I am solving the Stokes flow equations a rectangular domain. As far as I can tell, my code works well. However, my domain is symmetric with respect to the vertical axis, and I want to impose symmetry instead of solving for both sides. Currently, my results show the exact same behaviour on the right and on the left, which is great, but in future I would like to look at a more complicated configuration and imposing symmetry would save time.
I want to impose zero tangential stress on the centerline for the flow problem.
The right and left walls of my domain move with velocity u_c, which is what drives the recirculation zones on the sides.
This is the code I am using:
#Define mesh and geometry
mesh = RectangleMesh(Point(-1, 0), Point(1, 1), 120, 60)
#Mesh that I want, half of my current domain
#mesh = RectangleMesh(Point(0, 0), Point(1, 1), 120, 60)
#Define Taylor–Hood function space W
V = VectorElement(“CG”, triangle, 2)
Q = FiniteElement(“CG”, triangle, 1)
W = FunctionSpace(mesh, MixedElement([V, Q]))
#Define Function and TestFunction(s)
w = Function(W); (u, p) = split(w)
(v, q) = split(TestFunction(W))
#Define the viscosity and bcs
mu = Expression(‘exp(-a*pow(x[0],2))’, degree=2, a=5)
p0 = Expression(“1”, degree=1)
u_in = Constant(-2.0)
u_c = Constant(-1.0)
inflow = ‘near(x[1], 1.0) && x[0]<0.5 && x[0]>-0.5’
wall1 = ‘near(x[0], 1.0)’
wall2 = ‘near(x[0], -1.0)’
outflow = ‘near(x[1], 0.0)’
centre = ‘near(x[0], 0.0)’
bcu_inflow = DirichletBC(W.sub(0), (0.0, u_in), inflow)
bcu_wall1 = DirichletBC(W.sub(0), (0.0, u_c), wall1)
bcu_wall2 = DirichletBC(W.sub(0), (0.0, u_c), wall2)
#bcu_sym = Symmetry condition along centre, tangential stress = 0.
bcu_outflow = DirichletBC(W.sub(0), (0.0, u_c), outflow)
#bcs = [bcu_inflow, bcu_wall1, bcu_sym, bcu_outflow]
bcs = [bcu_inflow, bcu_wall1, bcu_wall2, bcu_outflow]
#Define the variational form
epsilon = sym(grad(u))
f = Constant((0, -9.81))
#F = (2muinner(epsilon, grad(v)) - div(u)*q - div(v)p)dx + p0dot(v,n)ds
F = (2muinner(epsilon, grad(v)) - div(u)*q - div(v)*p + dot(f,v))dx + p0dot(v,n)*ds
#Solve problem
solve(F == 0, w, bcs)
#Plot solutions
(u, p) = w.split()
File(“Stokes/velocity.pvd”) << u
File(“Stokes/pressure.pvd”) << p
Any help would be greatly appreciated!!
