That’s what I did, but don’t get a list like yours (that I want)
def solve(n_mesh=5,
R_i=1.,
R_e=6.9,
aspect_ratio=1.,
E_m=0.8,
nu_m=0.35,
E_i=11.,
nu_i=0.3,
mesh_order=1,
dim_func=1,
dim_geom=2):
#MESH DESIGN
mesh_size = R_i/n_mesh
mesh_order = mesh_order
mesh_comm = MPI.COMM_WORLD
model_rank = 0
facet_names = {"inner_boundary": 1, "outer_boundary": 2}
cell_names = {"inclusion": 1, "matrix": 2}
model = gmsh.model()
model.add("Disk")
model.setCurrent("Disk")
gdim = dim_geom # geometric dimension of the mesh
inner_disk = gmsh.model.occ.addDisk(0, 0, 0, R_i, aspect_ratio * R_i)
outer_disk = gmsh.model.occ.addDisk(0, 0, 0, R_e, R_e)
whole_domain = gmsh.model.occ.fragment([(gdim, outer_disk)], [(gdim, inner_disk)])
gmsh.model.occ.synchronize()
# Add physical tag for bulk
inner_domain = whole_domain[0][0]
outer_domain = whole_domain[0][1]
model.addPhysicalGroup(gdim, [inner_domain[1]], tag=cell_names["inclusion"])
model.setPhysicalName(gdim, inner_domain[1], "Inclusion")
model.addPhysicalGroup(gdim, [outer_domain[1]], tag=cell_names["matrix"])
model.setPhysicalName(gdim, outer_domain[1], "Matrix")
# Add physical tag for boundaries
lines = gmsh.model.getEntities(dim=1)
inner_boundary = lines[1][1]
outer_boundary = lines[0][1]
gmsh.model.addPhysicalGroup(1, [inner_boundary], facet_names["inner_boundary"])
gmsh.model.addPhysicalGroup(1, [outer_boundary], facet_names["outer_boundary"])
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",mesh_size)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",mesh_size)
model.mesh.generate(gdim)
gmsh.option.setNumber("General.Terminal", 1)
model.mesh.setOrder(mesh_order)
gmsh.option.setNumber("General.Terminal", 0)
# Import the mesh in dolfinx
from dolfinx.io import gmshio
domain, cell_tags, facet_tags = gmshio.model_to_mesh(model, mesh_comm, model_rank, gdim=gdim)
domain.name = "composite"
cell_tags.name = f"{domain.name}_cells"
facet_tags.name = f"{domain.name}_facets"
gmsh.finalize()
# Defines integrals
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags) #we specify that we want to look at the facets and not the cells
dx = ufl.Measure("dx", domain=domain, subdomain_data=cell_tags)
one = dolfinx.fem.Constant(domain,ScalarType(1.))
area_inclusion = dolfinx.fem.assemble_scalar(dolfinx.fem.form( one * dx(1))) # in fenics when we want to do an integration,
#we use "assemble" wich means integration (it is a sum), and we specify on what we shall integrate " * dx "
area_matrix = dolfinx.fem.assemble_scalar(dolfinx.fem.form( one * dx(2)))
area_domain = dolfinx.fem.assemble_scalar(dolfinx.fem.form(one * ufl.dx))
# RESOLUTION
V = dolfinx.fem.VectorFunctionSpace(domain,("CG", dim_func),dim=2)
def eps(u):
return ufl.sym(ufl.grad(u))
I2 = ufl.Identity(2)
# Hooke's law is written as the top of this notebook
def sigma(eps, E, nu):
mu = E/(2*(1+nu))
lamb = 2*mu*nu/(1-2*nu)
return lamb*ufl.tr(eps)*I2 + 2*mu*eps
u = ufl.TrialFunction(V)
u_bar = ufl.TestFunction(V)
bilinear_form_inclusion = ufl.inner(sigma(eps(u),E_i, nu_i), eps(u_bar)) * dx(1)
bilinear_form_matrix = ufl.inner(sigma(eps(u),E_m, nu_m), eps(u_bar)) * dx(2)
bilinear_form = bilinear_form_inclusion + bilinear_form_matrix
g=0.0 # no weight
body_force = dolfinx.fem.Constant(domain, ScalarType((0,-g)))
linear_form = ( ufl.dot(body_force,u_bar) ) * ufl.dx
# this finds the label of the degree of freedom for the nodes on the boundary facets
outer_facets = facet_tags.find(2)
#print("tags:", outer_facets)
outer_boundary_dofs = dolfinx.fem.locate_dofs_topological(V, 1, outer_facets) #the "1" specify the dimension of our outer facets.
#Since problem is plan, we have facets of dimension 1
#print("dofs:",outer_boundary_dofs)
uD = dolfinx.fem.Function(V)
u_on_boundary = lambda x: np.array([-x[1], -x[0]], dtype=ScalarType) # we impose our displacement (-y, -x)
uD.interpolate(u_on_boundary)
bc = dolfinx.fem.dirichletbc(uD, outer_boundary_dofs) #we don't use V here, maybe because u-D is created via V
problem = dolfinx.fem.petsc.LinearProblem(bilinear_form, linear_form, bcs=[bc],
petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
u_solution = problem.solve()
return u_solution,V,domain, dx
And
def errOnU(n_mesh=5, R_i=1., R_e=6.9, aspect_ratio=1., E_m=0.8, nu_m=0.35, E_i=11., nu_i=0.3, mesh_order=1, dim_func=1, dim_geom=2):
u_solution,V,domain, dx=solve(n_mesh=n_mesh,
R_i=R_i,
R_e=R_e,
aspect_ratio=aspect_ratio,
E_m=E_m,
nu_m=nu_m,
E_i=E_i,
nu_i=nu_i,
mesh_order=mesh_order,
dim_func=dim_func,
dim_geom=dim_geom)
solution = EshelbyDisk(V,R_e/R_i, E_i/E_m, nu_i, nu_m)
u_ref_func = solution.to_function(R_i)
#L2 norm of error
comm = u_solution.function_space.mesh.comm
error = dolfinx.fem.form((u_solution - u_ref_func)**2 * ufl.dx)
E = np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(error), MPI.SUM))
return E
def hErrOnU(n_mesh=5, R_i=1., R_e=6.9, aspect_ratio=1., E_m=0.8, nu_m=0.35, E_i=11., nu_i=0.3, mesh_order=1, dim_func=1, dim_geom=2):
u_solution,V, domain, dx=solve(n_mesh=n_mesh,
R_i=R_i,
R_e=R_e,
E_m=E_m,
nu_m=nu_m,
E_i=E_i,
nu_i=nu_i,
dim_func=dim_func,
dim_geom=dim_geom)
#H1 norm of error
eh=u_solution-u_ref_func
error_H10 = dolfinx.fem.form(ufl.inner(ufl.grad(eh), ufl.grad(eh)) * ufl.dx)
E_H10 = np.sqrt(comm.allreduce(dolfinx.fem.assemble_scalar(error_H10), op=MPI.SUM))
return E_H10
AND
Ns_func = np.linspace(5,20,15)
Es = np.zeros(len(Ns_func), dtype=ScalarType)
hs_func = np.zeros(len(Ns_func), dtype=np.float64)
list_rates_func = []
list_Es_func = []
dims_func = [1,2]
for n in range(len(dims_func)):
dim = dims_func[n]
for i, N in enumerate(Ns_func):
Es[i] = errOnU(n_mesh=N, mesh_order=2, dim_func=dim)
hs_func[i] = 1./Ns_func[i]
list_Es_func.append(list(Es))
rates = np.log(Es[1:]/Es[:-1])/np.log(hs_func[1:]/hs_func[:-1])
list_rates_func.append(list(rates))
When I print list_rates_func I get :
... [[2.011665794652411, 1.6850005934011927, 1.8840370945040423, 1.966635297510356, 1.9576644014104467, 1.8030249817794606, 2.181434530061626, 1.7213391889052085, 1.7943062319011487, 2.2923098171232454, 1.9922249700633368, 1.5595450180285453, 1.852164312335911, 2.165495469948245], [3.826932420683513, 3.0349402932021596, 3.302177004609476, 3.2509235502998917, 3.412379530596236, 3.472389422791963, 4.127164694728427, 2.567438267394478, 3.6218380077435124, 3.350413987907959, 3.618251844630758, 2.682745423225503, 3.2143056438838937, 4.9182560160857]]
