How to add values to a Matrix?
In fenics 2018, I was able to do
A = assemble(...)
A.add(local_tensor, local_to_global_map, local_to_global_map)\
but with fenics 2019 I now get the error “AttributeError: ‘dolfin.cpp.la.Matrix’ object has no attribute ‘add’”
Here is the full example:
from __future__ import division
import logging
from dolfin import (
    FunctionSpace,
    TestFunction,
    TrialFunction,
    assemble,
    assemble_local,
    cells,
    dx,
    grad,
    inner,
    UnitSquareMesh
mesh = UnitSquareMesh(8,8)
A = assemble(a)
A.zero()
dof_map = V.dofmap()
dof_coord = V.tabulate_dof_coordinates()
for cell in cells(mesh):
    local_to_global_map = dof_map.cell_dofs(cell.index())
    local_tensor = assemble_local(a, cell)
    A.apply("insert")
Thank you for your help.
You could try using the petsc4py API to add values to your matrix as suggested here: Add Matrix to Assembled Matrix - #2 by kamensky
import logging
mesh = UnitSquareMesh(2,2)
A = assemble(a)
mat = as_backend_type(A).mat()
b1 = A.array() # just for a quick comparison (you shouldn't do this)
A.zero()
    mat.setValuesLocal(local_to_global_map.tolist(), local_to_global_map.tolist(), local_tensor, PETSc.InsertMode.ADD)
A.apply("insert")
mat.assemble()
b2 = A.array()
np.testing.assert_allclose(b1,b2)  # True
