Hi everyone,
I am able to implement Dirichlet boundary conditions for coupled PDEs from the tutorial : https://fenicsproject.org/pub/tutorial/html/._ftut1010.html
However, the tutorial assumes homogeneous Neumann boundary conditions however for my couple expression:
I have input flux for the first equation and zero flux for the second expression. I’m not sure if my variational expression applies a flux to both u1 and u2:
#Define Boundary Conditions
Flux = Expression("t<30+1e-9 ? ((k1*A1)/Z_w)*exp(-1*k1*t) : 0", degree=2, k1=k1, A1=A1, Z_w=Z_w, t=0)
u1_D = Constant(0)
boundaryconditions = {
1 : {"Neumann" : Flux},
2 : {"Dirichlet" : u1_D}
ds = Measure('ds', domain=mesh, subdomain_data=mf)
bcs = []
for i in boundaryconditions:
if "Dirichlet" in boundaryconditions[i]:
# bc = DirichletBC(V, boundaryconditions[i]["Dirichlet"], boundaries, i)
bc = DirichletBC(V.sub(0), boundaryconditions[i]["Dirichlet"], boundaries, i) # Dirichlet is appied only to 1 subspace
bcs.append(bc)
integrals_N = []
if "Neumann" in boundaryconditions[i]:
if boundaryconditions[i]["Neumann"] != 0: #if not zero flux
g = boundaryconditions[i]["Neumann"]
integrals_N.append(v1*g*ds(i))
#Define Variational Problem
F = (((u1-u_n1 + u2-u_n2)*v1)/dt)*dx + D_T*dot(grad(u1),grad(v1))*dx + (((u2-u_n2)*v2)/dt)*dx - dt*sum(integrals_N) \
- v2*ka*u1*B_M*dx + ka*B_M*v2*u2*dx - kd*v2*u2*dx
This does not generate any error but the flux seems to be implemented to both u1 and u2.
Is this the right way to implement flux for just u1 and not u2?
Any help/advice will be greatly appreciated
Thanks
