Integrating over an interior surface
I would like to integrate a function over a surface lying within my domain. Consider the following code:
omega1 = Rectangle(Point(0, 0), Point(0.5, 1))
omega2 = Rectangle(Point(0.5, 0), Point(1, 1))
domain = omega1 + omega2
domain.set_subdomain(1, omega2)
mesh = generate_mesh(domain, 32)
interior_surface = CompiledSubDomain('near(x[0], 0.5, DOLFIN_EPS)')
interior_surface_marker = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
interior_surface_marker.set_all(0)
interior_surface.mark(interior_surface_marker,1)
g = Constant(1)
g = project(g, FunctionSpace(mesh, 'Lagrange', 1))
print(assemble(g*ds(subdomain_id = 1, subdomain_data = interior_surface_marker)))
As you can see, the mesh produced respects the interior surface \{x=0.5\}. The integral should give 1; the result, however, is 0.
On the other hand, when I replace the interior surface with a boundary surface, i.e.,
interior_surface = CompiledSubDomain('on_boundary && near(x[0], 1, DOLFIN_EPS)')
the correct result is computed.
What is the problem with my interior surface?
From UFL manual ds represents exterior facet integral (that is why your code works for boundary surface). For interior surface dS is needed
assemble(avg(g)*dS(subdomain_id=1, subdomain_data=interior_surface_marker))
Thank you, Miroslav. May I expand on my previous question?
In fact, my integrand g has the form
inner(kappa*grad(T),FacetNormal(mesh))
The problem is that kappa and grad(T) are discontinuous across the interior surface and the FacetNormal is ambiguous, too.
I guess the most natural way to resolve this would be to restrict T to the subdomain omega2 and to compute the integral over the corresponding part of the boundary. How can such a restriction be done?
Explanation: I am trying to compute the energy flow across a contact surface. Mathematically and physically, the integral must be independent of the side (material 1 or material 2) that we look at. However, there will be a numerical error. Therefore, I want to compute the integrals over each side separately, and therefore I cannot make use of avg or jump.
Hi, consider using restriction using + and -. Here foo('+') restricts foo to the positive cell and FacetNormal('+') is the outer normal of a positive cell. Following the discussion here the +, - side can be changed by providing a form which has a dx measure term which has specified subdomain_data by some cell function g. Then a positive cell for a facet is the one for which value of g is higher. This allows for the following
omega1 = Rectangle(Point(0, 0), Point(0.5, 2))
omega2 = Rectangle(Point(0.5, 0), Point(1, 2))
# Make up something with discontinuous gradient
f = interpolate(Expression('std::max(0., x[0]-0.5)', degree=1), V)
dS = Measure('dS', domain=mesh, subdomain_data=interior_surface_marker, subdomain_id=1)
# +, - sides are by default assigned arbitrarily so assembling below
# will not yield meaningful result
L0 = dot(grad(f)('+'), n('+'))*dS
print(assemble(L0))
L1 = dot(grad(f)('-'), n('-'))*dS
print(assemble(L1))
mf = MeshFunction('size_t', mesh, 2, mesh.domains())
# Add dummy terms that will allow for controlling restrictions
# This is (0, 0) * (1, 0) * 2
L2 = dot(grad(f)('-'), n('-'))*dS + Constant(0)*dx(domain=mesh, subdomain_data=mf)
print(assemble(L2))
# This is (1, 0) . (-1, 0) * 2
L3 = dot(grad(f)('+'), n('+'))*dS + Constant(0)*dx(domain=mesh, subdomain_data=mf)
print(assemble(L3))
This is working! Thank you!
Hey everyone,
I’m new in the fenics community and I could use some help right now…
I’m having some troubles in the same subject, I’ve solved the variational problem already, and I wanted to do an integral on my internal boundary. so I have:
## Airfoil subdomain
dInterior = Measure("dS", subdomain_data=subdomains, subdomain_id=5)
tangent = as_vector([n[1], -n[0]])
L0 = ((inner(avg(vvec), tangent('+')))*dInterior)
circulation = assemble(L0)
where vvec is my velocity vector. What i’m not understanding is the circulation is always equal to zero, no matter what. When I plot the velocity vector it’s pretty clear it shoudn’t be zero. Am I missing something trivial here? I’ve tried all combinations of (’+’), (’-’) and avg() And it’s still zero.
Meddling around, I decided to try using ds, even though it’s for exterior surfaces and the answer is different than zero, but still wrong (shoudn’t be negative):
ds = Measure("ds", domain=mesh, subdomain_data=subdomains)
GammaP = ds(5)
circulation = assemble((dot(vvec, tangent))*GammaP)
circulation
>> -18.485904269034087
Here’s an image o my vvec just for demonstration:
Any help will be greatly appreciated.
Could you be more specific of which boundary is supposed to have the marker 5 (used in the dS measure)? If this is the boundary of you object, this is an exterior boundary (interior boundaries are those between two cells in 2D). And you should therefore use ds.
Hello Dokken,
Ok… seems like I got confused with the definitions… I should be using ds because the boundary with marker 5 is the airfoil profile, but still, the answer doesn’t seems to be correct… I’m still missing something.
Let me share the whole code here. I’m just solving a homogeneus laplacian with Dirichlet boundary conditions to solve for the stream function, and then getting the velocity vector from the stream. The boundary 5 corresponds to the airfoil:
# Create mesh
length = 4.0
diameter = 1.0
p0 = Point(np.array([0.0, 0.0]))
p1 = Point(np.array([length, diameter]))
aero_points = np.genfromtxt('naca2412.txt', delimiter = ' ')
aerofoil = [Point(i[0] + 1.5, i[1] + 0.5) for i in aero_points]
aerofoil = Polygon(aerofoil)
domain = Rectangle(p0, p1) - aerofoil
mesh = generate_mesh(domain, 60)
# Define boundary condition
u_D = Expression('230*x[1]', degree=1)
# Making a mark dictionary
mark = {"generic": 0,"lower_wall": 1,"upper_wall": 2,"left": 3,"right": 4, "airfoil": 5 }
subdomains = MeshFunction("size_t", mesh, 1)
subdomains.set_all(mark["generic"])
class Left(SubDomain):
class Right(SubDomain):
        return on_boundary and near(x[0], length)
class UpperWall(SubDomain):
        return on_boundary and near(x[1], diameter)
class LowerWall(SubDomain):
        return on_boundary and near(x[1], 0)
class Airfoil(SubDomain):
        return on_boundary and not (near(x[1], 0) or near(x[1], diameter) or near(x[0], length) or near(x[0], 0))
# Marking the subdomains
left = Left()
left.mark(subdomains, mark["left"])
right = Right()
right.mark(subdomains, mark["right"])
upper_wall = UpperWall()
upper_wall.mark(subdomains, mark["upper_wall"])
lower_wall = LowerWall()
lower_wall.mark(subdomains, mark["lower_wall"])
airfoil = Airfoil()
airfoil.mark(subdomains, mark["airfoil"])
bc_lower_wall = DirichletBC(V, 0, subdomains, mark["lower_wall"])
bc_upper_wall = DirichletBC(V, u_D((0,diameter)), subdomains, mark["upper_wall"])
bc_left = DirichletBC(V, u_D, subdomains, mark["left"])
bc_right = DirichletBC(V, u_D, subdomains, mark["right"])
bc_airfoil = DirichletBC(V, u_D((2,diameter/2)), subdomains, mark["airfoil"])
bcs = [bc_lower_wall, bc_upper_wall, bc_left, bc_right, bc_airfoil]
f = Constant(0)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
solve(a == L, u, bcs)
W = VectorFunctionSpace(mesh, 'P', 1)
vx = project(u.dx(1), V)
vy = project(-u.dx(0), V)
vvec = project(as_vector([vx, vy]),W)
and then I try to calculate the circulation around the airfoil: (This is wrong based on your answer)
dS = Measure("dS", domain=mesh, subdomain_data=subdomains)
GammaPS = dS(5)
L0 = avg(dot((vvec), (tangent)))*GammaPS
circulation
>> 0.0
or: (This one’s supposed to be right)
GammaP = ds(5)
L1 = (dot(vvec, tangent))*GammaP
circulation = assemble(L1)
circulation
>> -18.485904269034172
I thought It might be me messing up the orientations and getting a negative value, but when I tried calculating the circulation for a symmetrical object, which is supposed to be zero, I got a value different than zero, which is wrong. I’m just writing it down here because I believe my reply is long enough for now, and adding more code will make it even longer…
Just to make the code 100% reproducible, here is the content from naca2412.txt:
1.0 -1.6616460838224803e-17
0.9993213820969975 0.00014499032984683925
0.9972872631225536 0.000578728511557539
0.9939028455768911 0.001297536081139998
0.9891767944945985 0.00229534808032572
0.9831212283309125 0.0035638093035125227
0.9757517054010261 0.005092404207668343
0.9670872051355998 0.006868615913445671
0.9571501032924649 0.00887810878330874
0.9459661401982883 0.011104928369901545
0.933564381088738 0.013531712116464912
0.9199771676711413 0.016139904079208404
0.9052400601453433 0.018909967133751822
0.8893917690780644 0.0218215866145346
0.8724740767219776 0.024853860094137484
0.8545317475888985 0.027985469002641854
0.8356124283115054 0.031194828968031024
0.8157665370441834 0.03446021707058515
0.7950471428460603 0.03775987558390232
0.7735098356452664 0.04107209315542856
0.7512125874929715 0.04437526569228436
0.7282156058726268 0.04764794039820733
0.7045811798320735 0.05086884739458386
0.6803735196560986 0.054016924101172765
0.6556585907012681 0.05707133800954382
0.6305039418838468 0.0600115136267799
0.6049785291587992 0.06281716918547092
0.5791525341688195 0.06546836821069141
0.5530971780935735 0.06794559022326693
0.5268845306070138 0.0702298237739368
0.5005873137694109 0.07230268369144069
0.47427870065252875 0.07414655294729396
0.4480321085293681 0.07574474795852291
0.42192098655787974 0.07708170454064288
0.3959866523958327 0.07814207063005084
0.37015695727219483 0.07885512396776277
0.3446799907251953 0.07917983840371742
0.3196303337262879 0.07911176559702549
0.295081536819036 0.07864954600904192
0.2711058222179506 0.0777950160429226
0.24777378350855334 0.07655327310524312
0.2251540869530402 0.07493269119192177
0.20331317876031155 0.07294488068029803
0.18231500284650742 0.07060458743317967
0.16222073357227657 0.0679295280389216
0.1430885276880899 0.06494015996054617
0.12497329925453382 0.061659387472332274
0.10792652064937588 0.05811220644271906
0.09199605195815633 0.05432529319262308
0.07722600011133889 0.0503265447331433
0.06365660812779954 0.046144579584377475
0.051324173805717924 0.04180821002266096
0.04026099622352848 0.03734589793152308
0.030495347529559153 0.03278520738857021
0.02205146675845987 0.028152267666707042
0.014949571856738614 0.023471260439048798
0.009205885759561888 0.018763944643771863
0.004832672255117894 0.014049231695066635
0.0018382775066629242 0.00934282254175867
0.00022717346758919707 0.004656916512940597
0.0 0.0
0.0011432917778369696 -0.0045199873743347885
0.0036398271250637857 -0.008796887680483256
0.007478987149744335 -0.012827539314411746
0.012646513506632423 -0.016608550176758007
0.019124601854193072 -0.0201364086500858
0.0268920169463866 -0.02340763583354531
0.035924225973239104 -0.026418972522308737
0.04619354613387065 -0.029167592939172374
0.05766930200591418 -0.03165133605209156
0.07031798808776175 -0.03386894448976651
0.08410343194323706 -0.03582030063062645
0.09898695366689622 -0.03750664940746651
0.11492751789365321 -0.03893079774434977
0.13188187526807194 -0.04009728131251159
0.14980469112536252 -0.04101249043088248
0.1686486600688652 -0.04168474840283598
0.18836460610365507 -0.042124337318878755
0.20890156894721532 -0.0423434682987691
0.2302068780319326 -0.04235619522042734
0.25222621649144655 -0.042178273105243136
0.27490367804250265 -0.04182696441529416
0.29818182010516364 -0.04132079848343261
0.3220017167284117 -0.04067929106222442
0.34630301489985726 -0.03992263247012663
0.37102399762528443 -0.03907135397193605
0.39610165678640813 -0.038145982808275594
0.4216445484018893 -0.03713442553609651
0.4474394282029785 -0.03599793724535724
0.4733853431045275 -0.03475223822003523
0.49941268623058876 -0.033413794802551806
0.5254514256359297 -0.031998530296521256
0.5514312851740798 -0.03052163424938244
0.5772819308714112 -0.0289974106514835
0.6029331616589602 -0.027439167727298798
0.6283151032186739 -0.025859150186468484
0.6533584036736794 -0.02426851302516897
0.6779944298892017 -0.022677334297823405
0.7021554632437267 -0.02109466278488639
0.72577489386692 -0.01952859522458461
0.7487874125070283 -0.01798637680339546
0.7711291993697603 -0.016474517946209404
0.7927381094464127 -0.014998920131944411
0.8135538540056538 -0.0135650034875589
0.8335181780473524 -0.012177829271078687
0.852575033597649 -0.01084221101582571
0.8706707487554164 -0.009562809033714818
0.8877541923789065 -0.00834420411430316
0.9037769342296041 -0.007190947548681063
0.9186934002742827 -0.00610758598798812
0.9324610226957009 -0.005098661047403128
0.9450403839900795 -0.0041686849205010874
0.9563953543501361 -0.0033220945120995644
0.9664932213616019 -0.0025631876728228263
0.9753048108941276 -0.001896045977266546
0.9828045979581557 -0.001324449092619368
0.9889708062392072 -0.0008517861112930204
0.9937854950182466 -0.0004809692585186644
0.99723463224572 -0.00021435513695233267
0.9993081526575762 -5.367815167922411e-05
1.0 1.6616460838224803e-17
Thank you very much for your attention, Dokken,
Consider the following problem for a circular object:
def compute_circulation(N):
    # Create mesh
    length = 4.0
    diameter = 1.0
    r = 0.2
    obj = Circle(Point(length/2, diameter/2), r)
    domain = Rectangle(p0, p1) - obj
    mesh = generate_mesh(domain, N)
            return on_boundary and (x[0]-length/2)**2+(x[1]-diameter/2)**2<1.1*r**2
    File("mesh.pvd") << mesh
    left = Left()
    right = Right()
    airfoil = Airfoil()
    f = Constant(0)
    L = f*v*dx
    # Compute solution
    GammaP = ds(5)
    # Project tangent to CG 1 space for visualization
    VV = VectorFunctionSpace(mesh, "CG", 1)
    q,r = TrialFunction(VV), TestFunction(VV)
    aV = inner(q, r)*ds(5)
    lV = inner(tangent, r)*ds(5)
    tang_proj = Function(VV)
    AV = assemble(aV, keep_diagonal=True)
    AV.ident_zeros()
    LV = assemble(lV)
    solve(AV, tang_proj.vector(), LV)
    File("tang.pvd") << tang_proj
    File("circ.pvd") << vvec
    print(N, circulation, assemble(inner(vvec, as_vector((1,0)))*ds(5)))
compute_circulation(50)
compute_circulation(100)
compute_circulation(200)
compute_circulation(400)
yielding:
fenics@3a01410489e7:~/shared$ python3 circulation.py
Solving linear variational problem.
50 -2.814902850116198 300.78413974646304
100 -0.35969509592035376 314.1475947113785
200 -0.3435394737202848 323.7011340127153
400 0.03041307517778638 328.270430678979
Here I have made the circulation a function of the mesh resolution (for a circular object). As you can observe, on a coarse mesh, the mesh circulation is far from 0 on the coarsest meshes. Also note that last value is simply the integral of the x-component of the velocity field, is of quite a large magnitude (and the flow field around the obstacle does not satisfy a no penetration constraint.
Therefore I would suggest using a finer mesh.
Note that I have also added a projection of the tangent vector to a CG 1 space, such that it can be visualized with either matplotlib or Paraview.
The accuracy of the circulation integral should also be greatly improved by using a second order mesh. There is limited support for higher order geometries in dolfin, while this has been one of the main focuses of dolfinx
Dokken,
Thank you so much for answering! Your answer was perfectly clear and made everything much clearer for me now. Thank you again for your time. Fenics seems to be an awesome platform!
Oh… and I apologize for the off-topic question, since it’s in a interior boundary question. Perhaps i should create a new question about circulation and add your answer?
I think we should leave the posts as they are, to avoid duplication;)
How does one do this in FenicsX?
Could you be more specific as to what you want to achieve, that you haven’t been able to do in DOLFINx.
  1. are you trying to compute an integral over an interior facet?
  2. Are you trying to do: Integrating over an interior surface - #9 by dokken in DOLFINx?
More precisely, I would like to compute the L^2-norm of the tangential component of the gradient along a curve in the interior of my domain, i.e.
\int_\gamma |\nabla u \cdot t|^2 ds
See for instance Add one-sided integration example as example of custom integration · Issue #158 · jorgensd/dolfinx-tutorial · GitHub
Thanks!
Follow-up question: Where does the ‘8’ come from in this line?
ds = ufl.Measure("ds", domain=mesh, subdomain_data=[
                 (8, np.asarray(integration_entities, dtype=np.int32))])
You choose an integer to mark the boundary.
n = ufl.FacetNormal(mesh)
# Exact integral is [y/2**2]_0^1= 1/2
L = ufl.dot(ufl.as_vector((x[1], 0)), n)*ds(8)
As you see here, the 8 is used in ds(8) to integrate over entities marked with 8 in subdomain data
OK, when adapting to my use case, I get a compile error with the form, that I do not understand
Here’s the code:
from dolfinx.io import gmshio
from ufl import Measure, grad, inner, FacetNormal, SpatialCoordinate, dot, as_vector
from dolfinx.fem import form, assemble_scalar
from dolfinx.mesh import meshtags
def get_mesh(size: float = 0.2, meshsize: float = 0.05, name: str = "dev"):
    comm = MPI.COMM_WORLD
    gmsh.model.add(name)
    model = gmsh.model
    geom = model.occ
    gdim = 2
    defeatured_domain_tag = geom.addDisk(0, 0, 0, 1, 1)
    geom.synchronize()
    disk_tag = geom.addDisk(0, 0, 0, size, size, defeatured_domain_tag + 1)
    geom.synchronize()
    out_dim_tags, *_ = geom.cut(
        [(gdim, defeatured_domain_tag)],
        [(gdim, disk_tag)],
        removeTool=False,
        removeObject=False,
    _, exact_domain_tag = out_dim_tags[0]
    geom.synchronize()
    exact_domain_marker = model.addPhysicalGroup(gdim, [exact_domain_tag])
    model.setPhysicalName(gdim, exact_domain_marker, "ExactDomain")
    outer_boundary = model.getBoundary([(gdim, defeatured_domain_tag)], oriented=False)
    outer_boundary_marker = model.addPhysicalGroup(
        gdim - 1, [b[1] for b in outer_boundary]
    model.setPhysicalName(gdim - 1, outer_boundary_marker, "OuterBoundary")
    disk_marker = model.addPhysicalGroup(gdim, [disk_tag])
    model.setPhysicalName(gdim, disk_marker, "Disk")
    disk_boundary = model.getBoundary([(gdim, disk_tag)], oriented=False)
    disk_boundary_marker = model.addPhysicalGroup(
        gdim - 1, [b[1] for b in disk_boundary]
    model.setPhysicalName(gdim - 1, disk_boundary_marker, "BoundaryDisk")
    gmsh.option.setNumber("Mesh.CharacteristicLengthMin", meshsize)
    gmsh.option.setNumber("Mesh.CharacteristicLengthMax", meshsize)
    gmsh.model.mesh.generate(dim=gdim)
    gmsh.write(f"{name}.msh")
    mesh = meshio.read(f"{name}.msh")
    meshio.write(f"{name}.xdmf", mesh)
    domain, cell_markers, facet_markers = gmshio.model_to_mesh(
        gmsh.model, comm, rank=0, gdim=gdim
    gmsh.finalize()
    name2marker = {
        "ExactDomain": exact_domain_marker,
        "OuterBoundary": outer_boundary_marker,
        "Disk": disk_marker,
        "BoundaryDisk": disk_boundary_marker,
    return domain, cell_markers, facet_markers, name2marker
if __name__ == "__main__":
    size = 0.3
    mesh, cell_tags, facet_tags, name2marker = get_mesh(size=size, meshsize=0.05)
    tdim = mesh.topology.dim
    fdim = tdim - 1
    disk_boundary_marker = name2marker["BoundaryDisk"]
    disk_marker = name2marker["Disk"]
    outer_marker = name2marker["OuterBoundary"]
    outer_facets = facet_tags.find(outer_marker)
    outer_tags = meshtags(mesh, fdim, outer_facets, outer_marker)
    disk_boundary_facets = facet_tags.find(disk_boundary_marker)
    disk_boundary_tags = meshtags(
        mesh, fdim, disk_boundary_facets, disk_boundary_marker
    f2c = mesh.topology.connectivity(fdim, tdim)
    c2f = mesh.topology.connectivity(tdim, fdim)
    integration_entities = []
    for i, facet in enumerate(disk_boundary_facets):
        cells = f2c.links(facet)
        marked_cells = cell_tags.values[cells]
        correct_cell = np.flatnonzero(marked_cells == disk_marker)
        assert len(correct_cell) == 1
        local_facets = c2f.links(cells[correct_cell[0]])
        local_index = np.flatnonzero(local_facets == facet)
        assert len(local_index) == 1
        integration_entities.append((cells[correct_cell[0]], local_index[0]))
    ds = Measure("ds", domain=mesh, subdomain_data=[
    x = SpatialCoordinate(mesh)
    L = dot(as_vector((x[1], 0)), n)*ds(8)
    L_compiled = form(L)
    print(
        f"Correct integral: {mesh.comm.allreduce(assemble_scalar(L_compiled), op=MPI.SUM)}")
Essentially, I have a disk as a domain with an interior circle over which I want to integrate a tangential derivative.
Change ds to:
                 (8, np.asarray(integration_entities, dtype=np.int32).flatten())])
I don’t exactly understand why, but it works like a charm, thanks ! :slight_smile:
