Hi guys, I am a new Fenics user. I am trying to solve a Poisson equation with PBC. However, I got the same value of my solution. May I ask what kind of mistakes I made?
a = 1e-7
L = 1e-7
num_points = 30
x = np.linspace(-L/2, L/2, num_points, endpoint=False)
y = np.linspace(0, L, num_points, endpoint=False)
z = np.linspace(0, L, num_points, endpoint=False)
X, Y, Z = np.meshgrid(x, y, z, indexing='ij')
# Gaussian width
sigma = L / (1*num_points) # Adjust as needed
rho_array = np.zeros((num_points, num_points, num_points))
# Coordinates for the 10 point charges on the x=0 plane
charge_positions = np.random.rand(10, 3) * 1e-7
charge_positions[:,0] = 0
#charge_positions = np.array([[0, 0, 0]])
# For each charge, add a Gaussian distribution centered at its position
for charge_pos in charge_positions:
x_pos, y_pos, z_pos = charge_pos
r2 = (X-x_pos)**2 + (Y - y_pos)**2 + (Z - z_pos)**2
delta_approx = (1 / (np.pi**(3/2) * sigma**3)) * np.exp(-r2 / sigma**2)
rho_array += delta_approx
rho_array = np.roll(rho_array, shift=-num_points//2, axis=0)
rho_array = rho_array * 2.26e-10
# Left boundary is "target domain" G
# return True if on left or bottom boundary AND NOT on one of the two slave edges
return bool ((near(x[0], 0) or near(x[1], 0) or near(x[2], 0)) and
(not ((near(x[0], a) and near(x[2], a)) or
(near(x[0], a) and near(x[1], a)) or
(near(x[1], a) and near(x[2], a)))) and on_boundary)
# Map right boundary (H) to left boundary (G)
def map(self, x, y):
#### define mapping for a single point in the box, such that 3 mappings are required
if near(x[0], a) and near(x[1], a) and near(x[2],a):
y[0] = x[0] - a
y[1] = x[1] - a
y[2] = x[2] - a
##### define mapping for edges in the box, such that mapping in 2 Cartesian coordinates are required
if near(x[0], a) and near(x[2], a):
y[0] = x[0] - a
y[1] = x[1]
y[2] = x[2] - a
elif near(x[1], a) and near(x[2], a):
y[0] = x[0]
y[1] = x[1] - a
y[2] = x[2] - a
elif near(x[0], a) and near(x[1], a):
y[0] = x[0] - a
y[1] = x[1] - a
y[2] = x[2]
#### right maps to left: left/right is defined as the x-direction
elif near(x[0], a):
y[0] = x[0] - a
y[1] = x[1]
y[2] = x[2]
### back maps to front: front/back is defined as the y-direction
elif near(x[1], a):
y[0] = x[0]
y[1] = x[1] - a
y[2] = x[2]
#### top maps to bottom: top/bottom is defined as the z-direction
elif near(x[2], a):
y[0] = x[0]
y[1] = x[1]
y[2] = x[2] - a
mesh = BoxMesh(Point(0, 0, 0), Point(L, L, L), num_points, num_points, num_points)
PBC = PeriodicBoundary()
V = FunctionSpace(mesh, 'Lagrange', 1, constrained_domain=PBC)
phi = TrialFunction(V)
rho = Function(V)
rho.vector().set_local(rho_array.flatten())
rho.vector().apply('insert')
#rho = Constant(1)
a = dot(grad(phi), grad(v))*dx
l = rho*v*dx
phi_solution = Function(V)
solve(a == l, phi_solution)
phi_values = phi_solution.vector().get_local()
