I want to create two domains with different elasticity. the main domain is square with length r2=8, the circle radious is r1=3 inside the square. I wrote the following code, but I am not sure this is correct.
E1 = 100e3 # Elastic modulus [MPa]
nu1 = 0.3 # Poisson’s ratio
E2 = 200e3 # Elastic modulus [MPa]
nu2 = 0.25 # Poisson’s ratio
dimension of geometry
r1= 3 #inner radius (mm)
a= 8 #outer radius (mm)
x=mesh_coord
class Left(SubDomain):
return near(x[0], 0.0)
class Right(SubDomain):
return near(x[0], 8.0)
class Bottom(SubDomain):
return near(x[1], 0.0)
class Top(SubDomain):
return near(x[1], 8.0)
class Omega_1(SubDomain):
return near((sqrt(x[0]**2+x[1]**2)<=3),0.0)
class Omega_2(SubDomain):
return near((sqrt(x[0]**2+x[1]**2)>3),8.0)
Initialize sub-domain instances
left = Left()
top = Top()
right = Right()
bottom = Bottom()
Omega_1 = Omega_1()
Omega_2 =Omega_2 ()
constrained displacement boundary
BC_bottom = DirichletBC(V_1, Constant((0.0)), bottom)
BC_left = DirichletBC(V_0, Constant((0.0)), left)
BC = [BC_bottom, BC_left]
Initialize mesh function for interior domains
domains = MeshFunction(“size_t”, mesh, mesh.topology().dim())
domains.set_all(0)
Omega_1.mark(domains, 1)
Omega_2.mark(domains, 2)
Initialize mesh function for boundary domains
boundaries = MeshFunction(‘size_t’, mesh, dim-1)
boundaries.set_all(0)
left.mark(boundaries,0)
bottom.mark(boundaries,1)
right.mark(boundaries,2)
top.mark(boundaries,3)
