Dear Fenics community
I am new to Fenics and hence the following question.
How to compute the curvature of a curved boundary of the domain? I have tried curvature, H, as
H =-\text{\div( n)}, where \text n is the unit normal vector of the boundary. When I compute assemble( H* \mathbf dS) for a circle, it results in zero, instead of 2\pi. I have gone through this forum and found a thread on the explanation for the same. However, I could not compute curvature. Could anyone kindly help me with computing it in any possible way by posting a code snippet?
Thanks
Using functionality implemented in dolfin-adjoint, which is an extension/generalization of an implementation in FEmorph, you can do the following (only works for CG1-approximations of the curvature and normal vector.
The following code first projects the facet normal to the boundary of a volume CG-1 function space, then transfering it to the boundary-mesh, consisting only of the exterior facets.
Then, we compute the curvature on the boundary-mesh, and transfer the values back to the volume mesh.
import numpy
import dolfin
def mesh_to_boundary(v, b_mesh):
Returns a the boundary representation of the CG-1 function v
# Extract the underlying volume and boundary meshes
mesh = v.function_space().mesh()
# We use a Dof->Vertex mapping to create a global
# array with all DOF values ordered by mesh vertices
DofToVert = dolfin.dof_to_vertex_map(v.function_space())
VGlobal = numpy.zeros(v.vector().size())
vec = v.vector().get_local()
for i in range(len(vec)):
Vert = dolfin.MeshEntity(mesh, 0, DofToVert[i])
globalIndex = Vert.global_index()
VGlobal[globalIndex] = vec[i]
VGlobal = SyncSum(VGlobal)
# Use the inverse mapping to se the DOF values of a boundary
# function
surface_space = dolfin.FunctionSpace(b_mesh, "CG", 1)
surface_function = dolfin.Function(surface_space)
mapa = b_mesh.entity_map(0)
DofToVert = dolfin.dof_to_vertex_map(dolfin.FunctionSpace(b_mesh, "CG", 1))
LocValues = surface_function.vector().get_local()
for i in range(len(LocValues)):
VolVert = dolfin.MeshEntity(mesh, 0, mapa[int(DofToVert[i])])
GlobalIndex = VolVert.global_index()
LocValues[i] = VGlobal[GlobalIndex]
surface_function.vector().set_local(LocValues)
surface_function.vector().apply('')
return surface_function
def vector_mesh_to_boundary(func, b_mesh):
v_split = func.split(deepcopy=True)
v_b = []
for v in v_split:
v_b.append(mesh_to_boundary(v, b_mesh))
Vb = dolfin.VectorFunctionSpace(b_mesh, "CG", 1)
vb_out = dolfin.Function(Vb)
scalar_to_vec = dolfin.FunctionAssigner(Vb, [v.function_space() for
v in v_b])
scalar_to_vec.assign(vb_out, v_b)
return vb_out
def SyncSum(vec):
""" Returns sum of vec over all mpi processes.
Each vec vector must have the same dimension for each MPI process """
comm = dolfin.MPI.comm_world
NormalsAllProcs = numpy.zeros(comm.Get_size() * len(vec), dtype=vec.dtype)
comm.Allgather(vec, NormalsAllProcs)
out = numpy.zeros(len(vec))
for j in range(comm.Get_size()):
out += NormalsAllProcs[len(vec) * j:len(vec) * (j + 1)]
return out
def boundary_to_mesh(f, mesh):
b_mesh = f.function_space().mesh()
SpaceV = dolfin.FunctionSpace(mesh, "CG", 1)
SpaceB = dolfin.FunctionSpace(b_mesh, "CG", 1)
F = dolfin.Function(SpaceV)
GValues = numpy.zeros(F.vector().size())
map = b_mesh.entity_map(0) # Vertex map from boundary mesh to parent mesh
d2v = dolfin.dof_to_vertex_map(SpaceB)
v2d = dolfin.vertex_to_dof_map(SpaceV)
dof = SpaceV.dofmap()
imin, imax = dof.ownership_range()
for i in range(f.vector().local_size()):
GVertID = dolfin.Vertex(b_mesh, d2v[i]).index() # Local Vertex ID for given dof on boundary mesh
PVertID = map[GVertID] # Local Vertex ID of parent mesh
PDof = v2d[PVertID] # Dof on parent mesh
value = f.vector()[i] # Value on local processor
GValues[dof.local_to_global_index(PDof)] = value
GValues = SyncSum(GValues)
F.vector().set_local(GValues[imin:imax])
F.vector().apply("")
return F
mesh = Mesh(UnitDiscMesh.create(MPI.comm_world, 100, 1, 2))
V = VectorFunctionSpace(mesh, "CG", 1)
a = inner(u,v)*ds
l = inner(n, v)*ds
A = assemble(a, keep_diagonal=True)
L = assemble(l)
A.ident_zeros()
nh = Function(V)
solve(A, nh.vector(), L)
File("nh.pvd") << nh
bmesh = BoundaryMesh(mesh, "exterior")
nb = vector_mesh_to_boundary(nh, bmesh)
Q = FunctionSpace(bmesh, "CG", 1)
p, q = TrialFunction(Q), TestFunction(Q)
a = inner(p,q)*dx
l = inner(div(nb), q)*dx
L = assemble(l)
A.ident_zeros()
kappab = Function(Q)
solve(A, kappab.vector(), L)
kappa = boundary_to_mesh(kappab, mesh)
print(assemble(kappa*ds))
File("kappa.pvd") << kappa
Thanks for the kind help, Dokken!
Is there an alternate way where I can extract the coordinates of the boundary (say internal boundary, a curved interface between two fluids) and then compute curvature using the standard definition from the derivates of the position vector?
Thanks
Dear Dokken
With the above method, I could compute curvature for the external boundaries. However, I am unable to compute the same for an internal boundary (a circular interface between two different fluids in a rectangular box ) as it leads to errors. Could you kindly help me with this internal boundary curvature? Sorry for the trouble.
Thanks
This method only works for exterior boundaries, as that is what is used to transfer quantities. To do this with interior boundaries, you need to define a SubMesh for a volume with the internal interface as an exterior boundary, and then create a boundary mesh for the submesh.
Thanks for the help Dokken.
