Hello!
I have some experience with FEniCS in 2D and now I’ve got a 3D problem. I was recommended to generate a mesh in Gmsh and convert it for dolfin by meshio.
I tried to follow this example but it failed (I guess the meshio interface has been changed since then, meshio._mesh.Mesh.cells returns a list while a dict is expected in the example).
I’ve described the domain geometry in a .geo file:
SetFactory("OpenCASCADE");
R = DefineNumber[0.0005, Min 0, Step 0.0001, Name "Parameters/Omega radius"];
Z = DefineNumber[0.0005, Min 0, Step 0.0001, Name "Parameters/Omega height"];
R_small = DefineNumber[0.0002 , Min 0, Step 0.00001, Name "Parameters/Laser beam radius"];
d = DefineNumber[0.0003 , Min 0, Step 0.00001, Name "Parameters/Distance"];
Cylinder(10) = {0, 0, 0, 0, 0, Z, R_small, 0.5*Pi};
Cylinder(20) = {-d, 0, 0, 0, 0, Z, R_small, 0.5*Pi};
Rotate {{0, 0, 1}, {-d, 0, 0}, Pi/2} {
Volume{20};
Box(30) = {-0, -0, 0, -d, R_small, Z};
Cylinder(11) = {0, 0, 0, 0, 0, Z, R, 0.5*Pi};
Cylinder(21) = {-d, 0, 0, 0, 0, Z, R, 0.5*Pi};
Volume{21};
Box(31) = {-0, -0, 0, -d, R, Z};
Now I would like to:
- Number (or tag) the boundary surfaces.
- Pass the generated mesh with the boundary markers to dolfin.
I would appreciate a minimal working example for maybe a very simple geometry just to get started.
