How to determine gauss point coordinates in a mesh
Hello fenics users,
I need to o determine gauss points coordinates of a mesh.
I’m a new fenics user, can any one helps me.
I will be grateful
Jihed ZGHAL
Maybe your are looking for this: How to get quadrature points and their weights? - #2 by bhaveshshrimali ?
Thank you for your quick reply. This exactly what I’m looking for. Based on the referred example I think that I can’t solve my problem.
I will explain more precisely my need: I generate this mesh as follow and I want to get the quadrature points :
print ( “Mesh Generation …” )
Structure dimension [mm]
L = 50
W = 10
Mesh size [mm]
h = 1
Nx = int( L/h ); print (" - number of element trough x direction = “, Nx);
Ny = int( W/h ); print (” - number of element trough y direction = ", Ny);
mesh = RectangleMesh(Point(-1*L, 0.), Point(L, W), Nx, Ny)
V = FunctionSpace(mesh, “CG”, 1)
Thank you for your help.
Do you want the physical quadrature points for each cell in your function space? These are automatically generated in ffc in fenics.
If you want to access them you could create a quadrature function space and tabulate the dof coordinates:
mesh = UnitSquareMesh(1, 1)
el = FiniteElement("Quadrature", mesh.ufl_cell(),  degree=2, quad_scheme="default")
V = FunctionSpace(mesh, el)
print(V.tabulate_dof_coordinates())
returning
[[ 0.83333333  0.66666667]
 [ 0.33333333  0.16666667]
 [ 0.83333333  0.16666667]
 [ 0.66666667  0.83333333]
 [ 0.16666667  0.33333333]
 [ 0.16666667  0.83333333]]
thank you it’s exactly what I need.
