How to import mixed triangle and quad meshes from gmsh to fenics
There is no Mixed element support in fenics. The aim is to support this in the future in dolfinx.
Note that the support for quarilateral/hexahedral elements in dolfin is quite limited, and i strongly advice you to move to dolfinx if you require such elements.
Using the following arguments in gmsh will force all cells to be quadrilateral:
Recombine Surface {:};
Mesh.RecombinationAlgorithm = 2;
