How to use a numpy matrix to define the conductivity
Hi everyone,
I’m trying to use Fenics to solve the diffusion equation: grad(*kgrad(u)) = 0**
In my situation, k is a scalar field defined from a given numpy matrix M as following:
k = Expression(‘M[int(x[0]*nx/l),int(x[1]*ny/h)’, M=M, nx=nx, ny=ny, l=l, h=h)
This is not working as M is not recognized by C++ I guess.
Can anyone help me to solve this issue?
Kind regards
Welcome to the community!
Your code shouldn’t compile. For one, there’s the missing closing square bracket in M[... and you should need to supply the either the degree or the element argument to Expression.
There’s a recent thread where @kamensky posted the most recent solution on how to pass a numpy array to an Expression:
You may be able to circumvent the hassle by defining k as a Function and manually setting the values at the DOFs as described here:
http://home.simula.no/~hpl/homepage/fenics-tutorial/release-1.0-nonabla/webm/materials.html
Hi Klunkean,
Thank you!
I found these two lines of code which enable you to assign a numpy array M to a Dolfi vector in a simple manner. Each element of M corresponds to the physical value of a given scalar field (permeability for instance ) at each node.
k = Function(V)
k.vector()[:] = M
M is a numpy array of shape (n, ) with n denotes the number of elements.
Regards
This is of course assuming the ordering of your matrix elements corresponds to the dof ordering in k.
And from the information you supplied I assumed your matrix had 2 columns and as many rows as you have elements in a 1D domain. Then your method actually shouldn’t work straight away. But glad it works for you.
Also consider using DG0 elements for the function space of k if you want cell-wise constant values in k.
Good day Klunkean,
I’m glad to hear from you.
This is perfectly working for me. I actually get the coordinates of the elements using the command:
V.tabulate_dof_coordinates()
Then I use these coordinates to convert my initial 2D matrix into a 1D vector corresponding to the same ordering of K.
I will have a look on DG0. I feel it’s doing the same thing I’m doing, but in a simpler fashion :smiley:
Have a good day!
