I am solving a hyperelastic problem. I have a domain on which I am applying pressure to minimize an energy functional. I increase the pressure using a loop. I want to save all solutions as separate xml files named with the loop index. For example, for loop i, the xml file will be solution_i.xml. I tried File('lumsoln%(d).xml'%(i))<<u2 in the below MWE, which returns the error:
TypeError: format requires a mapping
What “mapping” are we talking about here and how to fix this?
Also, is there a way to read solutions from pvd or vtk files?
Let’s consider the following MWE:
msh = meshio.read("mesh.msh")
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
xdmf = XDMFFile(mesh.mpi_comm(),"mesh.xdmf")
xdmf.read(mesh)
xdmf.close()
ds_custom = Measure("dS", domain=mesh, subdomain_data=mf)
dx_custom = Measure("dx", domain=mesh, subdomain_data=cf)
combined_subdomains_2 = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
combined_subdomains_2.array()[cf.array()==5] = 1 # Assigning same number for all the submeshes for compiling them into one submesh
combined_subdomains_2.array()[cf.array()==6] = 1
combined_subdomains_2.array()[cf.array()==7] = 1
mesh_ima_ref = SubMesh(mesh, combined_subdomains_2, 1)
boundary_marker_ima_ref = MeshFunction("size_t", mesh_ima_ref, mesh_ima_ref.topology().dim()-1, 0)
ncells_ref = MeshFunction("size_t", mesh_ima_ref, mesh_ima_ref.topology().dim())
surface_marker_ima_ref = MeshFunction("size_t", mesh_ima_ref, mesh_ima_ref.topology().dim(), 0)
vmap_ref = mesh_ima_ref.data().array("parent_vertex_indices", 0)
cmap_ref = mesh_ima_ref.data().array("parent_cell_indices", mesh_ima_ref.topology().dim())
n = 0
for c in cells(mesh_ima_ref):
parent_cell_ima_ref = Cell(mesh, cmap_ref[c.index()])
surface_marker_ima_ref.array()[c.index()] = cf.array()[parent_cell_ima_ref.index()]
for f in facets(parent_cell_ima_ref):
for g in facets(c):
g_vertices = vmap_ref[g.entities(0)]
if set(f.entities(0)) == set(g_vertices):
boundary_marker_ima_ref.array()[g.index()] = mf.array()[f.index()]
n=n+1
ds_ima_ref = Measure("ds", domain=mesh_ima_ref, subdomain_data=boundary_marker_ima_ref) # Defining global boundary measure, for global surface measure, plug in "dS" instead of "ds", which is used for subdomain boundary measures
dx_ima_ref = Measure("dx", domain=mesh_ima_ref, subdomain_data=surface_marker_ima_ref)
V_ima = VectorFunctionSpace(mesh_ima_ref, 'P', 1) # Changed to second order
W_ima_ref = FunctionSpace(mesh_ima_ref, 'P', 1)
T_ima = TensorFunctionSpace(mesh_ima_ref, 'P', 1)
initial_int_area = assemble(Constant(1.0)*dx_ima_ref(5))
initial_med_area = assemble(Constant(1.0)*dx_ima_ref(6))
initial_ad_area = assemble(Constant(1.0)*dx_ima_ref(7))
print('initial intima area =', assemble(Constant(1.0)*dx_ima_ref(5)))
print('initial media area =', assemble(Constant(1.0)*dx_ima_ref(6)))
print('initial adventitia area =', assemble(Constant(1.0)*dx_ima_ref(7)))
ug1 = Function(V_ima)
vg1 = TestFunction(V_ima)
# Elasticity parameters
nu = 0.4999
mu1, mu2, mu3 = 27.9, 1.27, 7.56
ds = 0.001
NumStepg = 51
for j in range(0,NumStepg):
tj = j*ds
dg = mesh_ima_ref.geometry().dim()
Ig = Identity(dg) # Identity tensor
Fg = Ig + grad(ug1) # Deformation gradient
g_1 = Expression((('1.0+p1*t1','0.0','0.0'),
('0.0','1.0+p2*t1','0.0'),
('0.0','0.0','1.0')),degree=1,p1=1.0,p2=1.0,t1=tj)
ginv = Expression((('1.0/(1.0+p1*t1)','0.0','0.0'),
('0.0','1.0/(1.0+p2*t1)','0.0'),
g_i = project(det(g_1),W_ima_ref)
Ce = (Fg*inv(g_1)).T*(Fg*inv(g_1)) # Right Cauchy-Green tensor for the Intima
Fe = Fg*ginv
Mg = cofac(Fg)
I1 = tr(Ce) # Ic for the Intima
Jg_e = det(Fg)
psig1 = (mu1/2)*(I1 - 3) + ((nu)*(mu1)/(1-2*nu))*(Jg_e-1)**2 - mu1*(ln(Jg_e))
psig2 = (mu2/2)*(I1 - 3) + ((nu)*(mu2)/(1-2*nu))*(Jg_e-1)**2 - mu2*(ln(Jg_e))
psig3 = (mu3/2)*(I1 - 3) + ((nu)*(mu3)/(1-2*nu))*(Jg_e-1)**2 - mu3*(ln(Jg_e))
Pig = (det(g_1))*psig1*dx_ima_ref(5) + psig2*dx_ima_ref(6) + psig3*dx_ima_ref(7)
# Compute first variation of Pi (directional derivative about u in the direction of v)
Fg1 = derivative(Pig, ug1, vg1)
bcgs_ima = []
ug1.set_allow_extrapolation(True)
# Solving variational problem
print(f"Solving for IMA displacement field at time T={tj}", flush=True)
solve(Fg1 == 0, ug1, bcgs_ima, solver_parameters={"newton_solver": {"relative_tolerance": 1e-8,
"absolute_tolerance": 1e-8,"maximum_iterations": 200}})
ug_ima = Function(V_ima)
ug_ima.assign(ug1)
ug1 = interpolate(ug_ima, V_ima)
File('lumsoln%(d).xml'%(j))<<u2
File('imasoln%(d).xml'%(j))<<u1
Any suggestions would be extremely helpful and would be greatly appreciated.
Thank you.
