Since I have a shape without a completly flat surface, I would like it to set to points where there is no material deformation. u =0
On the “core of the material”, example inside a ball arround the center of Radius R.
On a rectangular prism | z - z_0 | < tol
Is there a way to do this? Or do I need tools to “cut” my mesh and remove a part of it. Then, I’d have flat 2d boundary at can set u = 0 on them.
That’s because I’m applying external pressure on the material. But I don’t want it to move. It’s more about the local behavior.
dokken
January 3, 2025, 3:16pm
2
In DOLFINx, you can use locate_entities
and locate_dofs_topological
(or locate_dofs_geometrical) to set constraints on any degree of freedom given a spatial function.
A minimal working example follows:
import dolfinx.fem.function
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 50, 50, dolfinx.cpp.mesh.CellType.triangle)
def condition(x):
return np.logical_or(x[0]**2+x[1]**2 > 0.5, x[1] < 0.2)
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim)
entities = dolfinx.mesh.locate_entities(mesh, mesh.topology.dim, condition)
dofs = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim, entities)
u_bc = dolfinx.fem.Constant(mesh, 10.)
bc = dolfinx.fem.dirichletbc(u_bc, dofs, V)
uh = dolfinx.fem.Function(V)
bc.set(uh.x.array)
uh.x.scatter_forward()
with dolfinx.io.VTXWriter(mesh.comm, "output.bp", [uh]) as vtx:
vtx.write(0.0)
