nate:
bespoke approach
Hi Nate,
The Python script is below. Note that this script was mainly generated by FEATool Multiphysics.
FEATool Multiphysics → FEniCS project conversion
File featool-fenics.py created 29-Apr-2025 11:15:36
try:
except:
raise ImportError(“Could not find/import fenics.”)
from timeit import default_timer as timer
import atexit
comm = MPI.comm_world
size = comm.Get_size()
rank = comm.Get_rank()
import library
from scipy.interpolate import interp1d
import pandas as pd
Functions
def tc_inter(T):
# read txt file
thermal_cond = pd.read_csv(“../Data/ThermalCond.txt”)
# temperature and thermal conductivity
TV = thermal_cond.iloc[:,0].to_numpy()
TCv = thermal_cond.iloc[:,0].to_numpy()
# interpolate
f = interp1d(Tv, TCv,kind='cubic')
tc_val = f(T)
return tc_val
Mesh and subdomains.
with HDF5File(comm, “/tmp/featool-fenics.h5”, “r”) as f:
mesh = Mesh()
f.read(mesh, “/mesh”, False)
subd = MeshFunction(“size_t”, mesh, mesh.topology().dim())
f.read(subd, “/mesh”)
bdr = MeshFunction(“size_t”, mesh, mesh.topology().dim()-1)
f.read(bdr, “/boundary”)
dx = Measure(“dx”, domain=mesh, subdomain_data=subd)
ds = Measure(“ds”, domain=mesh, subdomain_data=bdr)
nz = n[0]
nr = n[1]
Finite element spaces.
E1 = FiniteElement(“P”, mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, E1)
Function spaces.
T = Function(V)
T_t = TestFunction(V)
T_n = Function(V)
Model constants and expressions.
dt = 0.001
tmax = 0.2
t = 0.0
t_i = Expression(“t”, degree=1, t=0.0)
z = Expression(“x[0]”, degree=1)
r = Expression(“x[1]”, degree=1)
h_grid = CellDiameter(mesh) if “CellDiameter” in globals() else CellSize(mesh)
rho_ht_0 = Constant(0.5)
cp_ht_0 = Constant(7000)
u_ht_0 = Constant(0)
v_ht_0 = Constant(0)
k_ht_0 = tc_inter(T)
q_ht_0 = 200.01800.0 1800.0
Mass forms.
m = ((rrho_ht_0 cp_ht_0)T T_t)*dx
Bilinear forms.
a = dt*(((rrho_ht_0 cp_ht_0*u_ht_0)T.dx(0)T_t + (r k_ht_0)T.dx(0)T_t.dx(0) + (r rho_ht_0 cp_ht_0 v_ht_0)*T.dx(1)T_t + (r k_ht_0)*T.dx(1)*T_t.dx(1))*dx)
Linear forms.
f = ((dt*(rq_ht_0) + (r rho_ht_0*cp_ht_0)*T_n)*T_t)*dx
Boundary conditions.
dbc0 = DirichletBC(V, Constant(300), bdr, 1)
dbc1 = DirichletBC(V, Constant(300), bdr, 2)
dbc = [dbc0, dbc1]
Initial conditions.
dvar = [“T”]
T_n = project(Expression(“Tini(x[1])”, degree=1), V)
assign(T, T_n)
Solver parameters.
param = {
“newton_solver”: {
“linear_solver”: “default” if “default” in linear_solver_methods() else “default”,
“preconditioner”: “default” if “default” in krylov_solver_preconditioners() else “default”,
“maximum_iterations”: 20,
“relaxation_parameter”: 1.0,
“relative_tolerance”: 1e-06,
“absolute_tolerance”: 1e-06,
Solve.
f_data = HDF5File(comm, “/tmp/featool-fenics.h5”, “a”)
atexit.register(lambda: f_data.close())
t_start = timer()
f_data.write(T, “/” + dvar[0], 0.0)
n_ts = int(-(tmax // -dt))
for i_step in range(n_ts):
print(“Time step %i, time = %f” % (i_step+1, t)) if rank == 0 else None
t_i.t = t
solve(m + a - f == 0, T, dbc, solver_parameters=param)
T_n.assign(T)
f_data.write(T, “/” + dvar[0], t)
t_solve = comm.gather(timer() - t_start)
print(“t_solve = %g (tot: %g)” % (max(t_solve), sum(t_solve))) if rank == 0 else None
