The residual is sent through the logger. thus, you cannot obtain it inside python, but you could simply pipe it:
python3 name_of_script.py > output.txt
results in
cat output.txt
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
Newton iteration 0: r (abs) = 1.776e+01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-06)
Newton iteration 1: r (abs) = 9.034e-03 (tol = 1.000e-10) r (rel) = 5.086e-04 (tol = 1.000e-06)
Newton iteration 2: r (abs) = 2.719e-04 (tol = 1.000e-10) r (rel) = 1.530e-05 (tol = 1.000e-06)
Newton iteration 3: r (abs) = 1.267e-07 (tol = 1.000e-10) r (rel) = 7.132e-09 (tol = 1.000e-06)
Newton solver finished in 3 iterations and 3 linear solver iterations.
Hi @dokken, I’m using Legacy Fenics through Docker. When I just redirect the stream (i.e. use >log.txt), my print statements and the residual information are out of order. Using the example above,
print('Performing first solve')
solve(F == 0, u, bc, solver_parameters={"newton_solver":
#{"relative_tolerance": 1e-6}})
print('Performing second solve')
Would print the newton iterations follow by the print statements, making it difficult to track which iterations correspond to which solve.
I thought I could get around this issue by using the log file. Do you know how to set the output log file? I’ve used the commands for setting logging from the documentation:
set_log_active(True)
set_log_level(LogLevel.INFO)
I also muted some output and tried to redirect the stream using the python logging package:
But the output from the nonlinear solver still ends up in the console.
The function set_output_stream() doesn’t seem to exists even though it is in the documentation. At a bit of a loss here. Will I just need to create a custom solver so that I can access my residuals?
Thanks for the reply, this is still outputting messages to console only for me and not the log file. I tried to add the specific log file for it to redirect to as well.
import logging
import sys
fh = logging.FileHandler("test.log", mode='w')
sh = logging.StreamHandler(sys.stdout)
logging.basicConfig(level=logging.DEBUG,
handlers=[fh,sh])
set_log_level(LogLevel.DEBUG)
mesh = UnitSquareMesh(10, 10)
logging.debug('Prints to log file')
