Hi everyone,
I’m aiming to model an electric machine in which only the core material is considered nonlinear.
I have defined the reluctivity of the material as a function, which on some domains is a fixed value, and in other subdomains is defined by the material properties and the solution of the problem, which is hence nonlinear.
The reluctivity is defined by:
W = functionspace(mesh, ("DG", 1))
B_norm = Function(W)
B_expr = Expression(sqrt((Az.dx(1))**2 + (-Az.dx(0))**2),
W.element.interpolation_points())
B_norm.interpolate(B_expr)
for key in material_tags.keys():
out = self.geometry[key]
cells = self.domain_data.cell_tags.find(out["geom"]["tag"])
if hasattr(out["material"], "bh_curve"):
nu_mat = B_norm.x.array[cells] / (out["material"].get_H(B_norm.x.array[cells]) + 1e-12) # Avoid division by zero
nu.x.array[cells] = nu_mat
nu_mat = 1.0 / (out["material"].mu_0 * out["material"].mu_r)
nu.x.array[cells] = np.full_like(cells, nu_mat, dtype=default_scalar_type)
nu.x.scatter_forward()
Az is the magnetic vector potential which is the unknown variable that is solved for. and out[“material”].get_H(B) interpolates the given B on a lookup table to get the value for H.
As the machine geometry is reduced, it is a periodic problem so I’m using dolfinx_mpc and the nonlinear solver from: dolfinx_mpc/python/tests/test_nonlinear_assembly.py at v0.9.3 · jorgensd/dolfinx_mpc · GitHub
My question is, how should I modify the newton solver to update the reluctivity in between solving iterations?
