How to solve Poisson on the surface of a manifold?
Hi. I am struggling with implementing the Poisson equation on the surface of a sphere. In essence I want to solve the equation on a 2D manifold embedded in 3D. The equation is -\bigtriangleup_\Gamma u = f for some f, where \Gamma is the manifold. The problem I have is that the results that FEniCS computes are too large to be correct and hence I get a very large L^2 norm error compared to the correct solution.
The case below in my code is for a sphere with f=2\sin^2\theta (where \theta is the azimuth in spherical coordinates). I used the contravariant Piola transformation to bound the problem to tangential space.
global_normal = Expression(("x[0]", "x[1]", "x[2]"), degree=3)
mesh.init_cell_orientations(global_normal)
order = 3
# Defining the exact solution and approximation spaces
Ve = VectorFunctionSpace(mesh, "Lagrange", order+1)
mesh_cell = ufl.Cell(mesh.cell_name(), geometric_dimension=mesh.geometry().dim())
V = FiniteElement("RT", mesh_cell, order)
Q = FiniteElement("DG", mesh_cell, order-1)
element = MixedElement([V, Q])
W = FunctionSpace(mesh, element)
(sigma, u) = TrialFunctions(W)
(tau, v) = TestFunctions(W)
x = SpatialCoordinate(mesh)
# Functions for the problem
theta = acos(x[2])
phi = atan(x[1]/x[0])
f = -2*pow(sin(theta), 2) # Expression("-2*pow(sin(theta),2)", theta=theta, degree=2)
# Solutions
u_sol = sin(theta)*sin(phi)
sigma_sol = Expression((("1-x[0]*x[0]", "-x[0]*x[1]", "-x[0]*x[2]"), ("-x[1]*x[0]", "1-x[1]*x[1]", "-x[1]*x[2]"), ("-x[2]*x[0]", "-x[2]*x[1]", "1-x[2]*x[2]")), degree=3)*grad(u_sol)
# The Forms
a = (inner(tau, sigma) - div(tau)*u + div(sigma)*v)*dx
L = (f*v)*dx
# Solving the problem
uv = Function(W)
solve(a==L, uv)
(sigma, u) = uv.split()
# Computing errors
L2_error_u = errornorm(Expression(str(u_sol), degree=5), u, "L2", degree_rise=1, mesh=mesh)
print(L2_error_u)
I’m sorry for the long code but I don’t know where the error could lie. Any help will be very much appreciated.
One issue that stands out immediately is that there is nothing constraining the space of constant functions. If u is a solution to -\Delta u = f on a sphere with no boundaries, then u + C is as well, for arbitrary C\in\mathbb{R}. Thus, there is no unique solution without imposing some auxiliary constraint, such as a DirichletBC acting on a single degree of freedom, or a global constraint on the average value (as demonstrated here).
@kamensky thank you so much for your reply. I implemented some constraints by increasing the number of trial functions and test functions to get the following form
a = (inner(tau, sigma) + div(tau)*u + div(sigma)*v + r*v + t*u)*dx
But I have read a paper that seems to imply that this should be the way I should do the calculation on any mesh with geometric dimension 3 and topological dimension 2:
a = inner(grad(u), grad(v))*dx
This on the other hand gives me very strange results. Do you know what the correct way to implement it is?
The second formulation, a = inner(grad(u),grad(v))*dx, also requires an additional constraint to have a unique solution. It’s also possible you may have forgotten to switch the space for u to a continuous Galerkin space ("CG") when testing the second formulation; it would be ill-posed with the DG space used for u and v in your mixed formulation, and would produce strange results, if any.
