I want to know how metadata is implemented in ufl.Measure?And what is the quadrature rule used here?(a 4th degree rule?)
Is there a way to change to different quadrature rules in Dolfinx?
In addition, I try to use the following codes to try to compare the degree of the qudrature rules but the result is the same for degree from 1 to 4, so it seems that I should also change the functionspace where the function f lives ?
from dolfinx import fem,mesh
domain=mesh.create_interval(MPI.COMM_WORLD,1,[0,1])
V=fem.FunctionSpace(domain,("CG",1))
#I want to intergate f=x^2 from 0 to 1
f=fem.Function(V)
u=lambda x: x[0]**2
f.interpolate(u)
metadata={"qudrature_degree":4}
a=f*ufl.dx(domain=domain,metadata=metadata)
a_=fem.form(a)
b=fem.assemble_scalar(a_)
print(b)
x=ufl.SpatialCoordinate(domain)
f=x[0]**2
for k in rang(3):
meta={"qudrature_degree":k}
dx=ufl.Measure('dx',domain=domain,metadata=meta)
a=f*ufl.dx
b=fem.assemble_scalar(fem.form(a))
print(b)
but I get the same results, is there something wrong?
Im not at a computer, but it might be super-convergence due to the mesh being structured. Either try with a higher order polynomial or an unstructured mesh.
from dolfinx import fem, mesh
domain = mesh.create_interval(MPI.COMM_WORLD, 1, [0, 1])
# I want to intergate f=x^2 from 0 to 1
f = x[0]**2
for i in range(5):
metadata = {"quadrature_degree": i}
a = f*ufl.dx(domain=domain, metadata=metadata)
a_ = fem.form(a)
b = fem.assemble_scalar(a_)
print(i, f"{b:.5e}")
Great thanks!
Sorry for questions about this typo
when I use “qudrature_degree” it sends no error ,so what is the reason here?It seems that something is implicitly implemented here.
Why should it? DOLFINx only parses the metadata for known keys, if they are not found it uses default values. Potentially your dict could have thousands of entries, that we would not want to parse to check the validity of each key, or making educated guesses on what a key should be interpreted as.
