Hey Fenics community,
I am currently trying to solve a system of a pair partial differential equations. Two of my trial functions within my system are the three-dimensional vector-valued functions \boldsymbol{x}(u) and \boldsymbol{f}(u) defined on the unit interval u\in[0,1]. We call \boldsymbol{x}(u) the centreline coordinates, \boldsymbol{f}(u) the force line density and u the material coordinate.
The two functions \boldsymbol{x}(u) and \boldsymbol{f}(u) are fully coupled through a complicated integral equation
The functions \hat{\boldsymbol{r}}(u,u'), r(u,u'), \hat{\boldsymbol{t}}(u) and s(u) and \left|\boldsymbol{x}_{u}(u')\right| can all be expressed in terms of the centreline coordinates \boldsymbol{x}(u). The vector-valued function \boldsymbol{u}(u) on the l.h.s. is the centreline velocity which can be expressed in terms of the centreline coordinates by a finite difference approximation. Alternatively, it would also be possible to express the system of partial differential equations in terms of centreline velocity \boldsymbol{u}(u) instead of the centreline coordinates \boldsymbol{x}(u) from the get go.
To solve the system of partial equations with fenics, I choose a uniform grid on the unit interval with N grid points and I approximate the force line density and the centreline vector components as continuous piecewise linear functions.
Because equations (2) and (3) are linear in the force line density \boldsymbol{f}(u), their solutions must be a linear function of the vertex values \boldsymbol{f}_{i}. Thus, there exists a matrix \boldsymbol{M} which maps the composite force line density vector \boldsymbol{F} onto the composite centreline velocity vector \boldsymbol{U} such that
with \boldsymbol{U} and \boldsymbol{F} being defined as
The vectors \boldsymbol{u}_{i} and \boldsymbol{f}_{i} refer to the centreline velocity and the force line density at the i-th vertix.
My first question is, would be in principle possible to pass the equation (1-3) symbolically to fenics using UFL. A potential problem is that the integrand includes divisions by zero if u=u' because r(u,u)=0 and \left|s(u)-s(u)\right|=0. Note that the integral converges nonetheless because terms with opposite signs converge to the same value and cancel in the limes u\rightarrow u'.
As a workaround, I derived the matrix elements of \boldsymbol{M} by hand which allows me to handle the division by zero problem by setting problematic matrix elements to zero. The inverse of \boldsymbol{M} exists, i.e. I can compute
which is the equation I want to include in my larger system of partial differential equations. I would approximate \boldsymbol{M}^{-1} to be a function of the the centreline coordinates \boldsymbol{x}(u) from the previous time step to linearize my equations.
What would be the best way to go about this? If possible, I would like to include equation (4) symbolically for \boldsymbol{M}^{-1} given numerically. If this is not possible, then I could insert the matrix \boldsymbol{M}^{-1} as a block into the bigger matrix representing my linearized discretized system of partial differential equations. To do that, I probably would need a dummy equation to include \boldsymbol{f(u)} into my set of equations. Here is some code to show how I define the function space for \boldsymbol{f}(u) and \boldsymbol{u}(u).
Thanks for taking the time!
N = 129
mesh = UnitIntervalMesh(N - 1)
P1 = FiniteElement('Lagrange', mesh.ufl_cell(), 1)
P3 = MixedElement(3 * [P1])
# inv_M would be computed using the solution for x from the
# previous time step
inv_M = np.random.rand((3*N, 3*N))
u = TrialFunction(P1) # 3xN
f = TrialFunction(P1) # 3xN
