Dear FEniCS community
I’m a new user of the FEniCS library. I would really appreciate your help.
I’m trying to implement the variational formulation reported in this article:A structural model for the viscoelastic behavior of arterial walls: Continuum formulation and finite element analysis - ScienceDirect
The variational reported in the article is for a hyperelastic fiber-reinforced material with viscoelasticity
In this first version of the code, I only try to solve the hyperelastic problem.
I looked for a solution in the several topics open in the blog, which helped me a lot in setting the boundary condition, but the problem with the variational formulation still remains.
Here I reported my code:
from dolfinx import *
from dolfinx.io import gmshio
import pyvista
import math
import os
import sys
import pyvista
from dolfinx import mesh, fem, plot, default_scalar_type, log
#Create the mesh
length = 10
width = 4
depth = 2
num_ele_along_depth = 4
size_ele = depth/num_ele_along_depth
print(f"Dimensione elementi : {size_ele}")
n = [int(length/size_ele), int(width/size_ele), int(depth/size_ele)]
print(f"Numero elementi lungo x: {n[0]} \nNumero elementi lungo y: {n[1]} \nNumero elementi pungo z : {n[2]}")
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([length, width, depth])], n, cell_type=mesh.CellType.hexahedron)
print("Ho creato il mio dominio trave 3D")
print(domain)
print(f"Numero di vertici: {domain.topology.index_map(0).size_local}")
print(f"Numero di elementi: {domain.topology.index_map(domain.topology.dim).size_local}")
print(f"Dimensione topologica: {domain.topology.dim}") # Dovrebbe stampare 3
print(f"Dimensione geometrica: {domain.geometry.dim}") # Dovrebbe stampare 3
#Visualization of domain
import pyvista as pv
from dolfinx import plot
topology, cell_types, geometry = plot.vtk_mesh(domain)
grid = pv.UnstructuredGrid(topology, cell_types, geometry)
plotter = pv.Plotter()
plotter.add_text("Definizione della mesh della trave 3D", position="upper_edge", font_size=12, color="blue")
plotter.view_isometric()
plotter.show_axes()
if not pyvista.OFF_SCREEN:
plotter.show()
figure = plotter.screenshot("Image_domain_3D.png")
#Create mixed element
Ue = element("CG", domain.ufl_cell().cellname(), 2, shape=(3,)) #Displacement
Pe = element("CG", domain.ufl_cell().cellname(), 1) #Pressure
Je = element("CG", domain.ufl_cell().cellname(), 1) #Volumetric strain
Me = mixed_element([Ue, Pe, Je])
print("Ho creato gli elementi mixati")
#Create function space
U = fem.functionspace(domain, Ue)
P = fem.functionspace(domain, Pe)
J = fem.functionspace(domain, Je)
print(f"Function spaces created: {U}, {P}, {J}")
M = fem.functionspace(domain, Me)
print(f"Function space created: {M}")
#Definizione delle condizioni a contorno
tdim = domain.topology.dim
def boundary_fixed(x):
return np.isclose(x[0], 0)
fixed_facets = mesh.locate_entities_boundary(domain, fdim, boundary_fixed)
marked_facets = np.hstack(fixed_facets)
marked_values = np.hstack(np.full_like(fixed_facets, 1))
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
u_fixed = np.array((0,) * domain.geometry.dim, dtype=default_scalar_type)
fixed_dofs = fem.locate_dofs_topological(U, facet_tag.dim, facet_tag.find(1))
bcs = [fem.dirichletbc(u_fixed, fixed_dofs, U)]
domain.topology.create_connectivity(fdim, 0) # Ensure facet-to-node connectivity
facet_to_vertex = domain.topology.connectivity(fdim, 0)
# Extract all unique node indices from marked facets
fixed_vertices = np.unique(np.hstack([facet_to_vertex.links(facet) for facet in facet_tag.find(1)]))
#Visualization of boundary conditions
# Convert mesh and boundary facets to PyVista format plot.vtk_mesh(domain)
topology, cell_types, geometry = plot.vtk_mesh(domain, domain.topology.dim)
# Find boundary facets
bndry_topology, bndry_cell_types, bndry_geometry = plot.vtk_mesh(domain, fdim)
boundary_grid = pv.UnstructuredGrid(bndry_topology, bndry_cell_types, bndry_geometry)
# Extract only fixed boundary facets
fixed_coordinates = domain.geometry.x[fixed_vertices]
#Per verificare che anche quelli fissi siano corretti
dof_coordinates = U.tabulate_dof_coordinates()[fixed_dofs]
# Plot mesh and highlight fixed nodes
plotter.add_mesh(grid, style="wireframe", color="white") # Plot full mesh
plotter.add_mesh(fixed_coordinates, color="red", render_points_as_spheres=True, point_size=10)
# Replace fixed_coordinates with dof_coordinates in visualization
plotter.add_mesh(dof_coordinates, color="green", render_points_as_spheres=True, point_size=10)
plotter.add_text("Dirichlet DOFs (Green)", position="upper_edge", font_size=12, color="green")
plotter.add_text("Boundary Conditions (Fixed Nodes in Red)", position="upper_edge", font_size=12, color="blue")
print("Visualizzazione pronta")
plotter.show()
figure = plotter.screenshot("Image_Boundary_Condition.png")
#Traction vector
#Body force vector
B = fem.Constant(domain, default_scalar_type((0, 0, 0)))
##################################SECOND VISUALIZATION
###########VERSIONE 1
# # Define functions
# u = fem.Function(U)
# p = fem.Function(P)
# j = fem.Function(J)
# m = fem.Function(M)
# m.x.array[:] = 0.0 #This will help Newton’s solver start from a reasonable initial state.
# print("Functions defined")
# δu, δp, δj = δw = ufl.TestFunctions(M)
#####################################################################FINE
#############VERSIONE 2
m = fem.Function(M)
p, j = ufl.split(m)[1], ufl.split(m)[2],
u = ufl.split(m)[0]
m.x.array[:] = 0.0
assert M.num_sub_spaces == 3, f"Error: Expected 3 subspaces in M, but got {M.num_sub_spaces}"
print(f"Number of subspaces in M: {M.num_sub_spaces}")
print(f"Displacement space shape: {M.sub(0).element.space_dimension}")
print(f"Pressure space shape: {M.sub(1).element.space_dimension}")
print(f"Volumetric strain space shape: {M.sub(2).element.space_dimension}")
####### VARIATIONAL FORMULATION #######
# Spatial dimension
d = len(u)
# Identity tensor
I = ufl.variable(ufl.Identity(d))
# Deformation gradient
FF = ufl.variable(I + ufl.grad(u))
# Right Cauchy-Green tensor
C = ufl.variable(ufl.transpose(FF) * FF)
Ic1 = ufl.variable(ufl.tr(C))
J = ufl.variable(ufl.det(FF))
# distortional part of C
C_dist = ufl.variable(J**(-2/3)*C)
Ic1_dist = ufl.variable(ufl.tr(C_dist))
#Fiber definition and orientation
a0 = fem.Constant(domain, default_scalar_type((1, 0, 0)))
Ic4 = ufl.variable(ufl.inner(a0, C*a0))
Ic4_dist = ufl.variable(J**(-2/3)*Ic4)
A0=ufl.variable(ufl.outer(a0,a0))
# Material parameters
C_m=default_scalar_type(100)
K1=default_scalar_type(100)
K2=default_scalar_type(10)
K11 = fem.Constant(domain,K1)
K22 = fem.Constant(domain,K2)
# Stored strain energy density
#psi_volumetrico_matrice=
psi_isochorico_matrice= (C_m/2)*(Ic1_dist -3)
psi_isochorico_fibre= K11/(2*K22)*(ufl.exp(K2*(Ic4_dist-1)**2)-1)
# Second Piola-Kirchhoff stress tensor
SPK_volumetrico_matrice = J*p*ufl.inv(C)
SPK_isochorico_matrice = 2 * J**(-2/3) * ufl.diff(psi_isochorico_matrice,Ic1_dist) * (I-(1/3)*ufl.inner(I,C)*ufl.inv(C))
SPK_isochorico_fibre = J**(-2/3) * ufl.diff(psi_isochorico_fibre,Ic4_dist) * (A0-(1/3)*ufl.inner(A0,C)*ufl.inv(C))
SPK_tot = SPK_volumetrico_matrice + SPK_isochorico_matrice + SPK_isochorico_fibre
# First Piola-Kirchhoff stress tensor
P = ufl.inv(FF)*SPK_tot
def Jacobian_F(u):
d = len(u)
# Identity tensor
I = ufl.Identity(d)
FF = I + ufl.grad(u)
return ufl.variable(ufl.det(FF))
ds = ufl.Measure('ds', domain=domain, metadata=metadata)
#Per vito che leggerà nel futuro
#Il traction vector non è applicato su nessuna superficie
dx = ufl.Measure("dx", domain=domain, metadata=metadata) # Elementarily volume
# Define form F (we want to find u such that F(u) = 0)
def E(r):
d = len(r)
# Identity tensor
I = ufl.Identity(d)
FF = ufl.variable(I + ufl.grad(r))
return ufl.variable(0.5*(C - I))
bulk_modulus = fem.Constant(domain, default_scalar_type(1000))
F1 = ufl.inner(E(δu) , SPK_volumetrico_matrice) * dx + ufl.inner(E(δu) , SPK_isochorico_matrice) * dx + ufl.inner(E(δu) , SPK_isochorico_fibre) * dx - ufl.inner(δu, B) * dx - ufl.inner(δu, T) * ds
F2 = (Jacobian_F(u)-j) *δp *dx
#U(JJ_trial) = bulk_modulus/2 * (JJ_trial - 1)**2
F3 = (bulk_modulus*(j - 1)-p)*δj*dx
F = F1 +F2 +F3
Is the variational formulation that I whore correct?
Any help is very appreciated
