How to set material property as a function of split unknown variable?
Hello Everyone,
I would like to base one material property as a function of one of the split variables (here temperature) of unknown. I read Material property depending on solution but I’m unable to implement that solution in my problem. I would like to vary varsigma as follows -
if x[1] < 0.5:
varsigma = a /(1.0 + b*(T - Tref ))
else :
varsigma = a*(1.0 + b*(T - Tref ))
And then update the value of T as time loop goes.
MWE -
domain = Rectangle(Point(0, 0),Point(1, 1))
mesh = generate_mesh(domain, 10)
Q = FiniteElement("CG", mesh.ufl_cell(), 1)
Space = FunctionSpace(mesh, MixedElement(Q, Q))
dunkn = TrialFunction(Space)
test = TestFunction(Space)
del_phi , del_T = split(test)
unkn = Function(Space)
unkn0 = Function(Space)
unkn_init = Expression(( '0.0' , 'T_ini' ) , degree = 0, T_ini=Tref )
unkn0 = interpolate(unkn_init , Space)
unkn = interpolate(unkn_init , Space)
phi , T = split(unkn)
phi0 , T0 = split(unkn0)
Any pointers, suggestions or help would be highly appreciable.
Thanks.
I would suggest using ufl.conditional, see for instance: Unable to use conditional module - #2 by dokken, Form compilation — FEniCS Tutorial @ Sorbonne or various other posts on the forum regarding conditionals.
Thanks for guidance and resources, after going through it, I wrote couple of lines -
x, y = SpatialCoordinate(mesh)
condition = lt(y, 0.5)
below = 1.*T
above = 1./T
varsigma = conditional(condition, below, above)
But running into the error -
True value of Condtional should only be one function: {((1, 'nzc3[k]', 3, 6),): Product([Symbol('FE0_C0[ip][k]', BASIS)])}
Exception                                 Traceback (most recent call last)
/tmp/ipykernel_3265/318594624.py in <module>
     29
     30 while t < tMax :
---> 31     solve(Form == 0,unkn,bc,J=Gain ,solver_parameters = solver_parameters,form_compiler_parameters = form_compiler_parameters)
     32     unkn0.assign(unkn)
     33     t += Dt
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py in solve(*args, **kwargs)
    231     # tolerance)
    232     elif isinstance(args[0], ufl.classes.Equation):
--> 233         _solve_varproblem(*args, **kwargs)
    234
    235     # Default case, just call the wrapped C++ solve function
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py in _solve_varproblem(*args, **kwargs)
    306
    307             # Create problem
--> 308             problem = NonlinearVariationalProblem(eq.lhs, u, bcs, J,
    309                                                   form_compiler_parameters=form_compiler_parameters)
    310
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/problem.py in __init__(self, F, u, bcs, J, form_compiler_parameters)
    157         F = Form(F, form_compiler_parameters=form_compiler_parameters)
    158         if J is not None:
--> 159             J = Form(J, form_compiler_parameters=form_compiler_parameters)
    160
    161         # Initialize C++ base class
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/form.py in __init__(self, form, **kwargs)
     41             form_compiler_parameters = {"external_include_dirs": dolfin_pc["include_dirs"]}
     42
---> 43         ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
     44                            mpi_comm=mesh.mpi_comm())
     45         ufc_form = cpp.fem.make_ufc_form(ufc_form[0])
/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py in mpi_jit(*args, **kwargs)
     48         # Just call JIT compiler when running in serial
     49         if MPI.size(mpi_comm) == 1:
---> 50             return local_jit(*args, **kwargs)
     51
     52         # Default status (0 == ok, 1 == fail)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py in ffc_jit(ufl_form, form_compiler_parameters)
     98     p.update(dict(parameters["form_compiler"]))
     99     p.update(form_compiler_parameters or {})
--> 100     return ffc.jit(ufl_form, parameters=p)
    101
    102
/usr/lib/python3/dist-packages/ffc/jitcompiler.py in jit(ufl_object, parameters, indirect)
    215
    216     # Inspect cache and generate+build if necessary
--> 217     module = jit_build(ufl_object, module_name, parameters)
    218
    219     # Raise exception on failure to build or import module
/usr/lib/python3/dist-packages/ffc/jitcompiler.py in jit_build(ufl_object, module_name, parameters)
    128
    129     # Carry out jit compilation, calling jit_generate only if needed
--> 130     module, signature = dijitso.jit(jitable=ufl_object,
    131                                     name=module_name,
    132                                     params=params,
/usr/lib/python3/dist-packages/dijitso/jit.py in jit(jitable, name, params, generate, send, receive, wait)
    163         elif generate:
    164             # 1) Generate source code
--> 165             header, source, dependencies = generate(jitable, name, signature, params["generator"])
    166             # Ensure we got unicode from generate
    167             header = as_unicode(header)
/usr/lib/python3/dist-packages/ffc/jitcompiler.py in jit_generate(ufl_object, module_name, signature, parameters)
     63         compile_object = compile_coordinate_mapping
     64
---> 65     code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
     66             prefix=module_name, parameters=parameters, jit=True)
     67
/usr/lib/python3/dist-packages/ffc/compiler.py in compile_form(forms, object_names, prefix, parameters, jit)
    140                  prefix="Form", parameters=None, jit=False):
    141     """This function generates UFC code for a given UFL form or list of UFL forms."""
--> 142     return compile_ufl_objects(forms, "form", object_names,
    143                                prefix, parameters, jit)
    144
/usr/lib/python3/dist-packages/ffc/compiler.py in compile_ufl_objects(ufl_objects, kind, object_names, prefix, parameters, jit)
    188     # Stage 2: intermediate representation
    189     cpu_time = time()
--> 190     ir = compute_ir(analysis, prefix, parameters, jit)
    191     _print_timing(2, time() - cpu_time)
    192
/usr/lib/python3/dist-packages/ffc/representation.py in compute_ir(analysis, prefix, parameters, jit)
    180     # Compute and flatten representation of integrals
    181     info("Computing representation of integrals")
--> 182     irs = [_compute_integral_ir(fd, form_id, prefix, element_numbers, classnames, parameters, jit)
    183            for (form_id, fd) in enumerate(form_datas)]
    184     ir_integrals = list(chain(*irs))
/usr/lib/python3/dist-packages/ffc/representation.py in <listcomp>(.0)
/usr/lib/python3/dist-packages/ffc/representation.py in _compute_integral_ir(form_data, form_id, prefix, element_numbers, classnames, parameters, jit)
    453
    454         # Compute representation
--> 455         ir = r.compute_integral_ir(itg_data,
    456                                    form_data,
    457                                    form_id,     # FIXME: Can we remove this?
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturerepresentation.py in compute_integral_ir(itg_data, form_data, form_id, element_numbers, classnames, parameters)
    102     # Transform integrals.
    103     cell = itg_data.domain.ufl_cell()
--> 104     ir["trans_integrals"] = _transform_integrals_by_type(ir, transformer,
    105                                                          integrals_dict,
    106                                                          itg_data.integral_type,
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturerepresentation.py in _transform_integrals_by_type(ir, transformer, integrals_dict, integral_type, cell)
    180         info("Transforming cell integral")
    181         transformer.update_cell()
--> 182         terms = _transform_integrals(transformer, integrals_dict, integral_type)
    183
    184     elif integral_type == "exterior_facet":
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturerepresentation.py in _transform_integrals(transformer, integrals, integral_type)
    227     for point, integral in sorted(integrals.items()):
    228         transformer.update_points(point)
--> 229         terms = transformer.generate_terms(integral.integrand(), integral_type)
    230         transformed_integrals.append((point, terms, transformer.function_data,
    231                                       {}, transformer.coordinate,
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturetransformerbase.py in generate_terms(self, integrand, integral_type)
    805
    806         # Get terms
--> 807         terms = self.visit(integrand)
    808
    809         # Get formatting
/usr/lib/python3/dist-packages/ufl/algorithms/transformer.py in visit(self, o)
     97         if visit_children_first:
     98             # Yes, visit all children first and then call h.
---> 99             r = h(o, *[self.visit(op) for op in o.ufl_operands])
    100         else:
    101             # No, this is a handler that handles its own children
/usr/lib/python3/dist-packages/ufl/algorithms/transformer.py in <listcomp>(.0)
    100         else:
    100         else:
    100         else:
    100         else:
    100         else:
    100         else:
    100         else:
    102             # (arguments self and o, where self is already bound)
--> 103             r = h(o)
    104
    105         # Update stack and return
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturetransformerbase.py in index_sum(self, o)
    591         for i in range(o.dimension()):
    592             self._index2value.push(index, i)
--> 593             ops.append(self.visit(summand))
    594             self._index2value.pop()
    595
    100         else:
    100         else:
    100         else:
    100         else:
--> 103             r = h(o)
    104
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturetransformerbase.py in indexed(self, o)
    556
    557         # Visit expression subtrees and generate code.
--> 558         code = self.visit(indexed_expr)
    559
    560         # Remove component again
--> 103             r = h(o)
    104
/usr/lib/python3/dist-packages/ffc/quadrature/quadraturetransformerbase.py in component_tensor(self, o)
    760
    761         # Visit expression subtrees and generate code.
--> 762         code = self.visit(component_expr)
    763
    764         # Remove the index map from the StackDict
    100         else:
    100         else:
    100         else:
    100         else:
    100         else:
    100         else:
    100         else:
/usr/lib/python3/dist-packages/ffc/quadrature/optimisedquadraturetransformer.py in conditional(self, o, *operands)
    253         ffc_assert(len(cond) == 1 and firstkey(cond) == (),
    254                    "Condtion should only be one function: " + repr(cond))
--> 255         ffc_assert(len(true) == 1 and firstkey(true) == (),
    256                    "True value of Condtional should only be one function: " + repr(true))
    257         ffc_assert(len(false) == 1 and firstkey(false) == (),
/usr/lib/python3/dist-packages/ffc/log.py in ffc_assert(condition, *message)
     44 def ffc_assert(condition, *message):
     45     "Assert that condition is true and otherwise issue an error with given message."
---> 46     condition or error(*message)
     47
     48
/usr/lib/python3/dist-packages/ffc/log.py in <lambda>(*message)
/usr/lib/python3/dist-packages/ufl/log.py in error(self, *message)
    156         "Write error message and raise an exception."
    157         self._log.error(*message)
--> 158         raise self._exception_type(self._format_raw(*message))
    159
    160     def begin(self, *message):
Exception: True value of Condtional should only be one function: {((1, 'nzc3[k]', 3, 6),): Product([Symbol('FE0_C0[ip][k]', BASIS)])}
Here is the MWE to reproduce the error -
from ufl import indices
parameters["form_compiler"]["representation"] = 'quadrature'
parameters["form_compiler"]["representation"] = "tsfc"
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("ignore", QuadratureRepresentationDeprecationWarning)
N = FacetNormal(mesh)
Vector = VectorFunctionSpace(mesh , 'P' , 1)
Tensor = TensorFunctionSpace(mesh , 'P' , 1)
Vs = [Scalar , Scalar]
cells = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
facets = MeshFunction("size_t", mesh, mesh.topology().dim()-1, 0)
da = Measure( 'ds' , domain=mesh , subdomain_data=facets)
dv = Measure( 'dx' , domain=mesh , subdomain_data=cells)
left = CompiledSubDomain( "near(x[0] , l ) && on_boundary" , l=0.)
right = CompiledSubDomain( "near(x[0] , l ) && on_boundary" , l=1.)
facets.set_all(0)
bc = [ DirichletBC(Space.sub(0) , 0.0 , left) , DirichletBC(Space.sub(0) , 0.1 ,right)]
Tref = 300.
Tamb = Tref
t_alpha = 3.9*(10**-3)
varsigma0 = 5.8*(10**+7)
rho = 8960.
kappa = 400.0
capacity = 390.
h = 10.
tMax = 2500.0
Dt = 50.0
t = 0.0
i,j,k,l = indices(4)
delta = Identity(3)
below = 1.*T
above = 1./T
J = -varsigma*grad(phi)
q = -kappa*grad(T)
r = Constant(0.0)
Form = (-J[i]*del_phi.dx(i) + rho*capacity*(T - T0)/Dt*(del_T/T)\
        - q[i]*(del_T/T).dx(i) - rho*r*(del_T/T) + J[i]*phi.dx(i)*(del_T/T))*dv\
        + h*(T - Tamb)*(del_T/T)*da
Gain = derivative(Form , unkn , dunkn)
solver_parameters = {
    "newton_solver": {
        "linear_solver": "umfpack",
        "relative_tolerance": 1e-5
    "cpp_optimize": True,
    "representation": "quadrature",
    "quadrature_degree": 2
while t < tMax :
    unkn0.assign(unkn)
    t += Dt
Any further suggestions would be very much helpful.
Projecting the conditional on DG space did the trick. Thanks Dokken.
W = FunctionSpace(mesh, "DG", 0)
below = 1.*T
above = 1./T
vary = conditional(condition, below, above)
varsigma = project(vary, W)
I cannot reproduce the error with a simplified version of your code:
from ufl_legacy import indices
kappa = 400.0
rho = 8960.
capacity = 390.
Dt = 50.0
h = 10.
Tref = 300.
Tamb = Tref
mesh = UnitSquareMesh(10, 10)
dv = Measure('dx', domain=mesh)
da = Measure('ds', domain=mesh)
unkn_init = Expression(('0.0', 'T_ini'), degree=0, T_ini=Tref)
unkn0.interpolate(unkn_init)
unkn.interpolate(unkn_init)
i, j, k, l = indices(4)
phi, T = split(unkn)
phi0, T0 = split(unkn0)
del_phi, del_T = split(test)
delta = Identity(3)
below = 1.*T
above = 1./T
q = -kappa*grad(T)
r = Constant(0.0)
left = CompiledSubDomain("near(x[0] , l ) && on_boundary", l=0.)
right = CompiledSubDomain("near(x[0] , l ) && on_boundary", l=1.)
bc = [DirichletBC(Space.sub(0), 0.0, left),
      DirichletBC(Space.sub(0), 0.1, right)]
Dt = 50.0
t = 0
for i in range(2):
    solve(Form == 0, unkn, bc)
    unkn0.assign(unkn)
    t += Dt
Thanks Dokken, I should have tried a simpler version.
One doubt -
Is it appropriate to use projected values ?
No, as you then decouple it from the unknown function in your system.
Okay, thanks for the reply.
