How to load 3D hexahedron mesh file and set the boundaries
Hi everyone, I’m new on Fenics. Now I’m trying to create 3D hexahedron mesh from msh file to conduct structural dynamic analysis. The msh file has been converted into a file with the format .xdmf. But when it came to set the facets of model as boundaries, my test code was not working and the error was reported as:
  File "/usr/lib/python3/dist-packages/IPython/core/interactiveshell.py", line 3331, in run_code
    exec(code_obj, self.user_global_ns, self.user_ns)
  File "<ipython-input-2-1feacff24f0a>", line 1, in <module>
    runfile('/mnt/d/test/3dtest.py', wdir='/mnt/d/test')
  File "/mnt/d/py/Pycharm2021.2.4/plugins/python/helpers/pydev/_pydev_bundle/pydev_umd.py", line 198, in runfile
    pydev_imports.execfile(filename, global_vars, local_vars)  # execute the script
  File "/mnt/d/py/Pycharm2021.2.4/plugins/python/helpers/pydev/_pydev_imps/_pydev_execfile.py", line 18, in execfile
    exec(compile(contents+"\n", file, 'exec'), glob, loc)
  File "/mnt/d/test/3dtest.py", line 56, in <module>
boundaries = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
TypeError: 'dolfinx.cpp.mesh.Topology' object is not callable
Do you any idea how to overcome this please?
Thanks a lot for your help!
Best regards,
Kepler.
Could you please clarify what version of FEniCS you are trying to run?
From the looks of it, you have installed dolfinx, but you are using legacy dolfin syntax
Thank you very much, Dokken, for the quick reply.
I have checked that the version of fenics-dolfin is 2019.2.0.dev0 and that of fenics-dolfinx is 0.4.1.
Sorry, I still don’t know where the syntax of the code conflicts. How should I use the syntax of new version to define the boundaries of the imported model. The mesh file of the model can be seen: my file
It should be additionally explained that I performed FENICS on the Pycharm platform by WSL in windows system. Would it affect this issue?
Please post your actual code, as here you are calling a dolfinx-object, while your code seems to be for dolfin.
Thank you very much, Prof. Dokken!
Here is the code. It takes from cases library. I want to have a try to using it to conduct dynamic analysis of three-dimensional structures as an exercise and learn more about FENICS by the way. It seems quite challenging now.
import h5py
import dolfinx.io
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, 'Ldam.xdmf', "r") as xdmf:
V = VectorFunctionSpace(mesh, "CG", 2)
# Create classes for defining parts of the boundaries of the domain
class Left(SubDomain):
        return near(x[0], -454.598)
class Right(SubDomain):
        return near(x[0], 464.200)
class Bottom(SubDomain):
        return near(x[2], -250.0)
class Front(SubDomain):
        return near(x[1], -277.267)
class Back(SubDomain):
        return near(x[1], 343.795)
# # Initialize sub-domain instances
left = Left()
right = Right()
front = Front()
bottom = Bottom()
back = Back()
# # Initialize mesh function for boundary domains
boundaries.set_all(0)
left.mark(boundaries, 1)
right.mark(boundaries, 2)
front.mark(boundaries, 3)
bottom.mark(boundaries, 4)
back.mark(boundaries, 5)
dss = ds(subdomain_data=boundaries)
# Define Dirichlet boundary conditions at top and bottom boundaries
bcs = [DirichletBC(V, (0.0,0.0,0.0), boundaries, 1),
       DirichletBC(V, (0.0,0.0,0.0), boundaries, 2),
       DirichletBC(V, (0.0,0.0,0.0), boundaries, 3),
       DirichletBC(V, (0.0,0.0,0.0), boundaries, 4),
       DirichletBC(V, (0.0,0.0,0.0), boundaries, 5)]
# Parameters
E  = 24e9
nu = 0.25
mu    = Constant(E / (2.0*(1.0 + nu)))
lmbda = Constant(E*nu / ((1.0 + nu)*(1.0 - 2.0*nu)))
rho = Constant(2400)
eta_m = Constant(0.1)
eta_k = Constant(0.1)
alpha_m = Constant(0.2)
alpha_f = Constant(0.4)
gamma   = Constant(0.5+alpha_f-alpha_m)
beta    = Constant((gamma+0.5)**2/4.)
# time
T       = 4.0
Nsteps  = 200
dt = Constant(T/Nsteps)
time = np.linspace(0, T, Nsteps+1)
p0 = 1.
cutoff_Tc = T/10
p = Expression(("0", "t <= tc ? p0*t/tc : 0", "0"), t=0, tc=cutoff_Tc, p0=p0, degree=0)
u0 = Constant((0.0, 0.0, 0.0))
b = Constant((0.0, 0.0, 0.0))
def epsilon(u_):
    return sym(grad(u_))
def sigma(u_):
    return 2.0*mu*epsilon(u_) + lmbda*tr(epsilon(u_))*Identity(len(u_))
def m(u_,v_):
    return rho*inner(u_, v_)*dx
def k(u_,v_):
    return inner(sigma(u_), epsilon(v_))*dx
def c(u_,v_):
    return eta_m*m(u_,v_) + eta_k*k(u_,v_)
def f(v_):
    return rho*dot(b,v_)*dx+dot(p,v_)*dss(3)
def update_a(u_, u_old_, v_old_, a_old_, ufl=True):
    if ufl:
        dt_ = dt
        beta_ = beta
        dt_ = float(dt)
        beta_ = float(beta)
    return (u_-u_old_-dt_*v_old_)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old_
def update_v(a_, u_old_, v_old_, a_old_, ufl=True):
    if ufl:
        dt_ = dt
        gamma_ = gamma
        dt_ = float(dt)
        gamma_ = float(gamma)
    return v_old_ + dt_*((1-gamma_)*a_old_ + gamma_*a_)
def update_fields(u_, u_old_, v_old_, a_old_):
    u_vec, u0_vec  = u_.vector(), u_old_.vector()
    v0_vec, a0_vec = v_old_.vector(), a_old_.vector()
    a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl=False)
    v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl=False)
    # (u_old <- u)
    v_old_.vector()[:], a_old_.vector()[:] = v_vec, a_vec
    u_old_.vector()[:] = u_.vector()
def avg(x_old, x_new, alpha):
    return (1-alpha)*x_new + alpha*x_old
# Definition question
u_ = Function(V)
u_old = Function(V)
v_old = Function(V)
a_old = Function(V)
a_new = update_a(u, u_old, v_old, a_old, ufl=True)
v_new = update_v(a_new, u_old, v_old, a_old, ufl=True)
F =  m(avg(a_old, a_new, alpha_m),v)+c(avg(v_old, v_new, alpha_f),v)+k(avg(u_old, u, alpha_f),v) - f(v)
a = lhs(F)
L = rhs(F)
#Calculating
vtkfile = File("elasdynamics.pvd")
K, res = assemble_system(a, L, bcs)
solver = LUSolver(K, "mumps")
solver.parameters["symmetric"] = True
for (i, dt) in enumerate(np.diff(time)):
    t = time[i+1]
    print("Time: ", t)
    p.t = t-float(alpha_f*dt)
    # solve
    #solve(a == L,u_,bc)
    res = assemble(L)
    bcs.apply(res)
    solver.solve(K, u_.vector(), res)
    # save
    vtkfile << (u_, t)
    # updating
    update_fields(u_, u_old, v_old, a_old)
You shouldn’t import dolfinx or use anything from dolfinx in combination with legacy FEniCS. For usage of dolfinx, see:
https://jsdokken.com/dolfinx-tutorial/
and
