How to achieve the transformation of the right-hand vector b under different processes
Dear all,
I am trying to convert vector b in different processes.Specifically, how to convert b assembled under 10 processes and b assembled under 4 processes into each other?(this is just an example).
How to obtain the corresponding mapping?I couldn’t find it in dolfinx.
import petsc4py
from dolfinx import default_real_type, fem, io, mesh,default_scalar_type
from dolfinx.fem.petsc import assemble_matrix, assemble_vector
from ufl import (CellDiameter, FacetNormal, TestFunction, TrialFunction, avg,
                 conditional, div, dot, dS, ds, dx, grad, gt, inner, outer,
                 TrialFunctions,TestFunctions,curl,cross)
from dolfinx.io import gmshio,XDMFFile
from basix.ufl import element,mixed_element
                                 create_vector, set_bc,create_matrix)
import time
from dolfinx.fem.petsc import (apply_lifting, assemble_matrix_block, assemble_vector_block,
                                 create_vector_block, set_bc,create_matrix_block,create_matrix)
import os
msh = mesh.create_rectangle(
    comm=MPI.COMM_WORLD,
    points=((0.0, 0.0), (1.0, 1.0)),
    n=(4, 4),
    cell_type=mesh.CellType.triangle,
P_space=fem.functionspace(msh,("CG",1))
P,q=ufl.TrialFunction(P_space), ufl.TestFunction(P_space)
h = CellDiameter(msh)
a = fem.form(inner(grad(P), grad(q)) * dx+0.1/h*inner(P,q)*ds )
L = fem.form(inner(fem.Constant(msh, 1.0), q) * dx)
A = fem.petsc.assemble_matrix(a); A.assemble()
b = fem.petsc.assemble_vector(L)
b.setRandom()
################define in sub process
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
color = 0 if rank < 2 else MPI.UNDEFINED
poisson_comm = comm.Split(color=color, key=rank)
if poisson_comm:
    prank = poisson_comm.Get_rank()
    poss_msh = mesh.create_rectangle(
    comm=poisson_comm,
    n=(4, 4),
    gdim = poss_msh.geometry.dim
    ph = CellDiameter(poss_msh)
    pV = fem.functionspace(poss_msh, ("CG", 1))
    pu, pv = TrialFunction(pV), TestFunction(pV)
    pa = fem.form(inner(grad(pu), grad(pv)) * dx+0.1/ph*inner(pu,pv)*ds )
    pL = fem.form(inner(fem.Constant(poss_msh, 1.0), pv) * dx)
    pA = fem.petsc.assemble_matrix(pa); pA.assemble()
    pb = fem.petsc.assemble_vector(pL)
    #pb=b(dofmap)
    pass
You should then store the vector in a dolfinx.fem.Function of the corresponding space, and use adios4dolfinx to checkpoint it: ADIOS4DOLFINx - A framework for checkpointing in DOLFINx — ADIOS2Wrappers
Thanks dokken,
I have been using dolfinx0.8.Thus I want to solve it through indexing.
For example, regarding this issue:
import petsc4py
import time
import os
    n=(2, 2),
def frv(x):
    values = np.zeros((2, x.shape[1]), dtype=PETSc.ScalarType)
    values=x[0]**2+x[1]**2
    return values
fr=fem.Function(P_space)
fr.interpolate(frv)
L = fem.form(inner(fr, q) * dx)
offset = P_space.dofmap.index_map.size_local * P_space.dofmap.index_map_bs
ff=fem.Function(P_space)
print(f'rank is {rank} val is :',b.array_r)
dof_coordinates = P_space.tabulate_dof_coordinates()
num_local_dofs = P_space.dofmap.index_map.size_local
out = open(f'dof_cor{rank}.csv', "w")
for x in dof_coordinates[:num_local_dofs, :]:
    print(f"{x[0]:.5f},{x[1]:.5f},{x[2]:.5f}", file=out)
out.close()
In fact, only the node numbers under each process need to be known.
In this example, use 2 processe:
rank 0 :[9 8 6 3]
rank 1 :[5 7 4 1 2]
I want to obtain this index. Does dolfinx store this information?
