Dear all,
I want to have multiple subdomains based on each cell. For example, I have 100 cells in my mesh, then I need to have 100 subdomains, in order to do the integration around each cell. I know this can be done by a For loop. However, when there are thousands of cells, it will take a lot of time to do the for loop at every time step. The code attached below is my thought to do that, but it fails.
- Can anyone help me with this problem?
- Or if you have a better idea to do the integration around each point, please let me know?
- Is there a way to find the index of points during “interpolate”?
Thanks a lot for your time and help!
from dolfinx import fem, io, mesh, plot, common, geometry
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (1, 1)), n=(10, 10),
cell_type=mesh.CellType.quadrilateral)
V = fem.FunctionSpace(msh, ("CG", 1))
Q = fem.FunctionSpace(msh, ("DG", 0))
P = fem.Function(Q)
T = fem.Function(V)
T.interpolate(lambda x: x[0] + 2 * x[1])
R = 0.02
def f_(x):
a = np.array(x[0])
b = np.array(x[1])
subcells = mesh.locate_entities(msh, msh.topology.dim, lambda y: np.sqrt((y[0]-a)**2 + (y[1]-b)**2) <= R)
subdm = mesh.meshtags(msh, msh.topology.dim, subcells, np.array([point_index], dtype = np.int32))
#here the point_index should be the index of each point and the length should be equal to subcells
dx_subdm = ufl.Measure("dx", subdomain_data = subdm)
return fem.assemble_scalar(fem.form(T * dx_subdm(point_index)))
P.interpolate(f_)
print(P.x.array)
