How to apply boundary conditions when using petsc4py.PETSc.SNES directly?
Hello everyone,
I am currently trying to solve a nonlinear problem by using petsc4py.PETSc.SNES directly. The problem is a 2D unit square with a neo-Hooke material and a traction applied to the right boundary. I followed the code given by niewiarowski and nate:
https://fenicsproject.discourse.group/t/using-petsc4py-petsc-snes-directly/2368
I encounter a problem when it comes to the boundary conditions: Everything seems to work fine when I set a non-homogeneous Dirichlet-BC (e.g. a displacement of (0,0.1) ) to the left boundary. However, when I set a zero-displacement Dirichlet-BC to the left boundary, the solution shows a zero-displacement in the whole domain, ignoring the traction set to the right side.
Here is a picture of the solution field, on the left with the non-zero Dirichlet-BC and on the right with the zero Dirichlet-BC:
Here is the MWE:
import dolfin as dlf
import petsc4py, sys
petsc4py.init(sys.argv)
# Elasticity parameters
E, nu = 10.0, 0.3
mu, lmbda = dlf.Constant(E/(2*(1 + nu))), dlf.Constant(E*nu/((1 + nu)*(1 - 2*nu)))
# boundary displacement
u0 = dlf.Constant((0, 0))
# u0 = dlf.Constant((0, 0.1)) # with this u0, everything seems to work
# boundary traction
t0 = dlf.Constant((0.0, 0.1))
# volume force
f = dlf.Constant((0.0, 0.0))
# define boundaries
def left(x, on_boundary):
    return on_boundary and dlf.near(x[0], 0.0)
def right(x, on_boundary):
    return on_boundary and dlf.near(x[0], 1)
mesh=dlf.UnitSquareMesh(16,16)
# define function space
V = dlf.VectorFunctionSpace(mesh, 'P', 1)
# define Dirichlet (displacement) boundary conditions
bcleft = dlf.DirichletBC(V, u0, left)
bcs = [bcleft]
#define Neumann (traction) boundary conditions
traction_markers = dlf.MeshFunction('size_t', mesh, mesh.topology().dim()-1)
traction_markers.set_all(0)
traction_domain = dlf.AutoSubDomain(right)
traction_domain.mark(traction_markers, 1)
ds_t = dlf.ds(subdomain_data=traction_markers)(1)
# define variational problem
u = dlf.Function(V)
v = dlf.TestFunction(V)
du = dlf.TrialFunction(V)
# Kinematics
d = u.geometric_dimension()
I = dlf.Identity(d)             # Identity tensor
F = I + dlf.grad(u)             # Deformation gradient
C = F.T*F
Ic = dlf.tr(C)
J  = dlf.det(F)
psi = (mu/2)*(Ic - 3) - mu*dlf.ln(J) + (lmbda/2)*(dlf.ln(J))**2
# Total potential energy
Pi = psi*dlf.dx - dlf.dot(f, u)*dlf.dx - dlf.dot(t0, u)*ds_t
# Compute first variation of Pi (directional derivative about u in the direction of v)
Var = dlf.derivative(Pi, u, v)
#Jac = dlf.derivative(Var, u, du)
class SNESProblem():
    def __init__(self, F, u, bcs):
        V = u.function_space()
        self.L = F
        self.a = dlf.derivative(F, u, du)
        self.bcs = bcs
        self.u = u
    def F(self, snes, x, F):
        x = dlf.PETScVector(x)
        F  = dlf.PETScVector(F)
        dlf.assemble(self.L, tensor=F)
        for bc in self.bcs:
            bc.apply(F, x)
    def J(self, snes, x, J, P):
        J = dlf.PETScMatrix(J)
        dlf.assemble(self.a, tensor=J)
        for bc in self.bcs:
            bc.apply(J)
problem = SNESProblem(Var, u, bcs)
b = dlf.PETScVector()
J_mat = dlf.PETScMatrix()
snes = PETSc.SNES().create(dlf.MPI.comm_world)
snes.setFunction(problem.F, b.vec())
snes.setJacobian(problem.J, J_mat.mat())
snes.setFromOptions()
snes.solve(None, problem.u.vector().vec())
uconv = u((1,1))
print('')
print(' Reporting results ...')
print(' v(1/1) = ', uconv[1])
# Plot and hold solution
pu=dlf.plot(u, mode='displacement')
plt.colorbar(pu)
I am using the dolfin version 2019.2.0.dev.
Any help would be greatly appreciated!
Jana
@niewiarowski, @nate maybe you can help?
Hi, did you manage to figure this out?
Hi! No, unfortunately not… Do you have any ideas?
An illustration of how to use snes with bcs in dolfinx is shown: dolfinx/test_nonlinear_assembler.py at main · FEniCS/dolfinx · GitHub
I tried a few things but nothing immediately comes to mind. It’s interesting that u0 = dlf.Constant((0, 1e-5)) doesn’t work but u0 = dlf.Constant((0, 1e-4)) does. Can you replicate this issue with another problem?
@dokken thanks for the reference. I am considering to switch to dolfinx for this problem.
@niewiarowski it took me some time, but I managed to replicate the issue with a Poisson problem. I am using u_D as a constant Dirichlet BC on the left, right and bottom boundary and applying a Neumann BC on the top of the domain. The results look like this (left: u_D=Constant(0), right: u_D=Constant(1e-3). In this example, u_D=Constant(1e-4) doesn’t work anymore.
When playing around with this example, I compared it to the results of an implementation of the same problem, but with the standard usage of SNES via solver.parameters['nonlinear_solver']='snes' and NonlinearVariationalProblem. The results are not the same - e.g. if I choose u_D=Constant(0.1), I get a result of u(0.5,0.5) = 0.4201732544314507 for the direct implementation of SNES and u(0.5,0.5) = 0.26009739812490046 for the standard one.
I attach both codes here and would be happy to hear any ideas.
  1. Code where I try to use SNES directly
mesh = UnitSquareMesh(8, 8)
V = FunctionSpace(mesh, 'P', 2)
# Define boundary condition
#u_D = Expression('1 + x[0]*x[0] + 2*x[1]*x[1]', degree=2)
u_D=Constant(0.1)
    return on_boundary and near(x[0], 0.0)
    return on_boundary and near(x[0], 1.0)
def bottom(x, on_boundary):
    return on_boundary and near(x[1], 0.0)
def top(x, on_boundary):
    return on_boundary and near(x[1], 1.0)
bc_left = DirichletBC(V, u_D, left)
bc_right = DirichletBC(V, u_D, right)
bc_bottom = DirichletBC(V, u_D, bottom)
bc_top = DirichletBC(V, u_D, top)
bcs=[bc_left,bc_right,bc_bottom]
#f = Constant(-6.0)
f=Constant(0)
a = dot(grad(u), grad(v))*dx
g_s=Constant(2)
L = f*v*dx+g_s*v*ds
F = a-L
        du = TrialFunction(V)
        self.L = F
        self.a = derivative(F, u, du)
        self.bcs = bcs
        self.u = u
        x = PETScVector(x)
        F  = PETScVector(F)
        for bc in self.bcs:
            bc.apply(F, x)
        J = PETScMatrix(J)
        for bc in self.bcs:
            bc.apply(J)
problem = SNESProblem(F, u, bcs)
b = PETScVector()
J_mat = PETScMatrix()
snes = PETSc.SNES().create(MPI.comm_world)
uconv = u((0.5,0.5))
print('')
print(' u(0.5,0.5) = ', uconv)
# Plot solution and mesh
pu=plot(u)
plot(mesh)
plt.colorbar(pu)
  1. Code with SNES as a parameter:
u_D=Constant(0.1)
def boundary(x, on_boundary):
    return on_boundary
#f = Constant(-6.0)
f=Constant(0)
g_s=Constant(2)
L = f*v*dx+g_s*v*ds
F = a-L
# Compute solution
Jac = derivative(F,u)
problem = NonlinearVariationalProblem(F,u,bcs,Jac)
solver=NonlinearVariationalSolver(problem)
solver.solve()
print('')
pu=plot(u)
plot(mesh)
plt.colorbar(pu)
