I am running this code
and I was wondering how can I print out the optimal solution?
Thank you.
Thank you.
Please note that pyadjoint has moved to github:GitHub - dolfin-adjoint/pyadjoint: The algorithmic differentation tool pyadjoint and add-ons.
Secondly, you can do this by a slight modification of the code, you can save the optimal state to pvd which can be visualized in Paraview.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# .. _time_distributed_control:
# .. py:currentmodule:: dolfin_adjoint
# Time-distributed controls
# .. sectionauthor:: Simon W. Funke <simon@simula.no>
# Background
# Some time-dependent problems have control variables that are distributed over
# all (or some) time-levels. The following example demonstrates how this can be
# implemented in dolfin-adjoint.
# One important aspect to consider is the regularisation term. For
# time-distributed controls, one typically uses wishes to enforce smoothness
# of the control variables in time. We will also discuss how such a
# regularisation term is implemented.
# Problem definition
# We consider the heat equation with a time-dependent source term :math:`f`, which will be
# our control variable:
# .. math::
# \frac{\partial u}{\partial t} - \nu \nabla^{2} u= f(t)
# \quad & \textrm{in } \Omega \times (0, T), \\
# u = 0 \quad & \textrm{for } \Omega \times \{0\} \\
# u = 0 \quad & \textrm{for } \partial \Omega \times (0, T).
# where :math:`\Omega` is the unit square, :math:`T` is the final time, :math:`u`
# is the unkown temperature variation, :math:`\nu` is the thermal diffusivity, and
# :math:`g` is the initial temperature.
# The objective value, the model output of interest, is the norm of the
# temperature variable integrated over time, plus a regularisation term that
# enforces smoothness of the control in time:
# .. math::
# J(u, f) := \int_0^T \int_\Omega (u-d)^2 \textrm{d} \Omega \text{d}t +
# \frac{\alpha}{2} \int_0^T \int_\Omega \dot f^2 \textrm{d} \Omega \text{d}t
# The aim of this example is to solve the minimization problem :math:`\min_f J`
# for some given data :math:`d`.
# Implementation
# We start by importing the needed FEniCS and dolfin-adjoint modules (note that
# `fenics_adjoint` is an alias for `dolfin_adjoint`):
from fenics_adjoint import *
from collections import OrderedDict
# Next, we define the expressions for observational data :math:`d` and the
# viscosity :math:`\nu`.
data = Expression("16*x[0]*(x[0]-1)*x[1]*(x[1]-1)*sin(pi*t)", t=0, degree=4)
nu = Constant(1e-5)
# Next, we define the discretization space:
mesh = UnitSquareMesh(8, 8)
# ... and time:
dt = Constant(0.1)
T = 2
# We are considering a time-distributed forcing as control. In the next step,
# we create one control function for each timestep in the model, and store all
# controls in a dictionary that maps timestep to control function:
ctrls = OrderedDict()
t = float(dt)
while t <= T:
ctrls[t] = Function(V)
t += float(dt)
# The following function implements a heat equation solver in FEniCS,
# and constructs the first functional term.
def solve_heat(ctrls, output=False):
f = Function(V, name="source")
u_0 = Function(V, name="solution")
d = Function(V, name="data")
F = ( (u - u_0)/dt*v + nu*inner(grad(u), grad(v)) - f*v)*dx
a, L = lhs(F), rhs(F)
bc = DirichletBC(V, 0, "on_boundary")
t = float(dt)
j = 0.5*float(dt)*assemble((u_0 - d)**2*dx)
if output:
outfile = XDMFFile("u_out.xdmf")
out_data = XDMFFile("data.xdmf")
while t <= T:
# Update source term from control array
f.assign(ctrls[t])
# Update data function
data.t = t
d.assign(interpolate(data, V))
# Solve PDE
solve(a == L, u_0, bc)
# Implement a trapezoidal rule
if t > T - float(dt):
weight = 0.5
weight = 1
j += weight*float(dt)*assemble((u_0 - d)**2*dx)
if output:
outfile.write(u_0, t)
out_data.write(d, t)
# Update time
t += float(dt)
if output:
outfile.close()
out_data.close()
return u_0, d, j
u, d, j = solve_heat(ctrls)
# With this preparation steps, we are now ready to define the functional.
# First we discretise the regularisation term
# .. math::
# Note, that :math:`f` is a piecewise linear function in time over the time intervals :math:`K = [(0, \delta t), (\delta t, 2 \delta t), \dots, (T-\delta
# t, T)]`. Thus, we can write the integral as a sum over all intervals
# .. math::
# \frac{\alpha}{2} \sum_{a_k, b_k \in K} \int_{a_k}^{b_k} \int_\Omega \dot f(t)^2 \textrm{d} \Omega\text{d}t
# Discretising the time-derivative yields:
# .. math::
# \frac{\alpha}{2} \sum_K \int_{a_k}^{b_k}
# \int_\Omega \left(\frac{f(b_k)-
# f(a_k)}{b_k-a_k}\right)^2\textrm{d}\Omega \\
# = \frac{\alpha}{2} \sum_K (b_k-a_k)^{-1}
# \int_\Omega \left(f(b_k)- f(a_k)\right)^2\textrm{d}\Omega
# In code this is translates to:
alpha = Constant(1e-1)
regularisation = alpha/2*sum([1/dt*(fb-fa)**2*dx for fb, fa in
zip(list(ctrls.values())[1:], list(ctrls.values())[:-1])])
# We add the regularisation term to the first functional term and define define the controls:
J = j + assemble(regularisation)
m = [Control(c) for c in ctrls.values()]
# Finally, we define the reduced functional and solve the optimisation problem:
rf = ReducedFunctional(J, m)
opt_ctrls = minimize(rf, options={"maxiter": 50})
from matplotlib import pyplot
x = [c((0.5, 0.5)) for c in opt_ctrls]
pyplot.plot(x, label="$\\alpha={}$".format(float(alpha)))
pyplot.ylim([-3, 3])
pyplot.legend()
pyplot.savefig("figure.png")
optc = OrderedDict()
t = float(dt)
for i in range(len(opt_ctrls)):
optc[t] = opt_ctrls[i]
t += float(dt)
solve_heat(optc, output=True)
