How to add a constant stress tensor to the stress expression? (linear elasticity)
Hi, a new user here, so a very basic question.
I have started to modify an elasticity example code. The initial code describes a steady-state deformation of a rectangular 3D beam, clamped on one end and deforming under its own gravity.
I have changed it to 2D and then wanted to include pre-stress, basically adding a constant (2,2) tensor to the stress function (see the code below).
I could not make the shapes of the addition arguments to match. I have also tried adding a constant scalar to a scalar field (Poisson example) in a similar fashion (taking the trial function u, and defining a new one) and it worked well, however, adding a Constant((1,0)) vector to the gradient of the test function didn’t work.
What am I doing wrong here? Thanks in advance :slight_smile:
MWE code:
from ufl import nabla_div, nabla_grad
# Scaled variables
L = 1; W = 0.2 # length and width
mu, lambda_ = 1, 1.25 #Lame coeffs
rho = 1
delta = W/L
g = 0.4*delta**2
mesh = RectangleMesh(Point(0, 0), Point(L, W), 50, 15, diagonal = "crossed")
# Define boundary condition
tol = 1E-14
def clamped_boundary(x, on_boundary):
    return on_boundary and x[0] < tol
bc = DirichletBC(V, Constant((0, 0)), clamped_boundary)
# Define strain and stress
def sigma(u):
    # The problem is in the line below. It works perfectly fine if the last term is not there
    return lambda_*nabla_div(u)*Identity(d) + 2*mu*epsilon(u) + as_tensor(((1,2),(3,4)))
##### Define variational problem
d = u.geometric_dimension()
f = Constant((0, -rho*g))
L = dot(f,v)*dx
solve(a == L, u, bc)
The error is:
  File "MWE_elasticity.py", line 46, in <module>
  File "/usr/lib/python3/dist-packages/dolfin/fem/solving.py", line 220, in solve
  File "/usr/lib/python3/dist-packages/dolfin/fem/solving.py", line 241, in _solve_varproblem
    problem = LinearVariationalProblem(eq.lhs, eq.rhs, u, bcs,
  File "/usr/lib/python3/dist-packages/dolfin/fem/problem.py", line 56, in __init__
    a = Form(a, form_compiler_parameters=form_compiler_parameters)
  File "/usr/lib/python3/dist-packages/dolfin/fem/form.py", line 43, in __init__
    ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
  File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 47, in mpi_jit
  File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 97, in ffc_jit
  File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 217, in jit
    module = jit_build(ufl_object, module_name, parameters)
  File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 130, in jit_build
    module, signature = dijitso.jit(jitable=ufl_object,
  File "/usr/lib/python3/dist-packages/dijitso/jit.py", line 165, in jit
    header, source, dependencies = generate(jitable, name, signature, params["generator"])
  File "/usr/lib/python3/dist-packages/ffc/jitcompiler.py", line 65, in jit_generate
    code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
  File "/usr/lib/python3/dist-packages/ffc/compiler.py", line 142, in compile_form
    return compile_ufl_objects(forms, "form", object_names,
  File "/usr/lib/python3/dist-packages/ffc/compiler.py", line 185, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
  File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 89, in analyze_ufl_objects
    form_datas = tuple(_analyze_form(form, parameters)
  File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 89, in <genexpr>
  File "/usr/lib/python3/dist-packages/ffc/analysis.py", line 169, in _analyze_form
    form_data = compute_form_data(form,
  File "/usr/lib/python3/dist-packages/ufl/algorithms/compute_form_data.py", line 418, in compute_form_data
    check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)  # Currently testing how fast this is
  File "/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py", line 177, in check_form_arity
    check_integrand_arity(itg.integrand(), arguments, complex_mode)
  File "/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py", line 159, in check_integrand_arity
    arg_tuples = map_expr_dag(rules, expr, compress=False)
  File "/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py", line 37, in map_expr_dag
    result, = map_expr_dags(function, [expression], compress=compress)
  File "/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py", line 86, in map_expr_dags
    r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
  File "/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py", line 48, in sum
    raise ArityMismatch("Adding expressions with non-matching form arguments {0} vs {1}.".format(_afmt(a), _afmt(b)))
ufl.algorithms.check_arities.ArityMismatch: Adding expressions with non-matching form arguments () vs ('v_1',).
Hello
Your bilinear part (a) should contain both trial and test functions. As you are adding a constant value to your stress term, then definition of the bilinear part is not correct in your implementation. So instead of:
L = dot(f,v)*dx
You can replace:
F = inner(sigma(u), epsilon(v))*dx - dot(f,v)*dx
a, L = lhs(F), rhs(F)
It works, thanks a lot! You have saved me a lot of hours of frustration :slight_smile:
If I understand correctly, my added term becomes linear
inner(my_constant_tensor,epsilon(v))*dx
and probably moves to the right hand side?
That is right. As it only includes the test function, then this term should appear in the linear part (e.g. L).
Hi Leo
I have a similar issue, but i need to add a depth dependent stress tensor like:
t=np.array([[22.26,4.29],[4.29,13.8]])
T=as_tensor(t)
y_insitu=849.9 #depth stress in situ medition
y_max=1179.735 #upper limit
stress_in = Expression(("(y_max-x[1])/(y_max-y_insitu)",0),degree=1,y_max=y_max,y_insitu=y_insitu)
#Functions
def eps(v):
  return sym(grad(v))
def sigma(v):
  return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v) + T*stress_in
When i add the tensor as a constant its works, but when apply the depht dependent function y have the error: UFLException: Can’t add expressions with different shapes.
I hope you can help me pls
From the error it is clear that you are not allowed to multiply an expression of rank 1 (vector) to a tensor (rank 2). In other words, the shapes must be consistent. You may want to take a look at Expression class in FEniCS
Here is a working example:
# Scaled variables
mu, lmbda = 1, 1.25 #Lame coeffs
rho = 1
delta = W/L
g = 0.4*delta**2
tol = 1E-14
x = SpatialCoordinate(mesh)
T=as_tensor(t)
S = as_tensor([[(y_max-x[1])/(y_max-y_insitu), 0],[0, (y_max-x[1])/(y_max-y_insitu)]])
def eps(v):
  return sym(grad(v))
def sigma(v):
  return lmbda*tr(eps(v))*Identity(2) + 2.0*mu*eps(v) + T*S
F = inner(sigma(u), eps(v))*dx - dot(f,v)*dx
Thanka a lot, it works perfect!
