You issue is in the definition of the MeshFunction as you define it as a function over cells.
You should change it to
sub_domains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
sub_domains.set_all(0)
Right().mark(sub_domains,1)
File("mf.pvd") << sub_domains
and you can visualize the markers on facets in for instance Paraview.
Using this marker will get you something close to 1 for
However, I disagree with the statement that
should be 1, as dS is the integration measure over internal facets (those that are not on the boundary).
As no internal markers has the value 1, the integral will be 0
