Hi everyone! I want to get the integral of a given variable over all internal facets. When I use assemble_vector the size of the array is different from the number of internal boundaries and I get the wrong integral value. The following is MWE
from dolfinx import *
from dolfinx.fem import (Constant, Function, functionspace, assemble_scalar,
assemble_vector,
dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
from joblib import Parallel, delayed
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
div, dot, dx, dS, grad, inner, lhs, rhs,jump, avg)
import time
from time import sleep
N = 2
L = 100
# Generating mesh
msh = mesh.create_rectangle(comm = MPI.COMM_WORLD, points = ((0, 0), (L, L)), n = (N, N),
cell_type = mesh.CellType.triangle)
DG0 = fem.FunctionSpace(msh, ("Discontinuous Lagrange", 0))
num_cells = msh.topology.index_map(msh.topology.dim).size_local+ msh.topology.index_map(msh.topology.dim).num_ghosts
num_edges = msh.topology.index_map(1).size_local + msh.topology.index_map(1).num_ghosts
cell_list = np.arange(num_cells, dtype=np.int32)
edge_list = np.arange(num_edges, dtype=np.int32)
tdim = msh.topology.dim # Topology dimension
fdim = tdim - 1 # Facet dimension
e4c_list = msh.topology.connectivity(tdim, fdim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(msh.topology)
edge_list1 = np.delete(edge_list, boundary_facets)
sort_index = np.argsort(edge_list1)
cell_tag = meshtags(msh, msh.topology.dim, cell_list, cell_list)
edge_tag = meshtags(msh, 1, edge_list1[sort_index], edge_list1[sort_index])
dS = Measure("dS", domain=msh, subdomain_data = edge_tag)
dx = Measure("dx", domain=msh, subdomain_data = cell_tag)
n = FacetNormal(msh)
h = ufl.CellDiameter(msh)
h_avg = avg(h)
q = ufl.TestFunction(DG0)
for i in edge_tag.values:
a111 = assemble_scalar(form(inner(1, q("+")) * dS(i)))
print(f"a111_{i}",a111)
a11 = assemble_vector(form(inner(1, q("+")) * dS(i)))
print(f"a11_{i}", a11.array, np.shape(a11.array))
a111_1 70.71067811865476
a11_1 [70.71067812 0. 0. 0. 0. 0.
0. 0. ] (8,)
a111_2 50.0
a11_2 [ 0. 50. 0. 0. 0. 0. 0. 0.] (8,)
a111_5 50.0
a11_5 [ 0. 50. 0. 0. 0. 0. 0. 0.] (8,)
a111_7 70.71067811865476
a11_7 [ 0. 0. 70.71067812 0. 0. 0.
0. 0. ] (8,)
a111_8 70.71067811865476
a11_8 [ 0. 0. 0. 70.71067812 0. 0.
0. 0. ] (8,)
a111_9 50.0
a11_9 [ 0. 0. 0. 0. 50. 0. 0. 0.] (8,)
a111_10 50.0
a11_10 [ 0. 0. 0. 0. 0. 50. 0. 0.] (8,)
a111_13 70.71067811865476
a11_13 [ 0. 0. 0. 0. 0. 0.
70.71067812 0. ] (8,)
Obviously the values of the second and fifth sides are placed at the same position.
