This is my mesh:
In fact using this mesh the facet_markers only include the global boundary:
msh, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
But still I can access the internal subdomain boundaries by
tdim = msh.topology.dim
fdim = tdim - 1
boundary_facets = mesh.exterior_facet_indices(msh.topology)
This is an example of what I am doing:
import sys
import pyvista
import math
from dolfinx.io import XDMFFile, gmshio
from dolfinx.io.gmshio import model_to_mesh
sys.path.insert(0, 'meshes')
#import gmsh
import numpy.linalg as npla
from scipy.sparse.linalg import spsolve
import scipy.sparse as sps
from dolfinx import fem
from dolfinx import default_real_type, mesh
from ufl import FacetNormal, SpatialCoordinate, ds, dx, grad, CellDiameter, inner, dot, as_ufl #Unified form language pieces
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement, TensorElement,
as_vector, div, dot, dS,ds, dx, inner, outer, lhs, grad, nabla_grad, rhs, sym, jump, avg)
from dolfinx.fem import (Expression, Constant, Function, FunctionSpace,
assemble_scalar, dirichletbc, form, locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, LinearProblem
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
import numpy
#import functions1
#from dolfinx.plot import create_vtk_mesh
import dolfinx.io
from dolfinx import io
currentmesh = "mesh10" # Change N and the filename for different refinements
gmsh.option.setNumber("General.Terminal", 0)
gmsh.open(currentmesh + ".msh")
model = gmsh.model
model.setCurrent(currentmesh)
print('Model ' + model.getCurrent() + ' (' + str(model.getDimension()) + 'D)')
# Define mesh
msh, cell_markers, facet_markers = io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=2)
n = FacetNormal(msh)
degree=1
V = FunctionSpace(msh, ("CG", degree))
fdim = tdim - 1
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
(2, lambda x: np.isclose(x[0], 1)),
(3, lambda x: np.isclose(x[1], 0)),
(4, lambda x: np.isclose(x[1], 1))]
facet_indices1, facet_markers1 = [], []
fdim = msh.topology.dim - 1
facets = locate_entities(msh, fdim, locator)
facet_indices1.append(facets)
facet_markers1.append(np.full_like(facets, marker))
facet_indices1 = np.hstack(facet_indices1).astype(np.int32)
facet_markers1 = np.hstack(facet_markers1).astype(np.int32)
sorted_facets = np.argsort(facet_indices1)
facet_tag = meshtags(msh, fdim, facet_indices1[sorted_facets], facet_markers1[sorted_facets])
ds = Measure("ds", domain=msh, subdomain_data=facet_tag)
class BoundaryCondition():
def __init__(self, type, marker, values):
self._type = type
if type == "Dirichlet":
u_D = Function(V)
u_D.interpolate(values)
facets = facet_tag.find(marker)
dofs = locate_dofs_topological(V, fdim, facets)
self._bc = dirichletbc(u_D, dofs)
elif type == "Neumann":
self._bc = inner(values, v) * ds(marker)
elif type == "Robin":
self._bc = values[0] * inner(u-values[1], v)* ds(marker)
raise TypeError("Unknown boundary condition: {0:s}".format(type))
@property
def bc(self):
return self._bc
@property
def type(self):
return self._type
u_1 = Function(V)
u_1.interpolate(lambda x: 0*x[1]**0)
boundary_conditions = [BoundaryCondition("Dirichlet", 1, u_1),
BoundaryCondition("Dirichlet", 2, u_1),
BoundaryCondition("Dirichlet", 3, u_1),
BoundaryCondition("Dirichlet", 4, u_1),
jump_grad_u = dot(grad(u)('+'),n('+'))-dot(grad(u)('-'),n('-'))
jump_grad_v = dot(grad(v)('+'),n('+'))-dot(grad(v)('-'),n('-'))
jump_u = u('+')*n('+')+u('-')*n('-')
jump_v = v('+')*n('+')+v('-')*n('-')
epsilon=10.0**(-2)
alpha = dolfinx.fem.Constant(msh, 1.0)
h = CellDiameter(msh)
dS= Measure("dS", domain=msh, subdomain_data=facet_markers)
a = epsilon*dot(grad(u), grad(v))*dx+ u * v * dx- epsilon*inner(avg(grad(v)), jump_u) * dS + epsilon*inner(jump_v, avg(grad(u))) * dS+epsilon*(alpha / avg(h))* epsilon* inner(jump_u, jump_v) * dS#+epsilon*(alpha / avg(h))* epsilon* inner(jump_u, jump_v) * dS
LL= dolfinx.fem.Constant(msh, 1.0) * v * dx
F=a-LL
bcs = []
for condition in boundary_conditions:
if condition.type == "Dirichlet":
bcs.append(condition.bc)
F += condition.bc
a = lhs(F)
L = rhs(F)
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
I want only integrate over internal subdomain boundaries.
