Hi all,
The following problem is a 2d simplification of a field theory calculation.
Consider the following problem: calculate a field u(x,y) in \Omega=[0,1]\times[0,1] that has obeys Dirichelt BCs u_{bc}=1+2x^2+3y^2 while also making sure it obeys the integral constraint \int\limits_0^{1/2} {dy} u\left( {\frac{1}{2},y} \right) = 1.
The constraint can be written as (\delta is the delta function and \theta is the Heaviside step function):
\int\limits_0^{1/2} {dy} u\left( {\frac{1}{2},y} \right) = \int {d\Omega } \delta \left( {x - \frac{1}{2}} \right)\theta \left( {\frac{1}{2} - y} \right)u(x,y) \equiv \int {d\Omega } g(x,y)u(x,y) = 1
The action is (\lambda is a Lagrange Multiplier):
S = \int {d\Omega } {\left| {\nabla u(x,y)} \right|^2} - \int {d\Omega } f(x,y)u(x,y) - \lambda \left[ {\int\limits_0^{1/2} {dy} u\left( {\frac{1}{2},y} \right) - 1} \right] = \int {d\Omega } \left[ {{{\left| {\nabla u} \right|}^2} - fu - \lambda gu} \right]
Minimization towards the LM gives back the integral constraint while minimizing towards the field gives the PDE:
- {\nabla ^2}u(x,y) = f(x,y) + \lambda g(x,y).
To solve the problem, I suggest the following procedure:
- Find the variational form of the PDE. Say that the trial function is \phi_i while the test function is \sum\limits_j {{u_j}{\varphi _j}} where \phi are proper elements for this problem. The variational form, thus, is:
\sum\limits_j {{A_{ij}}{u_j}} = {F_i} + \lambda {G_i}
where {A_{ij}} = \int {d\Omega } \nabla {\varphi _i} \cdot \nabla {\varphi _j},~~~{F_i}=\int {d\Omega } f{\varphi _i},~~~{G_i}=\int {d\Omega } g{\varphi _i} - Do the same in the integral constraint: \sum\limits_j {{G_j}{u_j}} \equiv G \cdot u = 1
- Write a matrix system as follows:\left[ {\begin{array}{*{20}{c}} A&G\\ {{G^ \bot }}&0 \end{array}} \right]\left[ {\begin{array}{*{20}{c}} u\\ { - \lambda } \end{array}} \right] = \left[ {\begin{array}{*{20}{c}} F\\ { - 1} \end{array}} \right]
- Make the usual assumptions: \delta (x - a) \to \frac{1}{{\sigma \sqrt {2\pi } }}\exp \left[ { - \frac{{{{\left( {x - a} \right)}^2}}}{{2{\sigma ^2}}}} \right],\theta (x - a) \to \frac{1}{{1 + {e^{ - \frac{{x - a}}{\varepsilon }}}}}
- Solve the problem in FEniCSx.
However, I cannot implement the problem correctly in FEniCSx. A code that presents the above idea but doesn’t work and the error will be attached in the end.
Therefore I have the following questions for discussion. Firstly, are the above correct? How can I do a proper implementation in FEniCSx? Secondly, can you suggest another viable option? I see the discussions in other topics about null spaces but I not familiar with them and my problem is not singular.
Finally, can you think of a “better” way to simulate the delta and step functions? Numerical tests in simple problems show high dependance of their parameters in the computational grid.
Thanks!!
import petsc4py.PETSc
import dolfinx.fem.petsc
# Create a mesh for the unit square domain
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 50, 50, dolfinx.mesh.CellType.quadrilateral)
V = dolfinx.fem.FunctionSpace(domain, ("CG", 3))
uD = dolfinx.fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
spatial_dimension = domain.topology.dim
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
boundary_dofs = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim-1, boundary_facets)
dof_coordinates = V.tabulate_dof_coordinates()[boundary_dofs]
bc = dolfinx.fem.dirichletbc(uD, boundary_dofs)
# Define test and trial functions
u = ufl.TrialFunction(V)
# Define the source term f(x, y)
f = dolfinx.fem.Constant(domain, petsc4py.PETSc.ScalarType(-6)) # Define your source term here, e.g., ufl.Constant(0)
ic_term = dolfinx.fem.Constant(domain, petsc4py.PETSc.ScalarType(0))
sigma_d=10**(-3)
sigma_s=10**(-5)
mean_d=0.5
mean_s=0.5
spatial_dimension = 2
dx_temp = ufl.exp(-((x[0] - mean_d)**2) / (2 * sigma_d**2)) / (sigma_d * ufl.sqrt(2 * ufl.pi)) * ((1 / (1 + ufl.exp(-(mean_s - x[1]) / sigma_s)))-(1 / (1 + ufl.exp(-(mean_s - x[1]) / sigma_s))))
# Define and solve the variational problem without constraint
a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
problem_unconstrained = dolfinx.fem.petsc.LinearProblem(a, L, bcs=[bc])
u_unconstrained = problem_unconstrained.solve()
u_unconstrained_array=np.array(u_unconstrained.x.array)
print(u_unconstrained_array)
# Define the integral constraint as a linear form
g = dx_temp
constraint_form = ufl.inner(g, v) * ufl.dx # Define the domain of the line integral
constraint_form_transpose = ufl.inner(v, g) * ufl.dx
# Stiffness Matrix
a_ic = dolfinx.fem.form([[a, constraint_form], [constraint_form_transpose, None]])
# Load Vector
L_ic = dolfinx.fem.form([[L], [1]])
problem_constrained = dolfinx.fem.petsc.LinearProblem(a_ic, L_ic, bcs=[bc])
u_constrained = problem_constrained.solve()
u_constrained_array=np.array(u_constrained.x.array)
Lagrange_multiplier = u_constrained_array[-1]
print(Lagrange_multiplier)
Error:
File "/Tests.py", line 54, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/petsc.py", line 589, in __init__
self._A = create_matrix(self._a)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/petsc.py", line 139, in create_matrix
return _cpp.fem.petsc.create_matrix(a._cpp_object)
AttributeError: 'list' object has no attribute '_cpp_object'
Exception ignored in: <function LinearProblem.__del__ at 0x7f4d7e899900>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/petsc.py", line 627, in __del__
self._solver.destroy()
AttributeError: 'LinearProblem' object has no attribute '_solver'
