How to improve the accuracy of projection
Hi all, I am trying to project a variable in the DG-0 function space to another DG-0 function space to test the accuracy of projection. However, sometimes the projection can give inaccurate results. The minimal working example is as follows:
from dolfinx.cpp.mesh import CellType
mesh = dolfinx.RectangleMesh(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([6, 6, 0])], \
    [2, 2], CellType.quadrilateral)
S0 = dolfinx.FunctionSpace(mesh, ('DG', 0))
z_field = dolfinx.Function(S0)
z_field.vector.array = np.array([0.5,0.5,0.5,0.5])
def ExpressionProjection(mesh, expr):
    V_proj = dolfinx.FunctionSpace(mesh, ('DG', 0))
    p = ufl.TrialFunction(V_proj)
    q = ufl.TestFunction(V_proj)
    a_v = ufl.inner(p, q) * ufl.dx
    L_v = ufl.inner(expr, q) * ufl.dx
    sol = dolfinx.fem.LinearProblem(a_v, L_v).solve().vector.array
    return sol
sol = ExpressionProjection(mesh, z_field)
print(sol) # projected results
print(z_field.vector.array) # original values
The output results are:
[1.42080553e-316 1.01306145e-316 5.00000000e-001 5.00000000e-001]
[0.5 0.5 0.5 0.5]
Apparently, the projected results and original values are different in this case. Also, there might be underflow values in the projected results. Do we have any methods to fix this? Thanks in advance!
It seems the following modification works, although I am not sure why:
    problem = dolfinx.fem.LinearProblem(a_v, L_v)
    sol = problem.solve()
    return sol
data = sol.vector.array
print(data) # projected results
The results are:
[0.5 0.5 0.5 0.5]
[0.5 0.5 0.5 0.5]
