I want to plot or save not only dependent variables (i.e. objects of the Function class) but also quantities, which are derived from Function objects. I attach the following example (derived from the standard Possion demo in 1D), where I am able to write uh (which is a Function object) but not vh = 2*uh, which is an object from the class ufl.algebra.product.
Thank you.
import pyvista
from dolfinx import fem, io, mesh
x_left = 0
x_right = 1
NumberOfCells = 1000
msh = mesh.create_interval(MPI.COMM_WORLD, NumberOfCells, points=(x_left, x_right))
V = fem.FunctionSpace(msh, ("Lagrange", 1))
facet_left_bdry = mesh.locate_entities_boundary(msh, dim=0, marker=lambda x: np.isclose(x[0], x_left))
dof_left_bdry = fem.locate_dofs_topological(V=V, entity_dim=0, entities=facet_left_bdry)
facet_right_bdry = mesh.locate_entities_boundary(msh, dim=0, marker=lambda x: np.isclose(x[0], x_right))
dof_right_bdry = fem.locate_dofs_topological(V=V, entity_dim=0, entities=facet_right_bdry)
bc_left = fem.dirichletbc(value=ScalarType(0), dofs=dof_left_bdry, V=V)
bc_right = fem.dirichletbc(value=ScalarType(1/6), dofs=dof_right_bdry, V=V)
u = ufl.TrialFunction(V)
f = x[0]
L = -inner(f, v) * dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc_left, bc_right], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
vh = 2*uh
with io.XDMFFile(msh.comm, "out_poisson/poisson.xdmf", "w") as file:
file.write_mesh(msh)
file.write_function(uh)
file.write_function(vh)
