How to extract values in a surface of 3D mesh to another 2D mesh?
Thank you for viewing my question.
I’m trying to extract interpolated values in a surface of 3D mesh to another 2D mesh with same surface area, but I have no idea how to achieve this. Following is a simple example:
#define mesh
mesh1=UnitSquareMesh(10,10)
mesh2=UnitCubeMesh(10,10,10)
#define FunctionSpace
V1=FunctionSpace(mesh1,'CG',1)
V2=FunctionSpace(mesh2,'CG',1)
#define u1 and u2
u1=interpolate(Constant(0),V1)
u2_ex=Expression('x[0]+x[1]+x[2]',degree=1)
u2=interpolate(u2_ex,V2)
#define SubDomain
class Surface1(SubDomain):
        return x[0]<0.5 and x[1]<0.5
class Surface2(SubDomain):
        return x[0]<0.5 and x[1]<0.5 and x[2]>1-DOLFIN_EPS
surface1=Surface1()
surface2=Surface2()
# next to do what to extract u2 values in the SubDomain surface2 of V2 to
# u1 for the SubDomain surface1 of V1?
I would suggest having a look at: Project creates different results - #18 by dokken
Hi, dokken. Thanks for replying. But I’m still confused about extrating values in a certain facet after carefully reading the topic you suggested. Is there another typical example you can suggest for me? And also, where can I find the «parts of domain» you refered in that topic?
What I am suggesting is to use a restricted measure, i.e.
ds = Measure("ds", domain=mesh1, subdomain_data=meshfunction_2D, subdomain_id=surface_id)
see for instance: Poisson equation with multiple subdomains — DOLFIN documentation for more info regarding subdomains.
Then you can simply do a restricted projection.
u, v = TrialFunction(V1), TestFunction(V1)
a = inner(u, v)*ds
A = assemble(a)
l = inner(u2, v)*ds
b = assemble(b)
A.ident_zeros()
u_2D = Function(V1)
solve(A, u_2D.vector(), b)
