Identifying subdomains from level set function on fenicsx
I’m trying to understand the best way to identify subdomains defined from a level set function on dolfinx. Briefly speaking, I have a reference domain D and the domain of interest Omega is defined as x in D such that phi(x) < 0.
When an analytical expression of phi is know, i’m using “locate_entities” from dolfinx.mesh (“strategy1” in the example bellow). However, assuming that the expression of phi is not known, the only approach I was able to figure out was using ufl conditional (“strategy2” in the example). Although error with conditional is smaller, the behavior with mesh refinement seems a bit strange.
Is there any problems with this use of “conditional”? I wonder if there is a better approach when no analytical expression of phi is know.
I appreciate any help!
from dolfinx import fem
from dolfinx.mesh import (locate_entities, create_rectangle, CellType, meshtags)
from ufl import Measure, conditional, ge,dx
import dolfinx.cpp as _cpp
def tag_subdomains(msh, subdomains): # Identifies and marks subdomains accoring to locator function
    cell_indices, cell_markers = [], [] # List for facet indices and respective markers
    fdim = msh.topology.dim
    for (marker, locator) in subdomains:
        cells = locate_entities(msh, fdim, locator)
        cell_indices.append(cells)
        cell_markers.append(np.full_like(cells, marker))
    cell_indices = np.hstack(cell_indices).astype(np.int32)
    cell_markers = np.hstack(cell_markers).astype(np.int32)
    sorted_cells = np.argsort(cell_indices)
    cell_tag = meshtags(msh, fdim, cell_indices[sorted_cells], cell_markers[sorted_cells])
    return cell_tag
tol = 1e-8
# simple example with circle inside a square
def phi(x):
    return np.sqrt((x[0] - 0.5)**2 + (x[1]-0.5)**2) - radius
subdomains = [(1, lambda x: phi(x) >= tol),
                (0, lambda x: phi(x) <= tol)]
N_list = np.array([5,10,20,40,80,160,320])
err = []; err2 = []
for N in N_list:
    comm = MPI.COMM_WORLD
    msh = create_rectangle(comm=MPI.COMM_WORLD,
                        points=((0.0, 0.0), (1.0, 1.0)), n=(N, N),
                        cell_type=CellType.triangle, diagonal = _cpp.mesh.DiagonalType.crossed)
    # Strategy 1: analytical expression
    cell_tag = tag_subdomains(msh, subdomains)
    dx = Measure("dx", domain=msh, subdomain_data=cell_tag)
    one = fem.Constant(msh, 1.0)
    area = 1 - np.pi*radius**2
    err.append(np.abs(area - fem.assemble_scalar(fem.form(one*dx(1)))))
    # Strategy 2: if no analytical expression is known
    dx = Measure("dx", domain=msh)
    V = fem.FunctionSpace(msh, ("CG", 1))
    phi_ = fem.Function(V)
    phi_.interpolate(phi)
    err2.append(np.abs(area - fem.assemble_scalar(fem.form(conditional(ge(phi_, tol), 1, 0)*dx))))
plt.plot(1/N_list,err, label = 'strategy 1'); plt.plot(1/N_list,err2, label = 'strategy 2'); plt.grid()
plt.yscale("log"); plt.xscale("log")
plt.xlabel('h'); plt.ylabel('error'); plt.legend()
error
First of all, you should look at the cell markers, as they clearly show that your approach might have some faults (adding this in your loop):
    with XDMFFile(msh.comm, f"tag_{N}.xdmf", "w") as xdmf:
        xdmf.write_mesh(msh)
        xdmf.write_meshtags(cell_tag)
As you can see from the figure, you have a layer where some vertices satisfies one criteria, while others satisfies the other, thus no tagged cell.
You can alter this with the following code:
radius = 0.25
def tag_subdomains(msh, levelset): # Identifies and marks subdomains accoring to locator function
    num_cells = msh.topology.index_map(dim).size_local
    cells = np.arange(num_cells, dtype=np.int32)
    markers = np.zeros_like(cells)
    markers[locate_entities(msh, dim, levelset)] = 1
    cell_tag = meshtags(msh, dim, cells, markers)
    return cell_tag
tol = 1e-8
def phi(x):
subdomains = lambda x: phi(x) >= -tol
err = []; err2 = []
for N in N_list:
plt.savefig("rates.png")
giving
What do you mean by this? You are trying to fit your area integration with a non-matching mesh, using the whole cell, giving the non-smooth boundary as shown in the figures.
If the analytical level set is known, I would mesh the boundary.
Conditionals simply evaluate phi(x) at every quadrature point, making it the most accurate representation of an Nth order polynomial on the given interval.
This means that you can change the quadrature degree of the integral to improve the error estimates (up to a point):
err = []; err2 = []
qd = 3
for N in N_list:
    dx = Measure("dx", domain=msh, metadata={"quadrature_degree":qd})
![rates_20|640x480](upload://frHmlLrvjPD258GoC9vyCjjfACN.png)
![rates_10|640x480](upload://nNYbQgVah1W057QjKonIY0lDawN.png)
![rates_3|640x480](upload://8l8H83WJg2cg5rUTJKULAHJnto4.png)
plt.plot(1/N_list,err, label = 'strategy 1'); plt.plot(1/N_list,err2, label = f'strategy 2 (degree: {qd})'); plt.grid()
plt.savefig(f"rates_{qd}.png")
Using different qd yields:
rates_3
rates_10
rates_20
Thank you very much!
Hello! May I ask another question? If I should make another post, just let me know.
I’m using ufl conditional to identify subdomains from a level set function, as described in the above discussion. However, I’m facing a memory issue (Error: error code 55). The thing is: i’m working with a shape optimization algorithm, so that i have to run several iterations. For each iteration I have to use the level set function to identify the subdomains and solve an EDP on the subdomains
Since the level set function/subdomains change, I’m initializing the LinearProblem for the EDP inside the loop. I belive that is what is causing the memory issue. However, I cannot figure out a solution. I’ve read other posts suggesting the use of fem.Constants, for example, but it doesn’t seem to apply with the use of conditional for mapping the subdomains. Do you have any sugestions?
Here is a simple example that reproduces my problem. In my computer the error appears after ~380 iterations. (In real examples i don’t have the analytical expression of the level set function, so that mapping the boundary is not an option)
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
                         form, locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import create_rectangle, CellType, locate_entities
from ufl import (Measure, SpatialCoordinate, TestFunction, TrialFunction,
                 dx, grad, inner, le, ge, conditional)
def phi(x):
radius = 0.25; tol =  1e-8
                    points=((0.0, 0.0), (1.0, 1.0)), n=(200, 100),
V = FunctionSpace(msh, ("CG", 1))
kappa = 0.1
eps = 10E-3
er = []; i = 0
r_list = np.array([0.1, 0.2, 0.3, 0.4])
for radius in np.linspace(0.1, 0.4, 10000):
    print(i)
    # Identifying the two-phases/subdomains from level-set
    phi_ = Function(V)
    interior = conditional(le(phi_, tol), 1, 0)
    exterior = conditional(ge(phi_, tol), 1, 0)
    # Solving two-phase problem
    a = interior * inner(kappa*grad(u), grad(v)) * dx \
        + eps * exterior * inner(kappa*grad(u), grad(v)) * dx
    x = SpatialCoordinate(msh)
    L =  interior * Constant(msh, ScalarType(1)) * v * dx \
        + eps * exterior * Constant(msh, ScalarType(1)) * v * dx
    dofs = locate_dofs_geometrical(V, lambda x: np.isclose(x[0], 0))
    bcs = [dirichletbc(ScalarType(1), dofs, V)]
    problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
    uh = problem.solve()
    i+=1
It is simple to rewrite your problem to not having linear-problem inside the loop:
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc,
                         locate_dofs_geometrical)
from dolfinx.mesh import CellType, create_rectangle
                 conditional, dx, ge, grad, inner, le)
def phi(x):
kappa = 0.1
eps = 10E-3
er = []; i = 0
phi_ = Function(V)
    print(i)
    print(uh.x.array)
    i+=1
Hello @dokken, thank you for your quick reply! The results obtained with the two approaches seem to be different, however (i’ve checked by saving uh.x.array[:] in both cases).
The left-hand side of the system also depends on the level set function. Therefore, wouldn’t it be necessary to redefine the solver?
Calling solve re-assembles the matrix and vector (i.e. with the updated levelset phi_, which was updated with interpolation inside your loop.
To highlight this, see the following codes, that both produce the same result
def phi(x):
kappa = 0.1
eps = 10E-3
er = []; i = 0
phi_ = Function(V)
for radius in np.linspace(0.1, 0.4, 4):
    print(i, radius, np.linalg.norm(uh.x.array))
    i+=1
produces the same result as
def phi(x):
kappa = 0.1
eps = 10E-3
er = []; i = 0
    phi_ = Function(V)
    i+=1
Hello, dokken. is it possible to change these codes to parallel version ? When it is runned by mpirun, the indexes returned by locate_entities will exceed the size of marker array.
  File "/mnt/g/workdir/MKM/NO_mkm/test_a.py", line 35, in <module>
  File "/mnt/g/workdir/MKM/NO_mkm/test_a.py", line 15, in tag_subdomains
IndexError: index 53 is out of bounds for axis 0 with size 50
IndexError: index 51 is out of bounds for axis 0 with size 50
and the write_meshtags function needs an argument “x”, what is it ?
#this will cause error in the latest fenicsx
