How to create a Dolfinx expression from a cross product?
I’m on Dolfinx 0.10.0 using the nightly build, and I’m currently tinkering around with previous Dolfinx tutorials to implement the usage of cross products to see how they work and how to use them for another program I’m working on. Currently I’m playing around with this older example for a mixed formulation of Poisson’s Equation which uses Dolfinx 0.7.1, and the code seems to work 1:1 between the two different Dolfinx versions. Upon retrieving the vector solution sigma_h by running
from ufl import (Measure, SpatialCoordinate, TestFunctions, TrialFunctions,
                 div, exp, inner, as_vector, cross, CellNormal, FacetNormal)
import pyvista as pv
domain = mesh.create_unit_square(MPI.COMM_WORLD, 32, 32, mesh.CellType.quadrilateral)
k = 1
Q_el = element("BDMCF", domain.basix_cell(), k)
P_el = element("DG", domain.basix_cell(), k - 1)
V_el = mixed_element([Q_el, P_el])
V = fem.functionspace(domain, V_el)
Ve = fem.functionspace(domain, ("Lagrange", k + 1))
(sigma, u) = TrialFunctions(V)
(tau, v) = TestFunctions(V)
x = SpatialCoordinate(domain)
f = 10.0 * exp(-((x[0] - 0.5) * (x[0] - 0.5) + (x[1] - 0.5) * (x[1] - 0.5)) / 0.02)
dx = Measure("dx", domain)
a = inner(sigma, tau) * dx + inner(u, div(tau)) * dx + inner(div(sigma), v) * dx
L = -inner(f, v) * dx
facets_top = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 1.0))
Q, _ = V.sub(0).collapse()
dofs_top = fem.locate_dofs_topological((V.sub(0), Q), fdim, facets_top)
def f1(x):
    values = np.zeros((2, x.shape[1]))
    values[1, :] = np.sin(5 * x[0])
    return values
f_h1 = fem.Function(Q)
f_h1.interpolate(f1)
bc_top = fem.dirichletbc(f_h1, dofs_top, V.sub(0))
facets_bottom = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 0.0))
dofs_bottom = fem.locate_dofs_topological((V.sub(0), Q), fdim, facets_bottom)
def f2(x):
    values[1, :] = -np.sin(5 * x[0])
    return values
f_h2 = fem.Function(Q)
f_h2.interpolate(f2)
bc_bottom = fem.dirichletbc(f_h2, dofs_bottom, V.sub(0))
bcs = [bc_top, bc_bottom]
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu",
                                                      'petsc_options_prefix': 'mixed_poisson',
                                                      "pc_factor_mat_solver_type": "mumps"},
                                                       petsc_options_prefix="mixed_poisson_",
                                                        kind="mpi")
w_h = problem.solve()
sigma_h, u_h = w_h.split()
I wanted to try creating and plotting \boldsymbol \sigma^\perp = \hat{\textbf{k}} \times \boldsymbol \sigma. The result should be the same as \boldsymbol \sigma^\perp = (-\boldsymbol \sigma_y,\boldsymbol\sigma_x) which I ran below for reference
# Cross product
sigma_v = as_vector(sigma_h)
k = CellNormal(domain) # normal vector
sigma_cross = cross(k,sigma_v) # k x sigma
sigma_cross_true = as_vector((-sigma_h[1],sigma_h[0])) # True result of cross product
# Plotting
W = fem.functionspace(domain, ("DG", 0, (domain.geometry.dim, )))
sigma_v = ufl.as_vector(sigma_h)
sigma_d = fem.Function(W)
expr_d = fem.Expression(sigma_cross_true,W.element.interpolation_points)
sigma_d.interpolate(expr_d)
u_d = fem.Function(W)
expr_d = fem.Expression(sigma_h,W.element.interpolation_points)
u_d.interpolate(expr_d)
num_dofs = W.dofmap.index_map.size_local
num_verts = W.mesh.topology.index_map(0).size_local
values_d = np.zeros((num_dofs, 3), dtype=np.float64)
values_d[:, :domain.geometry.dim] = sigma_d.x.array.real.reshape(num_dofs, W.dofmap.index_map_bs)
values = np.zeros((num_dofs, 3), dtype=np.float64)
values[:, :domain.geometry.dim] = u_d.x.array.real.reshape(num_dofs, W.dofmap.index_map_bs)
grid = pv.UnstructuredGrid(*plot.vtk_mesh(Ve))
grid["sigma"] = values_d
glyphs = grid.glyph(orient = "sigma", scale = "sigma", factor = 0.1)# tolerance=0.1)
grid.set_active_vectors("sigma")
grid["u"] = values
grid.set_active_scalars("u")
u_plotter = pv.Plotter()
u_plotter.add_mesh(grid,scalars="u",show_edges= False)
u_plotter.add_mesh(glyphs, cmap = 'bwr')#, clim = [np.min(grid["sigma"]),np.max(grid["sigma"])])
u_plotter.view_xy()
u_plotter.show()
which yields the following plot
However, this code fails to compile when attempting to create a Dolfinx expression of the cross product, hence running the following
expr_d = fem.Expression(sigma_cross,W.element.interpolation_points)
returns an error
ValueError                                Traceback (most recent call last)
Cell In[9], line 5
      3 sigma_v = ufl.as_vector(sigma_h)
      4 sigma_d = fem.Function(W)
----> 5 expr_d = fem.Expression(sigma_cross,W.element.interpolation_points)
      6 sigma_d.interpolate(expr_d)
      8 u_d = fem.Function(W)
File /usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/function.py:151, in Expression.__init__(self, e, X, comm, form_compiler_options, jit_options, dtype)
    149     form_compiler_options = dict()
    150 form_compiler_options["scalar_type"] = dtype
--> 151 self._ufcx_expression, module, self._code = jit.ffcx_jit(
    152     comm, (e, _X), form_compiler_options=form_compiler_options, jit_options=jit_options
    153 )
    154 self._ufl_expression = e
    156 # Prepare coefficients data. For every coefficient in expression
    157 # take its C++ object.
File /usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/jit.py:61, in mpi_jit_decorator.<locals>.mpi_jit(comm, *args, **kwargs)
     57 @functools.wraps(local_jit)
     58 def mpi_jit(comm, *args, **kwargs):
     59     # Just call JIT compiler when running in serial
     60     if comm.size == 1:
---> 61         return local_jit(*args, **kwargs)
     63     # Default status (0 == ok, 1 == fail)
     64     status = 0
File /usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/jit.py:218, in ffcx_jit(ufl_object, form_compiler_options, jit_options)
    216     r = ffcx.codegeneration.jit.compile_forms([ufl_object], options=p_ffcx, **p_jit)
    217 elif isinstance(ufl_object, tuple) and isinstance(ufl_object[0], ufl.core.expr.Expr):
--> 218     r = ffcx.codegeneration.jit.compile_expressions([ufl_object], options=p_ffcx, **p_jit)
    219 else:
    220     raise TypeError(type(ufl_object))
File /dolfinx-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py:306, in compile_expressions(expressions, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    304     except Exception:
    305         pass
--> 306     raise e
    308 obj, module = _load_objects(cache_dir, module_name, expr_names)
    309 return obj, module, (decl, impl)
File /dolfinx-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py:286, in compile_expressions(expressions, options, cache_dir, timeout, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    283     for name in expr_names:
    284         decl += expression_template.format(name=name)
--> 286     impl = _compile_objects(
    287         decl,
    288         expressions,
    289         expr_names,
    290         module_name,
    291         p,
    292         cache_dir,
    293         cffi_extra_compile_args,
    294         cffi_verbose,
    295         cffi_debug,
    296         cffi_libraries,
    297         visualise=visualise,
    298     )
    299 except Exception as e:
    300     try:
    301         # remove c file so that it will not timeout next time
File /dolfinx-env/lib/python3.12/site-packages/ffcx/codegeneration/jit.py:331, in _compile_objects(decl, ufl_objects, object_names, module_name, options, cache_dir, cffi_extra_compile_args, cffi_verbose, cffi_debug, cffi_libraries, visualise)
    327 libraries = _libraries + cffi_libraries if cffi_libraries is not None else _libraries
    329 # JIT uses module_name as prefix, which is needed to make names of all struct/function
    330 # unique across modules
--> 331 _, code_body = ffcx.compiler.compile_ufl_objects(
    332     ufl_objects, prefix=module_name, options=options, visualise=visualise
    333 )
    335 # Raise error immediately prior to compilation if no support for C99
    336 # _Complex. Doing this here allows FFCx to be used for complex codegen on
    337 # Windows.
    338 if sys.platform.startswith("win32"):
File /dolfinx-env/lib/python3.12/site-packages/ffcx/compiler.py:108, in compile_ufl_objects(ufl_objects, options, object_names, prefix, visualise)
    106 # Stage 1: analysis
    107 cpu_time = time()
--> 108 analysis = analyze_ufl_objects(ufl_objects, options["scalar_type"])  # type: ignore
    109 _print_timing(1, time() - cpu_time)
    111 # Stage 2: intermediate representation
File /dolfinx-env/lib/python3.12/site-packages/ffcx/analysis.py:103, in analyze_ufl_objects(ufl_objects, scalar_type)
    101 for original_expression, points in expressions:
    102     elements += ufl.algorithms.extract_elements(original_expression)
--> 103     processed_expression = _analyze_expression(original_expression, scalar_type)
    104     processed_expressions += [(processed_expression, points, original_expression)]
    106 elements += ufl.algorithms.analysis.extract_sub_elements(elements)
File /dolfinx-env/lib/python3.12/site-packages/ffcx/analysis.py:132, in _analyze_expression(expression, scalar_type)
    130 """Analyzes and preprocesses expressions."""
    131 preserve_geometry_types = (ufl.classes.Jacobian,)
--> 132 expression = ufl.algorithms.apply_algebra_lowering.apply_algebra_lowering(expression)
    133 expression = ufl.algorithms.apply_derivatives.apply_derivatives(expression)
    134 expression = ufl.algorithms.apply_function_pullbacks.apply_function_pullbacks(expression)
File /dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/apply_algebra_lowering.py:150, in apply_algebra_lowering(expr)
    148 def apply_algebra_lowering(expr):
    149     """Expands high level compound operators to equivalent representations using basic operators."""
--> 150     return map_integrand_dags(LowerCompoundAlgebra(), expr)
File /dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/map_integrands.py:86, in map_integrand_dags(function, form, only_integral_type, compress)
     84 def map_integrand_dags(function, form, only_integral_type=None, compress=True):
     85     """Map integrand dags."""
---> 86     return map_integrands(
     87         lambda expr: map_expr_dag(function, expr, compress), form, only_integral_type
     88     )
File /dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/map_integrands.py:79, in map_integrands(function, form, only_integral_type)
     77 elif isinstance(form, (Expr, BaseForm)):
     78     integrand = form
---> 79     return function(integrand)
     80 else:
     81     raise ValueError("Expecting Form, Integral or Expr.")
File /dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/map_integrands.py:87, in map_integrand_dags.<locals>.<lambda>(expr)
---> 87         lambda expr: map_expr_dag(function, expr, compress), form, only_integral_type
     88     )
File /dolfinx-env/lib/python3.12/site-packages/ufl/corealg/map_dag.py:35, in map_expr_dag(function, expression, compress, vcache, rcache)
     15 def map_expr_dag(function, expression, compress=True, vcache=None, rcache=None):
     16     """Apply a function to each subexpression node in an expression DAG.
     17
     18     If the same function is called multiple times in a transformation
   (...)     33         The result of the final function call
     34     """
---> 35     (result,) = map_expr_dags(
     36         function, [expression], compress=compress, vcache=vcache, rcache=rcache
     37     )
     38     return result
File /dolfinx-env/lib/python3.12/site-packages/ufl/corealg/map_dag.py:103, in map_expr_dags(function, expressions, compress, vcache, rcache)
    101     r = handlers[v._ufl_typecode_](v)
    102 else:
--> 103     r = handlers[v._ufl_typecode_](v, *(vcache[u] for u in v.ufl_operands))
    105 # Optionally check if r is in rcache, a memory optimization
    106 # to be able to keep representation of result compact
    107 if compress:
File /dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/apply_algebra_lowering.py:60, in LowerCompoundAlgebra.cross(self, o, a, b)
     57 def c(i, j):
     58     return Product(a[i], b[j]) - Product(a[j], b[i])
---> 60 return as_vector((c(1, 2), c(2, 0), c(0, 1)))
File /dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/apply_algebra_lowering.py:58, in LowerCompoundAlgebra.cross.<locals>.c(i, j)
     57 def c(i, j):
---> 58     return Product(a[i], b[j]) - Product(a[j], b[i])
File /dolfinx-env/lib/python3.12/site-packages/ufl/exproperators.py:383, in _getitem(self, component)
    380 shape = self.ufl_shape
    382 # Analyse slices (:) and Ellipsis (...)
--> 383 all_indices, slice_indices, repeated_indices = create_slice_indices(
    384     component, shape, self.ufl_free_indices
    385 )
    387 # Check that we have the right number of indices for a tensor with
    388 # this shape
    389 if len(shape) != len(all_indices):
File /dolfinx-env/lib/python3.12/site-packages/ufl/index_combination_utils.py:150, in create_slice_indices(component, shape, fi)
    148 elif isinstance(ind, int):
    149     if int(ind) >= shape[len(all_indices)]:
--> 150         raise ValueError("Index out of bounds.")
    151     all_indices.append(FixedIndex(ind))
    152 elif isinstance(ind, slice):
ValueError: Index out of bounds.
Not sure what Index out of bounds is supposed to mean in this context. Also, I receive this error whether I use CellNormal or FacetNormal to create my unit vector.
As far as I am aware ufl.cross is only defined in 3D , ref Why is 'fem.assemble_scalar(fem.form(ufl.cross(ufl_vec, sigma(u)*n)[1]*ds(ds_section)))' throwing "ValueError: Index out of bounds." - #4 by dokken
Ah! So my question would then need to become “how to take the cross product of a 2D vector using UFL?” Maybe there’s a way.
EDIT: Or wait, actually it looks like you did provide a workaround. I’ll take a look to see if that works, but understanding that limitation or intended use case helps greatly regardless.
Looks like the cross product between the normal vector to the mesh, and a 2D vector is handled with ufl.perp()
k = 1
def f1(x):
    return values
def f2(x):
    return values
                                                        kind="mpi")
sigma_cross = ufl.perp(sigma_v) #FIXED: Use ufl.perp() instead
fem.Expression(sigma_cross, W.element.interpolation_points)
grid["u"] = values
u_plotter.view_xy()
u_plotter.show()
Next, I need to determine if this works when setting up a Linear Problem in KSP or PETSc. Once I have that, I can feel more confident in how this is handled in the 2D case. The Shallow Water Equation in 2D like in the link might be a good one to test.
