How to further speed up the calculation in doflinx?
I am trying to run the default tutorial The equations of linear elasticity — FEniCS-X tutorial in the docker container, and want to test the computational time of the solver by using the time package.
start_time = time.time()
problem = dolfinx.fem.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
print('Time = %.3f (s)' %(time.time()-start_time))
I run this code by using the command:
mpirun --allow-run-as-root -n 2 python3 Demo_LinearElasticity.py
However, the computational time increases with the number of processors. And it seems the OS just run the same code for many times instead of using the parallel computation. I think dolfinx should have a faster speed and maybe I ran it in an inproper way.
root@08637eaf5b16:/shared# mpirun --allow-run-as-root -n 2 python3 Demo_LinearElasticity.py
Time = 0.383 (s)
Time = 0.383 (s)
root@08637eaf5b16:/shared# mpirun --allow-run-as-root -n 4 python3 Demo_LinearElasticity.py
Time = 0.397 (s)
Time = 0.402 (s)
Time = 0.433 (s)
Time = 0.453 (s)
root@08637eaf5b16:/shared# mpirun --allow-run-as-root -n 8 python3 Demo_LinearElasticity.py
Time = 0.536 (s)
Time = 0.534 (s)
Time = 0.530 (s)
Time = 0.528 (s)
Time = 0.531 (s)
Time = 0.554 (s)
Time = 0.544 (s)
Time = 0.553 (s)
I cannot reproduce your issue with a docker container (dolfinx/dolfinx) with the following script:
L = 1
W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lambda_ = beta
g = gamma
from dolfinx.cpp.mesh import CellType
import time
mesh = dolfinx.BoxMesh(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])], [20,6,6], cell_type=CellType.hexahedron)
V = dolfinx.VectorFunctionSpace(mesh, ("CG", 1))
def clamped_boundary(x):
    return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = dolfinx.Function(V)
with u_D.vector.localForm() as loc:
    loc.set(0)
bc = dolfinx.DirichletBC(u_D, dolfinx.fem.locate_dofs_topological(V, fdim, boundary_facets))
T = dolfinx.Constant(mesh, (0, 0, 0))
ds = ufl.Measure("ds", domain=mesh)
    return ufl.sym(ufl.grad(u)) # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
    return lambda_ * ufl.nabla_div(u) * ufl.Identity(u.geometric_dimension()) + 2*mu*epsilon(u)
u = ufl.TrialFunction(V)
f = dolfinx.Constant(mesh, (0, 0, -rho*g))
start = time.time()
end = time.time()
print(f'{MPI.COMM_WORLD.rank}: Time = {end-start:.3f} (s)')
and output:
root@feb3f65a1cf3:/home/shared# mpirun -n 1 python3 linearelasticity_code.py
0: Time = 0.315 (s)
root@feb3f65a1cf3:/home/shared# mpirun -n 2 python3 linearelasticity_code.py
0: Time = 0.115 (s)
1: Time = 0.115 (s)
root@feb3f65a1cf3:/home/shared# mpirun -n 3 python3 linearelasticity_code.py
0: Time = 0.094 (s)
1: Time = 0.094 (s)
2: Time = 0.094 (s)
root@feb3f65a1cf3:/home/shared# mpirun -n 4 python3 linearelasticity_code.py
0: Time = 0.081 (s)
1: Time = 0.081 (s)
2: Time = 0.081 (s)
3: Time = 0.081 (s)
root@feb3f65a1cf3:/home/shared# mpirun -n 8 python3 linearelasticity_code.py
0: Time = 0.060 (s)
1: Time = 0.060 (s)
2: Time = 0.060 (s)
3: Time = 0.060 (s)
4: Time = 0.060 (s)
5: Time = 0.060 (s)
6: Time = 0.060 (s)
7: Time = 0.060 (s)
Thanks, Dokken. I delete my old container and rerun a new one, now it works. But my improvement (from 0.36s to 0.14s) is not as obvious as yours (from 0.3s to 0.06s), maybe it is due to the difference of computers.
Im using a desktop computer with 64 GB ram and 16 processes. For further speedups, I would suggest changing from a direct to an iterative solver (especially if you increase the number of dofs)
I seem to be having the same problem with the same example. I am running fenicsx 0.9.0 under anaconda 3. The operating system is ubuntu 24.04 and the desktop computer has 16 cores and 32Gb of RAM.
In order to mimc the previous posts I created the following minimal code (cut down from linearelasticity_code.py and appropriate for version 0.9.0):
from dolfinx import mesh, fem, default_scalar_type
import time
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
gamma = 0.4 * delta**2
beta = 1.25
lambda_ = beta
g = gamma
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
                         [20, 6, 6], cell_type=mesh.CellType.hexahedron)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
def sigma(u):
f = fem.Constant(domain, default_scalar_type((0, 0, -rho * g)))
end_time = time.time()
print('Time = %.5f (s)' %(end_time-start_time))
My results are as follows:
(fenicsx-env) peter:fenicsx % mpirun -n 1 python lin_elas.py
Time = 0.18598 (s)
(fenicsx-env) peter:fenicsx % mpirun -n 2 python lin_elas.py
Time = 0.21867 (s)
Time = 0.21867 (s)
(fenicsx-env) peter:fenicsx % mpirun -n 4 python lin_elas.py
Time = 0.34490 (s)
Time = 0.34489 (s)
Time = 0.34490 (s)
Time = 0.34489 (s)
(fenicsx-env) peter:fenicsx % mpirun -n 8 python lin_elas.py
Time = 0.51458 (s)
Time = 0.51459 (s)
Time = 0.51552 (s)
Time = 0.51552 (s)
Time = 0.51551 (s)
Time = 0.51550 (s)
Time = 0.51551 (s)
Time = 0.51552 (s)
I assume that I must have missed something somewhere. I did run the program in a new window with a fresh start of conda. The only thing I haven’t tried is a reboot of the computer.
Any thoughts would be much appreciated.
Thank you,
Peter.
One thing you should add to the options are:
to ensure that you use the same solver in serial and parallel.
Secondly, your problem is very small. Ramping up the size of it:
import time
L = 1
W = 0.2
mu = 1
rho = 1
delta = W / L
beta = 1.25
lambda_ = beta
g = gamma
M = 40
N = 12
    MPI.COMM_WORLD,
    [M, N, N],
    cell_type=mesh.CellType.hexahedron,
V = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
    return ufl.sym(
        ufl.grad(u)
def sigma(u):
    a,
    L,
    bcs=[bc],
    petsc_options={
        "pc_type": "lu",
start_time = time.perf_counter()
end_time = time.perf_counter()
num_dofs_global = V.dofmap.index_map.size_global * V.dofmap.index_map_bs
print(f"{num_dofs_global=} Time = {end_time - start_time:.5f} (s)")
you get:
root@dokken-XPS-9320:~/shared# python3 mwe.py
num_dofs_global=20787 Time = 0.56405 (s)
root@dokken-XPS-9320:~/shared# mpirun -n 2 python3 mwe.py
num_dofs_global=20787 Time = 0.44247 (s)
root@dokken-XPS-9320:~/shared# mpirun -n 4 python3 mwe.py
num_dofs_global=20787 Time = 0.37886 (s)
further increasing the size of the problem, to
M = 80
N = 24
I get
num_dofs_global=151875 Time = 14.51238 (s)
num_dofs_global=151875 Time = 9.24733 (s)
num_dofs_global=151875 Time = 11.76198 (s)
num_dofs_global=151875 Time = 11.76197 (s)
where you see that with even 152 000 dofs, using 4 processes isn’t speeding up the code.
This is quite common with HPC/MPI finite element code. There is a quite large threshold for when one actually needs to use MPI parallelism.
