I would like to define initial conditions in preparation for a time dependent solve. In legacy fenics, this could be done via “y = interpolate(Constant((0.0, 1.0, 2.0)), ME)”. However, this does seem to work differently with the new dolfinx, since the following MWE results in a type error. Could you please advice what I have to change in order to make that work? Thank you.
from ufl import SpatialCoordinate, FiniteElement, MixedElement, TestFunctions, split
from dolfinx import mesh
from dolfinx.fem import FunctionSpace, Function, Constant
import numpy
msh = mesh.create_interval(MPI.COMM_WORLD, 10, points=(0, 1))
x = SpatialCoordinate(msh)
CG1_elem = FiniteElement("CG", msh.ufl_cell(), 1)
ME_elem = MixedElement([CG1_elem, CG1_elem, CG1_elem])
ME = FunctionSpace(msh, ME_elem)
u_test, v_test, w_test = TestFunctions(ME)
y = Function(ME)
y.interpolate(Constant(msh, (0.0, 1.0, 2.0)), ME)
u, v, w = split(y)
Hello nate,
thank you for the examples. I am now able to use interpolation on a simple finite element function space. However, when I try to use the same concept on a mixed element function space, I get the following error: “Cannot get interpolation points - no Basix element available. Maybe this is a mixed element?” Here is the corresponding MWE.
import numpy
def y_init(x):
values = numpy.zeros((2, x.shape[1]))
values[0] = 1.0
values[1] = 2.0
return values
ME_elem = MixedElement([CG1_elem, CG1_elem])
y = Function(ME)
y.interpolate(y_init)
