from dolfinx import fem, mesh, io, default_scalar_type
from dolfinx.io import gmshio, XDMFFile
from ufl import div, grad, inner, dx, Measure
from dolfinx.mesh import locate_entities_boundary, meshtags
# Initialize parameters
L, H = 3, 3  # Domain size
plate_length = 1
plate_height = 0.1
V0 = 1000.0  # Voltage on upper plate
model_rank = 0
mesh_comm = MPI.COMM_WORLD
gdim = 2
# Initialize gmsh
# Create background domain
background = gmsh.model.occ.addRectangle(0, 0, 0, L, H) #1
# Create plates
upper_plate = gmsh.model.occ.addRectangle(1, 2, 0, plate_length, plate_height) #2
lower_plate = gmsh.model.occ.addRectangle(1, 1.1, 0, plate_length, plate_height) #3
gmsh.model.occ.synchronize()
# Fragment all geometries together
all_surfaces = [(2, upper_plate), (2, lower_plate)]
whole_domain, map_to_input = gmsh.model.occ.fragment([(2, background)], all_surfaces)
# Create physical markers
background_surfaces = []
plate_surfaces = []
upper_mark = [idx for (dim, idx) in map_to_input[1] if dim == 2]
lower_mark = [idx for (dim, idx) in map_to_input[2] if dim == 2]
total_mark = upper_mark + lower_mark
background_mark = [idx for (dim, idx) in map_to_input[0] if dim == 2 and idx not in total_mark]
gmsh.model.addPhysicalGroup(2, upper_mark, tag=5)
gmsh.model.addPhysicalGroup(2, lower_mark, tag=7)
gmsh.model.addPhysicalGroup(2, background_mark, tag=9)
upper_boundary = gmsh.model.getBoundary([(2, e) for e in upper_mark], recursive=False, oriented=False)
lower_boundary = gmsh.model.getBoundary([(2, e) for e in lower_mark], recursive=False, oriented=False)
outer_boundary = gmsh.model.getBoundary([(2, e) for e in background_mark], recursive=False, oriented=False)
upper_interface = [idx for (dim, idx) in upper_boundary if dim == 1]
lower_interface = [idx for (dim, idx) in lower_boundary if dim == 1]
total_interface = upper_interface + lower_interface
ext_boundary = [idx for (dim, idx) in outer_boundary if idx not in total_interface and dim == 1]
gmsh.model.addPhysicalGroup(1, upper_interface, tag=12)
gmsh.model.addPhysicalGroup(1, lower_interface, tag=15)
gmsh.model.addPhysicalGroup(1, ext_boundary, tag=17)
 # Create refined mesh around plates
gmsh.model.mesh.field.setNumbers(1, "EdgesList", [e[1] for e in upper_boundary+lower_boundary])
# Add threshold field for mesh refinement
gmsh.model.mesh.field.setNumber(2, "IField", 1)
gmsh.model.mesh.field.setNumber(2, "LcMin", plate_height/3)
gmsh.model.mesh.field.setNumber(2, "LcMax", plate_height*6)
gmsh.model.mesh.field.setNumber(2, "DistMin", plate_height*4)
gmsh.model.mesh.field.setNumber(2, "DistMax", plate_height*10)
gmsh.model.mesh.field.add("Min", 5)
gmsh.model.mesh.field.setNumbers(5, "FieldsList", [2])
gmsh.model.mesh.field.setAsBackgroundMesh(5)
# Generate mesh
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.model.mesh.setOrder(2)
gmsh.write("capacitor.msh")
# Read mesh and set up connectivity
mesh_obj, cell_tags, facet_tags = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2)
mesh_obj.topology.create_connectivity(gdim - 1, gdim)  # Create necessary connectivity
gmsh.finalize()
# Save mesh for visualization
with XDMFFile(MPI.COMM_WORLD, "capacitor.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh_obj)
    xdmf.write_meshtags(cell_tags, mesh_obj.geometry)
# Create function space
V = fem.functionspace(mesh_obj, ("CG", 2))
# Now locate DOFs based on the markers
upper_plate_dofs = fem.locate_dofs_topological(V, gdim - 1,facet_tags.find(12))
lower_plate_dofs = fem.locate_dofs_topological(V, gdim - 1, facet_tags.find(15))
# Apply Dirichlet boundary conditions
bc_upper = fem.dirichletbc(PETSc.ScalarType(V0), upper_plate_dofs, V)
bc_lower = fem.dirichletbc(PETSc.ScalarType(-V0), lower_plate_dofs, V)
# Combine boundary conditions
bcs = [bc_upper, bc_lower]
u = ufl.TrialFunction(V)
# Permittivity (εr = 1 for air)
epsilon_0 = 8.854e-12  # F/m
epsilon_r = 1.0        # relative permittivity for air
epsilon = epsilon_0 * epsilon_r
# Poisson equation: -∇·(ε∇u) = ρ/ε₀ (here ρ = 0 between plates)
a = epsilon * inner(grad(u), grad(v)) * dx
L = fem.Constant(mesh_obj, PETSc.ScalarType(0.0)) * v * dx
# Solve problem
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
# Save solution to XDMF format for visualization
with io.XDMFFile(mesh_obj.comm, "capacitor_solution.xdmf", "w") as file:
    file.write_mesh(mesh_obj)
    file.write_function(uh)
# Compute electric field (E = -grad(u))
gdim = mesh_obj.geometry.dim
E_field = -ufl.grad(uh)
V_E = fem.functionspace(mesh_obj, ("DG", 2, (gdim, )))
E = fem.Function(V_E)
E_expr = fem.Expression(E_field, V_E.element.interpolation_points())
E.interpolate(E_expr)
# Save the electric field
with io.VTXWriter(mesh_obj.comm, "capacitor_field.bp", E, engine="BP4") as vtx:
    vtx.write(0.0)
I am able to solve the plate capacitor problem. But the field lines on and near the plates are disoriented.  I don’t it’s from paraview or fenics. Can someone please help?
