How to set up an integration loop to determine the moment at each cross section of 3D hexahedral beam?
dolfinx 0.8.0…
This is the gist example:
from dolfinx import mesh, fem, io, default_scalar_type
L = 120.0         # Beam length in inches
W = 4.0           # Cross-sectional width (and height here; for a square beam)
E = 2000000.0     # Young's modulus in psi
nu = 0.3          # Poisson's ratio
mu = E/(2*(1+nu))
lambda_ = (E * nu) / ((1 + nu) * (1 - 2 * nu))
rho = 30.0/12**3  # Density in lb/in^3 (converted from 30 lb/ft^3)
w_load = -50.0  # lbs/in along the beam length
w_vol = w_load / L / (W*W)
delta = W / L
gamma = 0.4 * delta**2
g = gamma
f_body_total = (0, 0, w_vol + (-rho * g))
domain = mesh.create_box(MPI.COMM_WORLD,
                         [np.array([0, 0, 0]), np.array([L, W, W])],
                         [20, 6, 6],
                         cell_type=mesh.CellType.hexahedron)
def clamped_boundary(x):
    return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D,
                     fem.locate_dofs_topological(V, fdim, boundary_facets),
                     V)
    return ufl.sym(ufl.grad(u))
def sigma(u):
u_trial = ufl.TrialFunction(V)
v_test  = ufl.TestFunction(V)
a = ufl.inner(sigma(u_trial), epsilon(v_test)) * ufl.dx
L_form = ufl.dot(fem.Constant(domain, default_scalar_type(f_body_total)), v_test) * ufl.dx \
         + ufl.dot(T, v_test) * ds
problem = LinearProblem(a, L_form, bcs=[bc],
                        petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
print("Displacement field (array):", uh.x.array)
print("Minimum displacement:", min(uh.x.array))
This is the second part of the gist that integrates:
x_sections = [0.0, 6.0, 120.0]
print("Cross-sectional positions (inches):", x_sections)
tol = 0.5
bending_moments = []
u = fem.Function(V, name="Displacement")
for x_sec in x_sections:
    def facets_at_xsec(x):
        return np.isclose(x[0], x_sec, atol=tol)
    facets = mesh.locate_entities(domain, 2, facets_at_xsec)
    print(facets)
    if len(facets) == 0:
        print(f"No cells found near x = {x_sec}")
        bending_moments.append(0.0)
        continue
    markers = np.full(len(facets), 1, dtype=np.int32)
    cell_tags = mesh.meshtags(domain, domain.topology.dim, facets, markers)
    dx_section = ufl.Measure("dx", domain=domain, subdomain_data=cell_tags)
    z_c = W / 2
    X = ufl.SpatialCoordinate(domain)
    z = X[2]
    sigma_xx = sigma(uh)[1, 1]
    My_integrand = (z - z_c) * sigma_xx
    My_form = My_integrand
    My = fem.assemble_scalar(fem.form(My_form * ds(dx_section)))
    bending_moments.append(My)
    print(f"Bending moment M_y at x = {x_sec} is approximately: {My} in-lb")
In regards to the second part that integrates, sigma(uh) has a ufl.shape of (3,)… I have these components to go by as a reference so far:
  • σₓₓ = σ(u)[0, 0]
  • σₓᵧ = σ(u)[0, 1]
  • σₓ𝓏 = σ(u)[0, 2]
  • σᵧₓ = σ(u)[1, 0]
  • σᵧᵧ = σ(u)[1, 1]
  • σᵧ𝓏 = σ(u)[1, 2]
  • σ𝓏ₓ = σ(u)[2, 0]
  • σ𝓏ᵧ = σ(u)[2, 1]
  • σ𝓏𝓏 = σ(u)[2, 2]
Output:
Displacement field (array): [ 0.00000000e+00  0.00000000e+00  0.00000000e+00 ...  2.99149928e-03
 -2.21514691e-08 -1.34378060e-01]
Minimum displacement: -0.13437807301956423
Cross-sectional positions (inches): [0.0, 6.0, 120.0]
[  2   8  14  20  38  44  50  56  86  92  98 104 110 155 161 167 173 179
 185 248 254 260 266 272 278 284 372 378 384 390 496 502 508 623 629 752]
Bending moment M_y at x = 0.0 is approximately: 134022.83141157418 in-lb
[  3  10  16  23  40  47  52  59  88  95 101 106 113 157 164 170 176 181
 188 250 257 263 269 275 280 287 375 381 387 393 499 505 511 626 632 755]
Bending moment M_y at x = 6.0 is approximately: 134022.83141157418 in-lb
[1960 1961 1962 1963 2072 2073 2074 2075 2172 2173 2174 2175 2176 2258
 2259 2260 2261 2262 2263 2327 2328 2329 2330 2331 2332 2333 2376 2377
 2378 2379 2406 2407 2408 2424 2425 2433]
Bending moment M_y at x = 120.0 is approximately: 134022.83141157418 in-lb
So I have the same moment coming out @ each individual section. The ending cell numbers are 752,755,2433 of the tree sections in question…I also tried to use sigma(uh)[1,1] however I have the same difficulty with the same quantity coming out at each section.
Why is the quantity being computed always the same, shouldn’t it be changing at each cross section? Could it be explained how to use the stress components correctly in this scenario to obtain a proper moment at each cross section?
As far as I know the moment at the free end should be about -3000.0 inch/lbs approximately… That’s by the formula w=-50.0 * x=120.0**2 /2… which is the American Wood Council’s version of things where w=lbs/inch x=length in inches…
The latter bit here doesn’t make sense to me. ds(dx_section) where
and
What is this trying to represent?
Secondly,
these are facets, but then you treat them as cells:
Without a clearer code, it’s hard to understand what you are trying to achieve. I think (please correct me if I’m wrong) that you are trying to compute an integral over a slice of the box, for varying x-component. Is that the correct interpretation?
Based from the formula:
\int_A \tau + z :: dA = M
(description: The shear force with is the force normal to the facets of the cross section inegrated over the area of the cross section is equal to the moment of force of the cross sectional area, where z, is distance away from the centroid of the cross sectional area. As far as I know…)
More clear code:
x_sections = [120.0-6.0, 120.0]
u = fem.Function(V, name="Displacement")  # Initialize u
        return np.isclose(x[0], x_sec, atol=1e-6)
        print(f"No facets found near x = {x_sec}. Skipping.")
        continue
    facet_tags = mesh.meshtags(domain, 2, facets, markers)
    ds_section = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags, subdomain_id=1)
    z = X[2] - W/2
    sigma_xx = sigma(uh)[0, 0] * L
    My = fem.assemble_scalar(fem.form(sigma_xx * z * ds_section))
    print(f"Bending moment M_y at x = {x_sec} inches: {My}")
description: the x-axis is the directional of L, therfore sigma_xx, should be the force normal to the facets of the cross section. The z-axis is the height of the cross section, as per the direction of the load, therefore the z-axis must be a classical up-down axis. Therefore z, should be a distance away from the centroid of the cross sectional area, (in this case the half height distance of the height of the cross section away from its centroid)
z = X[2] - W/2 # supporting statement
# ds_section seems to be correct to me at this time...
description: A UFL measure to integrate the surface of the cross section as described, now renamed, with some renamed parameters to discuss and use facets, as denoted in the last message:
   # dimension '2' here for facets...
OK…x_sections = [120.0-6.0, 120.0], for simplicity two cross sectional areas to look at. Here is my best attempt to set up the forces:
w_load = -50.0
w_vol = w_load / (20*6*6) # My attempt to assign a per node force
# 20,6,6 are the Nx,Ny,Nz or divisions of the box...
Output:
Displacement field (array): [ 0.00000000e+00  0.00000000e+00  0.00000000e+00 ...  5.74197729e+00
 -4.25182231e-05 -2.57929453e+02]
Minimum displacement: -257.929476648926
d_max:-0.151875
Bending moment M_y at x = 114.0 inches: 0.0
Bending moment M_y at x = 120.0 inches: 603735.621261901
… I have a too huge displacement, which should be equal to d_max=-0.15±… … same thing with Bending moment M_y at x = 120.0 inches: 603735.621261901, its way too high…
…Bending moment M_y at x = 114.0 inches: 0.0 … … it shouldn’t be… so far I would expect to see some moment there less than the free end…
There are some adjustments to make I’m sure…
What are the problems here in terms of matching the theoretical values? What is the cause for the 0 moment @ the cross section 120.0-6.0? Is the computation for My anywhere where it should be in terms of the formula applied?
P.S. This worked for me as far as distributing a load on a per node basis to get the displacements to match the theoretical, (still there is some issues to work out to get the moment to come out of the system correctly):
# [40, 12, 12] Nx,Ny,Nz divisions...
def distribute_load(domain, load_per_node, V):
    f = fem.Function(V)
    f.x.array[:] = 0.0  # Initialize to zero
    for i in range(num_nodes):
        f.x.array[i*3 + 2] = load_per_node  # Apply load in z-direction, accounting for 3 components per node
    return f
f = distribute_load(domain, 1.04, V)
Also this was the 2D formulation:
    sgn = sigma(u) * n
    ufl_vec = ufl.as_vector([x_pos, 3.9])
    My = fem.assemble_scalar(fem.form(cross_2D(ufl_vec, sigma(u) * n) * ds(ds_section)))
So here above there is a normal vector… Should there be a normal vector to integrate the cross section in 3D? Should there be some integration over the volume to integrate the cross section in 3D properly?
