Help with writing variational form in python
Hi, I have a problem with trying to get my variational problem to work correctly. I have
\partial_{L} P(L, \mathbf{x})=(\nabla \cdot \mathbf{a} \nabla+\mathbf{c} \cdot \nabla) P(L, \mathbf{x})
with
\mathbf{a}=\left[\begin{array}{ccc}\frac{A_{5}^{2} z^{2}}{2} & 0 & \frac{A_{5}^{2} x z}{2} \\ 0 & \frac{1}{2}\left(A_{1}^{2}+A_{2}^{2}+A_{3}^{2} \frac{z^{2}}{x^{2}}\right) & 0 \\ \frac{A_{3}^{2} x z}{2} & 0 & \frac{A_{2}^{2} x^{2}}{2}\end{array}\right], \quad \mathbf{c} = \begin{bmatrix}-A_4x \\ 0 \\ A_4z\end{bmatrix}.
My variational problem is then
\frac{P^{n+1}-P^{n}}{\Delta L} \approx(\nabla \cdot \mathbf{a} \nabla+\mathbf{c} \cdot \nabla) P^{n+1},
so
\int_{\Omega}\left(v(\mathrm{x}) P^{n+1}+\Delta L \mathrm{S}\right) d \mathrm{x}=\int_{\Omega} v(\mathrm{x}) P^{n} d \mathrm{x},
with
\mathrm{S}=\nabla v(\mathrm{x}) \cdot \mathrm{a} \nabla P^{n+1}-v(\mathrm{x}) \mathrm{c} \cdot \nabla P^{n+1}.
Furthermore
\begin{aligned} a(P, v) &=\int_{\Omega}(v(\mathbf{x}) P+\Delta L \mathbf{S}) d \mathbf{x} \\ L_{n+1}(v) &=\int_{\Omega} v(\mathbf{x}) P^{n} d \mathbf{x} \end{aligned}.
I try to formulate the problem in python as
a = np.array([[0.5*A_3**2*x[2]**2,0,0.5*A_3**2*x[0]*x[2]],[0,0.5*(A_1**2+A_2**2+A_3**2*(x[2]/x[0])**2),0],[0.5*A_3**2*x[0]*x[2],0,0.5*A_3**2*x[0]**2]])
cee = np.array([-0.5*A_3**2*x[0]+(A_3**2/2-A_4)*x[0], -A_5, -0.5*A_3**2*x[2]+(A_3**2/2+A_4)*x[2]])
a_grad_u = np.multiply(a,grad(u))
c_dot_grad_u = cee.dot(grad(u))
S = np.dot(grad(v),a_grad_u) - np.multiply(v,c_dot_grad_u)
a_form = (u*v + dl*(S))*dx
L_form = u_n*v*dx
Next I have
L = .2   #Final L
num_steps = 10  #Number of length steps
dl = L / num_steps #Length step size
then I solve
for n in range(num_steps):
#Update current lengthj
    l += dl
    #Solve
    solve(a_form == L_form, u)
#Update previous solution
    u_n.assign(u)
but I get the error
line 227, in solve
return dolfin.la.solver.solve(*args)
TypeError: solve() missing 1 required positional argument: ‘b’
Have I input my \mathbf{S} incorrectly? I feel like I’m making a really dumb mistake.
you should post the whole code with proper formatting so that people can help.
At first glance, you should not use Numpy dot or multiply functions but UFL dot or inner.
Apologies. Here is my code
L = .2   #Final L
#Define positive constants
A_1 = 6
A_2 = 7
A_3 = 5.4
A_4 = 6
A_5 = 7
#Intial mesh values
x0 = 0.01
y0 = 0.01
z0 = 1
#End mesh values
x1 = 3
y1 = 30
z1 = 3
#Number of cells in each direction of the mesh
nxyz = 20
#Define mesh
mesh = BoxMesh(Point(x0, y0, z0),Point( x1, y1, z1), nxyz, nxyz, nxyz)
x = SpatialCoordinate(mesh)
mpx=np.array(mesh.coordinates())
dx = Measure('dx',mesh)
#Dirac Delta (mass) initial condition with epsilon definition
u_D = Expression("(1./(pow(x[0],2) + pow(eps, 2)))*(1./(pow(x[1],2) + pow(eps, 2)))*(1./(pow(x[2]-1.,2) + pow(eps, 2)))", eps=1e-6, degree=2)
#Define initial value
u_n = interpolate(u_D, V)
C = assemble(u_n*dx)
u_n.assign(u_n/C)
#Bilinear form
S = dot(grad(v),a_grad_u) - np.multiply(v,c_dot_grad_u)
#Form
L_form = u_n*v*dx
#Starting to build length steps
l = 0
    print("We have",num_steps - n, "steps remaining." )
    l += dl
    #Solve
    u_file = File('u.pvd')
    u_file << u, l
    u_n.assign(u)
I may say, originally I had my \mathbf{S} written as
cee = np.array([-0.5*A_3**2*x[2]+(A_3**2/2-A_4)*x[0], -A_5, -0.5*A_3**2*x[0]+(A_3**2/2+A_4)*x[2]])
a_dot_grad_u = a.dot(grad(u))
S = np.dot(grad(v),a_dot_grad_u) - np.dot(v,c_dot_grad_u)
so
L_form = u_n*v*dx
and the code ran. I’m not sure it’s correct however since I use dot instead of multiply?
I think my formulation is fine, no? Since \nabla P is a scalar, i can just write dot(a,grad(u)) where u=P?
In your code, just change to
a_grad_u = dot(as_matrix(a),grad(u))
