@Daniel.Baker Did you resolve your problem? Scifem has real function space and is interoperable with dolfinx. Here’s one of their demos solving singular poisson.
I believe this problem has been confused with the purely Neumann problem so I’d like to restate the problem:
\mathrm{find\ u\ that\ solves}\ \nabla\cdot(-\kappa\nabla u)=0\ \mathrm{in}\ \Omega
assuming \partial\Omega=\Gamma_D\bigcup\Gamma_0\bigcup\Gamma_N and that \Gamma_D\neq\emptyset.
A Dirichlet bc is prescribed on \Gamma_D.
u|_{\Gamma_D}=u_0
Zero flux is prescribed on the insulated boundary.
\kappa\nabla u\cdot\pmb{n}|_{\Gamma_0}=0
A total current condition is enforced on \Gamma_N.
\int_{\Gamma_N}\kappa\nabla u\cdot\pmb{n}\mathrm{ds}=I_{tot}
We start by considering the equivalent optimization problem:
Find u \in H^1(\Omega) such that
\begin{align}
\min_{u \in H^1(\Omega)} J(u) = \min_{u \in H^1(\Omega)} \frac{1}{2}\int_\Omega \vert \nabla u \cdot \nabla u \vert \mathrm{d}x
\end{align}
such that
\begin{align}
\int_{\Gamma_N} \kappa\nabla u\cdot\pmb{n}\mathrm{ds} = I_{tot}.
\end{align}
We introduce a Lagrange multiplier \lambda to enforce the constraint:
\begin{align}
\min_{u \in H^1(\Omega), \lambda\in \mathbb{R}} \mathcal{L}(u, \lambda) = \min_{u \in H^1(\Omega), \lambda\in \mathbb{R}} J(u) + \lambda (\int_{\Gamma_N} \kappa\nabla u\cdot\pmb{n}\mathrm{ds}-I_{tot}).
\end{align}
We then compute the optimality conditions for the problem above
\begin{align}
\frac{\partial \mathcal{L}}{\partial u}[\delta u] &= \int_\Omega \nabla u \cdot \nabla \delta u \mathrm{d}x + \lambda\int_{\Gamma_N} \kappa\nabla \delta u\cdot\pmb{n}\mathrm{ds} = 0, \\
\frac{\partial \mathcal{L}}{\partial \lambda}[\delta \lambda] &=\delta \lambda (\int_{\Gamma_N} \kappa\nabla u\cdot\pmb{n}\mathrm{ds} - I_{tot})= 0.
\end{align}
We write the weak formulation:
\begin{align}
\int_\Omega \nabla u \cdot \nabla \delta u~\mathrm{d}x = -\int_{\Gamma_N} \lambda \kappa\nabla\delta u~\mathrm{ds}\\
\int_{\Gamma_N} \kappa\nabla u \delta \lambda \mathrm{ds} = I_{tot} \delta \lambda .
\end{align}
In Real function spaces — scifem, the integral constraint value is added by modifying the \pmb{b} in A\pmb{x}=\pmb{b}
b_local = get_local_vectors(b, maps)
b_local[1][:] = h
scatter_local_vectors(
b,
b_local,
maps,
b.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
What’s a similar approach for the boundary integral? Below is my MWE where the real function space is defined over \Gamma_N. Were it to work, the total flux at the left and right boundaries would be equal and that over the insulated boundary would be zero.
import scifem
from dolfinx import cpp, default_scalar_type, fem, mesh
from dolfinx.io import gmshio, VTXWriter
class Boundaries:
def __init__(self):
pass
@property
def left(self):
return 1
@property
def bottom(self):
return 2
@property
def right(self):
return 3
@property
def top(self):
return 4
@property
def insulated(self):
return 5
@property
def domain(self):
return 5
def build_mesh(output_path, markers, Lx=10, Ly=1):
generate mesh for given dimensions (`Lx` `Ly`) and write output to `output_path`
gmsh.model.add('2D')
gmsh.option.setNumber("Mesh.MeshSizeMax", 0.1)
coords = [
(0, 0, 0),
(Lx, 0, 0),
(Lx, Ly, 0),
(0, Ly, 0),
points = []
lines = []
# adding coordinates
for coord in coords:
points.append(gmsh.model.occ.addPoint(*coord))
# adding lines
for idx in range(-1, len(points)-1):
lines.append(gmsh.model.occ.addLine(points[idx], points[idx+1]))
gmsh.model.occ.synchronize()
# connect lines into loop
loop = gmsh.model.occ.addCurveLoop(lines)
# create surface from loop
surf = gmsh.model.occ.addPlaneSurface([loop])
# add boundary markers
gmsh.model.addPhysicalGroup(1, [lines[0]], markers.left, "left")
gmsh.model.addPhysicalGroup(1, [lines[1]], markers.bottom, "bottom")
gmsh.model.addPhysicalGroup(1, [lines[2]], markers.right, "right")
gmsh.model.addPhysicalGroup(1, [lines[3]], markers.top, "top")
gmsh.model.addPhysicalGroup(1, [lines[1], lines[3]], markers.insulated, "insulated")
gmsh.model.addPhysicalGroup(2, [surf], markers.domain, "domain")
gmsh.model.mesh.generate(2)
gmsh.write(output_path)
gmsh.finalize()
return 0
def compute_cell_boundary_facets(domain, ct, marker):
"""Compute the integration entities for integrals around the
boundaries of all cells in domain.
Parameters:
domain: The mesh.
ct: cell tags
marker: physical group label
Returns:
Facets to integrate over, identified by ``(cell, local facet
index)`` pairs.
tdim = domain.topology.dim
fdim = tdim - 1
n_f = cpp.mesh.cell_num_entities(domain.topology.cell_type, fdim)
cells_1 = ct.find(marker)
perm = np.argsort(cells_1)
n_c = cells_1.shape[0]
return np.vstack((np.repeat(cells_1[perm], n_f), np.tile(np.arange(n_f), n_c))).T
def compute_interface_cell_boundary_facets(domain, ct, ft, cell_marker, facet_marker):
Compute integration entities for integrals around the boundaries of cells at the
location of prescribed flux expression
domain: the mesh
ct: cell tags
ft: facet tags
cell_marker: marker for subdomain
facet_marker: marker for interface
fdim = tdim - 1
f_to_c = domain.topology.connectivity(fdim, tdim)
c_to_f = domain.topology.connectivity(tdim, fdim)
ft_imap = domain.topology.index_map(fdim)
num_facets = ft_imap.size_local + ft_imap.num_ghosts
interface_facets = ft.find(facet_marker)
int_facet_domain = []
lcells = []
for f in interface_facets:
if f >= ft_imap.size_local:
continue
c_0 = f_to_c.links(f)[0]
subdomain_0 = ct.values[c_0]
local_f_0 = np.where(c_to_f.links(c_0) == f)[0][0]
if subdomain_0 == cell_marker:
int_facet_domain.append([c_0, local_f_0])
if len(f_to_c.links(f)) == 2:
c_1 = f_to_c.links(f)[1]
subdomain_1 = ct.values[c_1]
if subdomain_1 == cell_marker:
local_f_1 = np.where(c_to_f.links(c_1) == f)[0][0]
int_facet_domain.append([c_1, local_f_1])
return int_facet_domain
def delete_numpy_rows(in_arr, to_delete):
out_arr = in_arr
for row in to_delete:
idx = np.where(np.all(out_arr == row, axis=1))[0][0]
out_arr = np.delete(out_arr, idx, axis=0)
return out_arr
if __name__ == '__main__':
markers = Boundaries()
output_mesh_path = 'mesh.msh'
output_potential_path = 'potential.bp'
build_mesh(output_mesh_path, markers, Lx=1)
comm = MPI.COMM_WORLD
partitioner = mesh.create_cell_partitioner(mesh.GhostMode.shared_facet)
domain, ct, ft = gmshio.read_from_msh(output_mesh_path, comm, partitioner=partitioner)[:3]
fdim = tdim - 1
domain.topology.create_connectivity(tdim, fdim)
left_boundary = ft.find(markers.left)
bottom_boundary = ft.find(markers.bottom)
right_boundary = ft.find(markers.right)
top_boundary = ft.find(markers.top)
ds = ufl.Measure("ds", domain=domain, subdomain_data=ft)
V = fem.functionspace(domain, ("Lagrange", 2))
n = ufl.FacetNormal(domain)
# facets submesh
submesh_facets, submesh_facets_to_mesh, f_v_map = mesh.create_submesh(
domain, fdim, ft.find(markers.right))[:3]
num_facets_local = (
domain.topology.index_map(fdim).size_local + domain.topology.index_map(fdim).num_ghosts
parent_to_facets = np.full(num_facets_local, -1, dtype=np.int32)
parent_to_facets[submesh_facets_to_mesh] = np.arange(len(submesh_facets_to_mesh), dtype=np.int32)
entity_maps = {submesh_facets: parent_to_facets}
all_facets = compute_cell_boundary_facets(domain, ct, markers.domain)
right_facets = compute_interface_cell_boundary_facets(domain, ct, ft, markers.domain, markers.right)
minus_right_facets = delete_numpy_rows(all_facets, right_facets)
right_bndry_facets = np.array(right_facets).flatten()
# # Create the measure
dx = ufl.Measure('dx', domain=domain, subdomain_data=ct, subdomain_id=markers.domain)
ds_c = ufl.Measure("ds", subdomain_data=[(1, minus_right_facets.flatten()), (2, right_bndry_facets)], domain=domain)
R = scifem.create_real_functionspace(submesh_facets)
I_tot = fem.Constant(submesh_facets, PETSc.ScalarType(-1.0))
u_left = fem.Function(V)
with u_left.x.petsc_vec.localForm() as u0_loc:
u0_loc.set(0)
left_dofs = fem.locate_dofs_topological(V, 1, left_boundary)
left_bc = fem.dirichletbc(u_left, left_dofs)
u, lmbda = fem.Function(V), fem.Function(R)
du, dl = ufl.TestFunction(V), ufl.TestFunction(R)
zero = fem.Constant(submesh_facets, default_scalar_type(0.0))
kappa = fem.Constant(domain, default_scalar_type(1.0))
a00 = ufl.inner(kappa * ufl.grad(u), ufl.grad(du)) * dx
L0 = ufl.inner(kappa * ufl.grad(du), n) * lmbda * ds_c(2)
L1 = ufl.inner(zero, dl) * ds_c(2)
L1 += ufl.inner(kappa * ufl.grad(u), n) * dl * ds_c(2)
a = fem.form([[a00, None], [None, None]], entity_maps=entity_maps)
L = fem.form([L0, L1], entity_maps=entity_maps)
maps = [(Wi.dofmap.index_map, Wi.dofmap.index_map_bs) for Wi in [V, R]]
F0 = a00 + L0
F1 = L1
F = [fem.form(F0, entity_maps=entity_maps), fem.form(F1, entity_maps=entity_maps)]
j00 = ufl.derivative(F0, u)
j01 = ufl.derivative(F0, lmbda)
j10 = ufl.derivative(F1, u)
j11 = ufl.derivative(F1, lmbda)
J00 = fem.form(j00, entity_maps=entity_maps)
J01 = fem.form(j01, entity_maps=entity_maps)
J10 = fem.form(j10, entity_maps=entity_maps)
J11 = fem.form(j11, entity_maps=entity_maps)
J = [[J00, J01], [J10, J11]]
opts = {
'ksp_type': 'preonly',
'pc_type': 'lu',
'pc_factor_mat_solver_type': 'superlu_dist',
solver = scifem.NewtonSolver(F, J, [u, lmbda], bcs=[left_bc], petsc_options=opts)
solver.solve()
current_l = domain.comm.allreduce(fem.assemble_scalar(fem.form(np.abs(ufl.inner(-ufl.grad(u), n)) * ds(markers.left))), op=MPI.SUM)
current_r = domain.comm.allreduce(fem.assemble_scalar(fem.form(np.abs(ufl.inner(-ufl.grad(u), n)) * ds(markers.right))), op=MPI.SUM)
current_ins = domain.comm.allreduce(fem.assemble_scalar(fem.form(np.abs(ufl.inner(-ufl.grad(u), n)) * ds(markers.insulated))), op=MPI.SUM)
print(current_l, current_r, current_ins)
