How to get the solution value at the boundary or any give points?
Hello everyone. I am solving a set of coupled 1d-PDEs,
\begin{cases} \frac{\partial c_1}{\partial t} &= \frac{\partial}{\partial x}f_1(c_1,c_2,...,\partial c_1/\partial x, \partial c_2/\partial x,...) \\ \frac{\partial c_2}{\partial t} &= \frac{\partial}{\partial x}f_2(c_1,c_2,...,\partial c_1/\partial x, \partial c_2/\partial x,...) \end{cases}
the left boundary is the flux \vec{f}(c_1, c_2, ...), it’s a numerical function, so I can’t write it in the variational form. How can I get the \{c_i\} and \{\partial c_i/\partial x\} at the left boundary? A more general question is, how can I get them at arbitrary points on the domain?
I find a topic in Calculate the value of a solution on mesh points or in any point - General - FEniCS Project
But it does not works. The error occurs at
bb_tree = geometry.BoundingBoxTree(mesh, mesh.topology.dim)
python3 test_eval.py
  File "/mnt/g/workdir/MKM/NO_mkm/test_eval.py", line 46, in <module>
TypeError: BoundingBoxTree.__init__() takes 2 positional arguments but 3 were given
And I don’t understand these codes at all because the lack of comments. For example, the functions such as
exterior_facet_indices
tabulate_dof_coordinates
compute_collisions
compute_colliding_cells
There is a test case, a vector-valued problem on (0, 1)
\begin{cases} \frac{\partial u_1}{\partial t} &= \frac{\partial^2 u_1}{\partial x^2} - \exp(u_1 - u_2) + \exp(-(u_1 - u_2)) \\ \frac{\partial u_2}{\partial t} &= \frac{\partial^2 u_2}{\partial x^2} + \exp(u_1 - u_2) - \exp(-(u_1 - u_2)) \\ \end{cases}
the boundary condition is
\begin{cases} \frac{\partial u_1}{\partial x}(0, t) &= \sin(u_1(x = 0)) \\ \frac{\partial u_2}{\partial x}(0, t) &= -0.1u_1(x=0)u_2(x=0) \end{cases} \quad \begin{cases} u_1(1, t) = 1 \\ u_2(1, t) = 0 \end{cases}
# -*- coding:utf-8 -*-
t_ini = 0
t_fin = 1.1
n_step = 11
dt = (t_fin - t_ini) / n_step
nx = 64
L = 1.0
rank = MPI.COMM_WORLD.Get_rank()
domain = dolfinx.mesh.create_interval(MPI.COMM_WORLD, nx, points=(0.0, L))
V = dolfinx.fem.FunctionSpace(domain, ufl.VectorElement("Lagrange", domain.ufl_cell(), 1, dim=2))
boundary_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(L, x[0]))
bc1 = dolfinx.fem.dirichletbc(PETSc.ScalarType(1.0),
                              dolfinx.fem.locate_dofs_topological(V.sub(0), fdim, boundary_facets),
                              V.sub(0))
bc2 = dolfinx.fem.dirichletbc(PETSc.ScalarType(0.0),
                              dolfinx.fem.locate_dofs_topological(V.sub(1), fdim, boundary_facets),
                              V.sub(1))
u_n = dolfinx.fem.Function(V)
u = dolfinx.fem.Function(V)
u_n1, u_n2 = ufl.split(u_n)
u1, u2 = ufl.split(u)
u_n.sub(0).interpolate(lambda x: np.ones(x[0].shape))
u_n.sub(1).interpolate(lambda x: np.zeros(x[0].shape))
u_n.x.scatter_forward()
v1, v2 = ufl.TestFunction(V)
G = -ufl.exp(u1-u2)+ufl.exp(-(u1-u2))
F1 = u1*v1*ufl.dx + dt*ufl.dot(ufl.grad(u1), ufl.grad(v1))*ufl.dx + dt*ufl.sin(u1)*v1*ufl.ds - dt*G*v1*ufl.dx - u_n1*v1*ufl.dx
F2 = u2*v2*ufl.dx + dt*ufl.dot(ufl.grad(u2), ufl.grad(v2))*ufl.dx + dt*(-0.1*u1*u2)*v2*ufl.ds + dt*G*v2*ufl.dx - u_n2*v2*ufl.dx
F = F1 + F2
problem = NonlinearProblem(F, u, bcs=[bc1, bc2])
solver.convergence_criterion = "residual"
solver.rtol = 1e-6
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
file = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "diffu_test3/u_tot.xdmf", "w")
file.write_mesh(domain)
t = t_ini
while t < t_fin:
    n, converged = solver.solve(u)
    if (rank == 0):
    u_n.x.array[:] = u.x.array
    file.write_function(u, t)
file.close()
See
https://jsdokken.com/dolfinx-tutorial/chapter1/membrane_code.html#making-curve-plots-throughout-the-domain
for updated syntax regarding boundingboxes
Here is a working example which evaluate the solution at the left boundary (0.0, 0.0, 0.0) and broad cast the value to all the process.
cells = []
points_on_proc = []
bb_tree = dolfinx.geometry.bb_tree(domain, domain.topology.dim)
points = np.array([[0.0, 0.0, 0.0]])
cell_candidates = dolfinx.geometry.compute_collisions_points(bb_tree, points)
colliding_cells = dolfinx.geometry.compute_colliding_cells(domain, cell_candidates, points)
for i, point in enumerate(points):
        points_on_proc.append(point)
points_on_proc = np.array(points_on_proc, dtype=np.float64)
non_empty_process = MPI.COMM_WORLD.gather(len(points_on_proc), root=0)
if rank == 0:
    root_rank = np.argmax(non_empty_process)
    root_rank = None
root_rank = MPI.COMM_WORLD.bcast(root_rank, root=0)
t = t_ini
while t < t_fin:
    u_values = u.eval(points_on_proc, cells)
    u_values = MPI.COMM_WORLD.bcast(u_values, root=root_rank)
    print("rank = ", rank, "u_values = ", u_values)
Thanks for your answer, my problem is solved.
