Hello everyone!
I’m working with ubuntu 18.04 and Fenics to solve the 2D Possion equation, and the code is as follows:
import dolfin as df
Create mesh and define function space
mesh = df.UnitSquareMesh(6, 4)
V = df.FunctionSpace(mesh, “Lagrange”, 1)
Define boundary conditions
u0 = df.Expression(“1 + x[0]x[0] + 2 x[1]*x[1]”, degree =2)
def u0_boundary(x, on_boundary):
return on_boundary
bc = df.DirichletBC(V, u0, u0_boundary)
Define variational problem
u = df.TrialFunction(V)
v = df.TestFunction(V)
f = df.Constant(-6.0)
a = df.inner(df.nabla_grad(u), df.nabla_grad(v))* df.dx
L = fv df.dx
A = df.PETScMatrix()
b = df.PETScVector()
A = df.assemble(a)
b = df.assemble(L)
bc.apply(A, b)
u =df. Function(V)
U = u.vector()
#df .solve(A, U, b, ‘cg’, ‘ilu’)
solver = df.KrylovSolver(“cg”, “ilu”)
solver.parameters[“absolute_tolerance”] = 1e-17
solver.parameters[“relative_tolerance”] = 1e-4
solver.parameters[“maximum_iterations”] = 1000
solver.parameters[“error_on_nonconvergence”] = True
solver.parameters[“report”] = True
solver.solve(A, U, b)
Compute solution
file = df.File(“poisson-1.pvd”)
file << u
and now I want to output the PETScMatrix A in the form like the figure, but when I tried the function MatView in PETSc library, but it seems the function isn’t existing. Can anyone tell me how could I do to achieve the goal?
dokken
December 12, 2022, 3:08pm
2
You need to call A.mat() to get the petsc4py matrix object with its functionality.
Please note that for further questions, please use markdown format to encapsulate your code i.e.
```python
import dolfin as df
def some_function(x):
return x
# Replace this with code
Hello! Based on the given advice, I tried:
A.mat().MatView()
but it reminded me that AttributeError: ‘dolfin.cpp.la.Matrix’ object has no attribute ‘mat’, then what should I do for this condition
dokken
December 13, 2022, 6:08am
4
Do as_backend(A) first.
When you get error messages please supply a minimal example that reproduces the error. Without a minimal example it becomes educated guessing from other people what’s gone wrong.
The code is changed as:
PetSc.MatView(A.mat())
After running the code above, it reminded me that "AttritbuteError: module ‘petsc4py.PETSc’ has no attribute ‘MatView’ ". The output error is the same when using:
import petsc4py
petsc4py.MatView(A.mat())
or
import dolfin as df
df.MatView(A.mat())
dokken
December 13, 2022, 8:46am
6
Again, please make a minimal reproducible example.
In the snippets above, you have not defined A, so I cannot help you reproducing your issue.
MatView is a function from PETSc (petsc4py,src/binding/petsc4py/src/PETSc/Mat.pyx · main · PETSc / petsc · GitLab ), working in a PETSc matrix. Thus you would need something like:
from dolfin import PETScMatrix, as_backend_type
A = PETScMatrix()
A_petsc = as_backend_type(A).mat()
A_petsc.assemble()
A_petsc.view()
Hello! I retried the process based on your suggestion, and the code is as follows:
import dolfin as df
V = df.FunctionSpace(mesh, "Lagrange", 1)
# Define boundary conditions
u0 = df.Expression("1 + x[0]*x[0] + 2*x[1]*x[1]", degree =2)
return on_boundary
L = f*v*df.dx
A = PETScMatrix()
A_petsc = as_backend_type(A.mat())
A_petsc.assemble(a)
A_petsc.view()
While it only output an error as follows, instead in the form of the figure in the below.
TypeError Traceback (most recent call last)
/tmp/ipykernel_27380/3677198767.py in <cell line: 3>()
1 A = PETScMatrix()
2 A_petsc = as_backend_type(A.mat())
----> 3 A_petsc.assemble(a)
4 A_petsc.view()
PETSc/Mat.pyx in petsc4py.PETSc.Mat.assemble()
PETSc/petscmat.pxi in petsc4py.PETSc.assemblytype()
TypeError: an integer is required
dokken
December 15, 2022, 5:32am
8
adamson-lkx:
A_petsc.assemble(a)
I never said you should add a here.
This whole step should be replaced by your normal assembly.
Actually, I haven’t truly understand what you mean since I know too less. But I also tried without a in the function, and it returns a message that:
Mat Object: 1 MPI processes
type not yet set
instead the matrix content I needed in the form of the figure.
