Dear community
I solved a finite element problem on a cubic domain with FEniCs. To find certain quantities, I had to interpolate the solution on the mid-plane of the z-axis (thus on the mid-surface). the objective was to be able to perform the HILBERT transform in 2D of the solution obtained on this surface. After getting the solution, I turned it into a numpy array so I could use the hilbert2 function which is contained in the scipy library. only, after using this method, I realize that the NUMPY results are no longer compatible with the UFL language. I have tried ways to leave numpy to UFL without success. I also tried to project the solutions coming from numpy into a FunctionSpace but no results.
please i would like to know if there is any way to convert numpy array to UFL language? or, does UFL have a way to do the Hilbert transform?
Thank you in advance.
I will attach to this request a piece of my code.
Mh1 = FunctionSpace(mesh3, P12)
I4f1 = inner(f01, E_out1 * f01)
I4f11 = project(I4f1,Mh1)
I4f111 = np.array(I4f11.vector())
### hilbert transform ####
im_I1 = np.imag(hilbert2(I4f111))
r_I1 = np.real(hilbert2(I4f111))
PH1 = project(np.arctan(im_I1/r_I1),Mh1)
AM1 = project ((im_I1**2+r_I1**2)**0.5,Mh1)
I’ve the following conersion error
ufl.log.UFLValueError: Invalid type conversion: [[ 1.57073722 1.57021749 1.57040617 1.56843488 1.56973472 1.56643423
1.56896551 1.56555684 1.56899562 1.55090886 1.56425717 1.53243787
1.56745704 1.55792053 1.56876535 0.94090225 1.52773487 0.9977159
1.53468148 -1.27512584 1.56699534 -1.55738644 1.56924163 -1.5702078
1.0478015 -1.02568609 1.22021917 -1.32489794 1.50502088 -1.55033121
1.56391166 1.57044341 -1.57019304 -1.57052695 -0.90565318 -1.57040799
-0.54346908 -0.48537103 0.6835119 -1.15603898 0.97328087 -1.55865028
-1.56566246 -1.57079566 -1.56542658 -1.5706531 -1.56943593 -1.5704638
-0.1471946 1.25547389 0.20918702 1.42199656 -0.67474811 1.55724698
-1.56448427 -1.56324497 -1.56040751 -1.56812617 -1.56264603 -1.55667831
-1.56885723 -1.56848191 -1.5699468 -1.19916903 -1.5706108 -0.41933631
0.69237835 1.2720099 1.43488067 1.54366177 -1.56621239 1.55405021
1.47359874 1.47481035 1.50863242 1.48079876 1.54203298 -1.48488143
1.56189615 -1.56668644 1.47626401 -1.52436288 -0.20954633 0.82124713
1.14184567 1.3163255 1.54372384 1.4118422 1.29483438 0.62097153
1.24100497 1.00432834 1.42523366 -1.18306962 1.52210946 -1.56151785
-1.08539557 -1.57013113 -0.28051408 0.70041215 0.99295126 -0.68091119
0.8173392 -1.447112 -0.95665044 -0.91871426 -0.06246736 0.18037061
0.9341108 -1.22558773 -0.84120473 -1.55938942 -1.56183872 -1.57010119
1.51271111 1.55548121 -1.37979241 -1.31056101 -0.56499637 -0.63949099
-0.38254558 -1.42520975 -1.51402999 1.55921153 -1.38386978 -1.20059628
-0.76694737 -0.3381174 0.68236788 1.24376141 1.0962757 -1.5045341
0.12698094]] can not be converted to any UFL type.
