How to define product of dirac delta functions as initial condition
HI ,
I am solving heat equation u_t - u_xx -u_yy = 0 , with u(x,y, 0) = \delta(x)\delta(y), u = 0 on boundary
I tried this code and when I plot the solution I am getting flat surface but i think there should be peak in the solution.
from mpl_toolkits.mplot3d import Axes3D
nx = 64
# Define the mesh and function space
mesh = RectangleMesh(Point(-10, -20), Point(20, 30), nx, nx)
# Define the initial condition u(x,y,0) = Ξ΄(x)Ξ΄(y)
class Delta(UserExpression):
    def __init__(self, **kwargs):
        super().__init__(**kwargs)
    def eval(self, values, x):
        values[0] = 1.0 if abs(x[0]) < 1e-12 and abs(x[1]) < 1e-12 else 0.0
u0 = interpolate(Expression('0.0', degree=1), V)
# Define the boundary condition
def boundary(x, on_boundary):
    return on_boundary
bc = DirichletBC(V, Constant(0.0), boundary)
# Define the variational problem
f = Constant(0.0)
t = 0.0
T = 1.0
dt = 0.01
a = u*v*dx + dt*inner(grad(u), grad(v))*dx
L = u0*v*dx
# Time-stepping loop
while t < T:
    solve(a == L, u, bc)
    u0.assign(u)
#plot comupted solution
# Define a 3D plot
fig = plt.figure()
ax = fig.gca(projection='3d')
# Extract the coordinates and values of the FEM solution
X = mesh.coordinates()[:, 0]
Y = mesh.coordinates()[:, 1]
Z = u.vector()[:]
# Plot the solution as a surface
ax.plot_trisurf(X, Y, Z, cmap=plt.cm.jet)
# Set the axis labels and title
ax.set_xlabel('x')
ax.set_ylabel('y')
ax.set_zlabel('u')
# Show the plot
That initial condition will not work if you do not have a degree if freedom at (0,0), which you do not have with your mesh
Sorry, I didn’t get the idea of what you want to say. Can you please explain with an example or provide me any reference? It will be helpful for me.
The degrees of freedom has physical coordinates, which you can get through
print(V.tabulate_dof_coordinates)
these are the coordinates sent into
(which you dont call anywhere in your code btw.)
If none of these coordinates are close to (0,0), then you will only get zero values in your initial function (say if you called)
u0 = interpolate(Delta(), V)
Thus you need to make sure your discretization aligns with your point source if you want to use it as an initial condition.
If you don’t want alignment, you need to project Delta into V (but you face the same issue if none of the quadrature points align with the point source).
Alternatively, you can used a smooth approximation of the point source, see: Implement point source in the variational formulation - #2 by MiroK
I am trying to code a solution for the groundwater pollution model using the FEniCs as given in the paper titled Alternating approaches for groundwater pollution. https://reader.elsevier.com/reader/sd/pii/S2405896315001500?token=971FB3A154F7774257B3FE02E4BC701DA61B47C17ACC23B6F98B9D989ADD185DD73FF6BB2B4B39792471273BB9246755&originRegion=eu-west-1&originCreation=20230418173647
I got the idea that you have explained earlier. Now I have defined the Dirac distribution as the limit of Gauss function, now I am getting the peak in the solution, but I am not sure if I am doing right or not because in defining the initial condition I have considered only one variable x but there should be one more variable y.
The code is given as:
β€œβ€"
from fenics import*
nx = 64
V = FunctionSpace(mesh, β€˜P’, 1)
Define the Gaussian function G(x) FOR APPROXIMATION OF dIRAC DELTA FUNCTION
def G(x, v1=0.02, D=0.02, sigma=0.025):
return 1/(4piD*sigma)*np.exp(-((x - v1)**2) / (4 D sigma))
Define the initial condition u(x,y,0) = G(x)G(y)
class InitialCondition(UserExpression):
def init(self, **kwargs):
super().init(**kwargs)
values[0] = G(x[0]) * G(x[1])
u0 = interpolate(InitialCondition(degree=1), V)
return on_boundary
f = Constant(0.0)
v1 = Constant(0.02)
v2 = 0
e1 = as_vector([v1,v2])
D = Constant(0.02)
t = 0.0
T = 250
dt = 0.025
a = uvdx + dtDinner(grad(u), grad(v))dx + dot(e1, grad(u))vdx
L = u0
v*dx
Time-stepping loop
while t < T:
u0.assign(u)
import pylab as plt
Q = plot(u)
plt.xlabel(β€˜x’)
plt.ylabel(β€˜y’)
plt.title(β€˜t={}’.format(t))
plt.set_cmap(β€˜jet’)
plt.colorbar(Q)
Define a 3D plot
Z = u.vector()[:]
fig = plt.figure()
ax = fig.gca(projection=β€˜3d’)
ax.set_xlabel(β€˜x’)
ax.set_ylabel(β€˜y’)
ax.set_zlabel(β€˜u’)
Show the plot
β€œβ€β€œβ€
Gentle reminder, I am stuck on this point.
First of all, you need to format your code with 3x` encapsulation, i.e.
```python
# add code here
Secondly, you can verify your initial condition by plotting u0. I.e. either use plot(u0) or File("u0.pvd") << u0 and visualize it in paraview.
nx = 64
# Define the Gaussian function G(x) FOR APPROXIMATION OF dIRAC DELTA FUNCTION
    return 1/(4*pi*D*sigma)*np.exp(-((x - v1)**2) / (4 *D* sigma))
# Define the initial condition u(x,y,0) = G(x)G(y)
    return on_boundary
f = Constant(0.0)
v1 = Constant(0.02)
v2 = 0
D = Constant(0.02)
t = 0.0
T = 250
dt = 0.025
a = u*v*dx + dt*D*inner(grad(u), grad(v))*dx + dot(e1, grad(u))*v*dx
L = u0*v*dx
while t < T:
    u0.assign(u)
import pylab as plt
Q = plot(u)
plt.xlabel('x')
plt.ylabel('y')
plt.title('t={}'.format(t))
plt.set_cmap('jet')
plt.colorbar(Q)
# Define a 3D plot
Z = u.vector()[:]
fig = plt.figure()
ax.set_xlabel('x')
ax.set_ylabel('y')
ax.set_zlabel('u')
# Show the plot
Is there a question in this post?
It seems like your scaling of the delta function is wrong
Thank you for your help. I got the results.
