Thank you for your suggestion!I haven’t tried the method you gave, but solved the problem by doing the following:
u_bc = dolfinx.fem.Function(V)
disp_bc_partial = partial(disp_bc, node_i=5, l=1)
u_bc.sub(0).interpolate(disp_bc_partial) # This is my function expression of BC
x_bc = dolfinx.fem.dirichletbc(value=u_bc.sub(0),
dofs=dolfinx.fem.locate_dofs_topological(V.sub(0), fdim, all_fs))
It works well. But I still have some confussion that when I add the Parameter V of dolfinx.fem.dirichletbc. Like:
dofs=dolfinx.fem.locate_dofs_topological(V.sub(0), fdim, all_fs), V=V.sub(0))
It will output errors like:
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/bcs.py", line 175, in dirichletbc
bc = bctype(_value, dofs, V)
TypeError: __init__(): incompatible constructor arguments. The following argument types are supported:
1. dolfinx.cpp.fem.DirichletBC_float64(g: numpy.ndarray[numpy.float64], dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace<double>)
2. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Constant<double>, dofs: numpy.ndarray[numpy.int32], V: dolfinx::fem::FunctionSpace<double>)
3. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double, double>, dofs: numpy.ndarray[numpy.int32])
4. dolfinx.cpp.fem.DirichletBC_float64(g: dolfinx::fem::Function<double, double>, dofs: List[numpy.ndarray[numpy.int32][2]], V: dolfinx::fem::FunctionSpace<double>)
Invoked with: <dolfinx.cpp.fem.Function_float64 object at 0x7fc0f120c030>, array([ 0, 3, 6, 9, 12, 15, 18, 24, 27, 30, 36,
39, 42, 48, 51, 54, 60, 63, 66, 72, 78, 84,
87, 90, 96, 102, 105, 108, 114, 117, 120, 126, 132,
138, 147, 153, 156, 159, 165, 171, 177, 180, 183, 189,
192, 195, 201, 207, 213, 222, 228, 240, 246, 249, 252,
258, 264, 270, 276, 279, 282, 288, 291, 294, 300, 306,
312, 321, 327, 339, 345, 360, 366, 369, 372, 378, 384,
390, 396, 402, 405, 408, 414, 417, 420, 426, 432, 438,
447, 453, 465, 471, 486, 492, 510, 516, 519, 522, 528,
534, 540, 546, 552, 558, 561, 564, 570, 573, 576, 582,
588, 594, 603, 609, 621, 627, 642, 648, 666, 672, 693,
699, 702, 705, 711, 717, 723, 729, 735, 741, 747, 750,
753, 759, 762, 765, 771, 777, 783, 792, 798, 810, 816,
831, 837, 855, 861, 882, 888, 912, 918, 921, 924, 930,
936, 942, 948, 954, 960, 966, 972, 975, 978, 984, 987,
990, 993, 996, 1002, 1008, 1017, 1023, 1035, 1041, 1056, 1062,
1080, 1086, 1107, 1113, 1137, 1143, 1170, 1176, 1179, 1182, 1185,
1188, 1194, 1200, 1206, 1212, 1218, 1224, 1230, 1236, 1239, 1242,
1245, 1248, 1251, 1254, 1257, 1260, 1269, 1275, 1287, 1293, 1308,
1314, 1332, 1338, 1359, 1365, 1389, 1395, 1422, 1428, 1431, 1458,
1461, 1464, 1467, 1470, 1476, 1482, 1488, 1494, 1500, 1506, 1512,
1515, 1518, 1521, 1524, 1527, 1530, 1533, 1545, 1551, 1566, 1572,
1590, 1596, 1617, 1623, 1647, 1653, 1680, 1686, 1689, 1716, 1719,
1722, 1746, 1749, 1752, 1755, 1761, 1767, 1773, 1779, 1785, 1791,
1794, 1797, 1800, 1803, 1806, 1809, 1812, 1815, 1830, 1836, 1854,
1860, 1881, 1887, 1911, 1917, 1944, 1950, 1953, 1980, 1983, 1986,
2010, 2013, 2034, 2037, 2040, 2043, 2049, 2055, 2061, 2067, 2073,
2076, 2079, 2082, 2085, 2088, 2091, 2094, 2097, 2100, 2118, 2124,
2145, 2151, 2175, 2181, 2208, 2214, 2217, 2244, 2247, 2250, 2274,
2277, 2298, 2301, 2319, 2322, 2325, 2328, 2334, 2340, 2346, 2352,
2355, 2358, 2361, 2364, 2367, 2370, 2373, 2376, 2379, 2382, 2403,
2409, 2433, 2439, 2466, 2472, 2475, 2502, 2505, 2508, 2532, 2535,
2556, 2559, 2577, 2580, 2595, 2598, 2601, 2604, 2610, 2616, 2622,
2625, 2628, 2631, 2634, 2637, 2640, 2643, 2646, 2649, 2652, 2655,
2679, 2685, 2712, 2718, 2721, 2748, 2751, 2754, 2778, 2781, 2802,
2805, 2823, 2826, 2841, 2844, 2856, 2859, 2862, 2865, 2871, 2877,
2880, 2883, 2886, 2889, 2892, 2895, 2898, 2901, 2904, 2907, 2910,
2913, 2940, 2946, 2949, 2976, 2979, 2982, 3006, 3009, 3030, 3033,
3051, 3054, 3069, 3072, 3084, 3087, 3096, 3099, 3102, 3105, 3111,
3114, 3117, 3120, 3123, 3126, 3129, 3132, 3135, 3138, 3141, 3144,
3147, 3150, 3153, 3180, 3183, 3186, 3210, 3213, 3234, 3237, 3255,
3258, 3273, 3276, 3288, 3291, 3300, 3303, 3309, 3312, 3315, 3318,
3321, 3324, 3327, 3330, 3333, 3336, 3339, 3342, 3345, 3348, 3351,
3354, 3357, 3360, 3384, 3387, 3408, 3411, 3429, 3432, 3447, 3450,
3462, 3465, 3474, 3477, 3483, 3486, 3489, 3492, 3495, 3498, 3501,
3504, 3507, 3510, 3513, 3516, 3519, 3522, 3525, 3546, 3549, 3567,
3570, 3585, 3588, 3600, 3603, 3612, 3615, 3621, 3624, 3627, 3630,
3633, 3636, 3639, 3642, 3645, 3648, 3651, 3654, 3657, 3675, 3678,
3693, 3696, 3708, 3711, 3720, 3723, 3729, 3732, 3735, 3738, 3741,
3744, 3747, 3750, 3753, 3756, 3759, 3762, 3777, 3780, 3792, 3795,
3804, 3807, 3813, 3816, 3819, 3822, 3825, 3828, 3831, 3834, 3837,
3840, 3843, 3855, 3858, 3867, 3870, 3876, 3879, 3882, 3885, 3888,
3891, 3894, 3897, 3900, 3903, 3912, 3915, 3921, 3924, 3927, 3930,
3933, 3936, 3939, 3942, 3945, 3951, 3954, 3957, 3960, 3963, 3966,
3969, 3972, 3975, 3978, 3981, 3984, 3987, 3990], dtype=int32), FunctionSpace(Mesh(blocked element (Basix element (P, hexahedron, 1, gll_warped, unset, False), (3,)), 0), FiniteElement('Q', hexahedron, 1))
File "/mnt/d/BaiduNetdiskWorkspace/MultiscaleDynamicTOP/code/FEniCSBasedProject/3D_test/Unit_cubic.py", line 119, in <module>
main()
File "/mnt/d/BaiduNetdiskWorkspace/MultiscaleDynamicTOP/code/FEniCSBasedProject/3D_test/Unit_cubic.py", line 99, in main
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/bcs.py", line 177, in dirichletbc
bc = bctype(_value, dofs, V._cpp_object)
3969, 3972, 3975, 3978, 3981, 3984, 3987, 3990], dtype=int32), <dolfinx.cpp.fem.FunctionSpace_float64 object at 0x7fc0a4b27a30>
