{ij,k}, you could use
T = dot(v,nabla_grad(S))
T = dot(grad(S),v)
or just specify it directly in index notation:
from ufl import indices
i,j,k = indices(3)
T = as_tensor(v[k]*(S[i,j].dx(k)),(i,j))
Basically, grad
adds the “new index” from spatial differentiation at the end of the output tensor, while nabla_grad
adds it at the beginning. dot
sums over the last index of its first argument and the first index of its second argument. inner
requires two arguments of the same shape and sums over all corresponding indices; this is equivalent to dot
when passing two vectors, but differs for higher-rank tensors.
