How to parallelize code alongside assign()?
I’m trying to manipulate functions using assign() inside of a for-loop, but I want my code to run in parallel, especially when using solve() elsewhere inside of a time loop.
As a simple example, consider the following code code as run using mpirun -np 2
# Define submesh mesh and function spaces
mesh = BoxMesh(Point(0, 0), Point(box_length, box_length, 0.5),
                     64, 64, 32)
P1 = FiniteElement('CG', mesh.ufl_cell(), 1)
W = FunctionSpace(mesh, P1)
#Initialize functions
Aexp = Expression('2', degree=1)
A = interpolate(Aexp, W)
Bexp = Expression('2', degree=1)
B = interpolate(Bexp, W)
Cexp = Expression('0', degree=1)
C = interpolate(C, W)
#time loop
for t in range(0,5):
  C.assign(A + B)
  B.assign(C)
  print(C.vector().get_local())
This returns the following error message
*** Error:   Unable to successfully call PETSc function 'VecCopy'.
*** Reason:  PETSc error code is: 73 (Object is in wrong state).
*** Where:   This error was encountered inside /home/conda/feedstock_root/build_artifacts/fenics-pkgs_1668433332839/work/dolfin/dolfin/la/PETScVector.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  3ea2183fbfe7277de9f16cbe1a9ffaab133ba1fa
This question seems similar to this question, but that question was never answered and my example is both slightly different in form and returns a different error.
Any help at all would be appreciated, even just an explanation of what is going on with the dofs in parallel, or pointing to the relevant documentation. Clearly, I know that assign itself does not probably need parallelization. Parallelizing other code that might be in the for-loop alongside assign() is my real goal. For instance, when assign() is used in a time loop to update a source field for some variational form to be solved.
Surely this is a typo?
Even with the fix I mentioned above, I cannot reproduce your issue using the lastest version of DOLFIN (on docker), or the 2019.1.0 dolfin quay image:
box_length = 1
                     10,10,10)
C = interpolate(Cexp, W)
#time loop
  C.assign(A + B)
  B.assign(C)
Thanks for your help @dokken! You are correct about the typo.
I’m not sure why you cannot reproduce the error. I’m running the code from the conda-forge version running on a cluster. Could clashes between the conda installation and the cluster’s handling of multithreading or something be going on?
I was able to “fix” things by doing a hacky workaround. From this question I learned that c.assign(a) has different behavior than assign(c, a) when running under mpirun. Thus, the following code has the desired behavior for me:
mesh = BoxMesh(Point(0, 0), Point(1, 1, 0.5),
                     64, 64, 32)
#Define pointwise addition of functions. Returns a numpy array of the pointwise sym of .get_local() values
def Add(functions):
    garrays = []
    for g in functions:
        garrays.append(g.vector().get_local())
    Sum = garrays[0] #initialize the sum variable with the first array in garrays
    #successively add each array in garrays together (-1 in loop +1 in index because sum begins with garrays[0])
    for i in range(len(garrays)-1):
        Sum = Sum+garrays[i + 1]
    result = Function(W)
    result.vector().set_local(Sum)
    return result
for x in range(0,5):
  assign(C, Add([A,B]))
  assign(B, C)
While this workaround might “work” for now, I certainly don’t understand what’s going on? Bafflingly, this is the output from the print function using -np 2:
[0. 4. 0. ... 4. 4. 0.]
[0. 6. 0. ... 6. 6. 0.]
[0. 8. 0. ... 8. 8. 0.]
[ 0. 10.  0. ... 10. 10.  0.]
[ 0. 12.  0. ... 12. 12.  0.]
[4. 4. 4. ... 4. 4. 4.]
[6. 6. 6. ... 6. 6. 6.]
[8. 8. 8. ... 8. 8. 8.]
[10. 10. 10. ... 10. 10. 10.]
[12. 12. 12. ... 12. 12. 12.]
One of the processes seems to get it right, while the other doesn’t?
You error is in PETSc, which might mean there is an issue with the PETSc installation shipped with conda.
